86-97 Honda/Acura Radio Wiring - D-series.org
Old 02-12-2014, 12:36 PM   #1 (permalink)
Cali Noob's Avatar
Rep Power: 32 Cali Noob is on a level you can only DREAM about! ! !Cali Noob is on a level you can only DREAM about! ! !Cali Noob is on a level you can only DREAM about! ! !Cali Noob is on a level you can only DREAM about! ! !Cali Noob is on a level you can only DREAM about! ! !
Cali Noob is on a level you can only DREAM about! ! !Cali Noob is on a level you can only DREAM about! ! !Cali Noob is on a level you can only DREAM about! ! !Cali Noob is on a level you can only DREAM about! ! !Cali Noob is on a level you can only DREAM about! ! !Cali Noob is on a level you can only DREAM about! ! !Cali Noob is on a level you can only DREAM about! ! !Cali Noob is on a level you can only DREAM about! ! !Cali Noob is on a level you can only DREAM about! ! !Cali Noob is on a level you can only DREAM about! ! !Cali Noob is on a level you can only DREAM about! ! !Cali Noob is on a level you can only DREAM about! ! !Cali Noob is on a level you can only DREAM about! ! !Cali Noob is on a level you can only DREAM about! ! !
Default 86-97 Honda/Acura Radio Wiring
Hi All,
Didn't see this here and had to look it up elsewhere, figured I would share:
12v Constant (Battery)= White with either Blue or Yellow Stripe
12v Switched (Ignition) = Yellow with Red Stripe
Ground = Black
Left Front + = Blue with Green Stripe
Left Front - = Gray with Black Stripe
Right Front + = Red with Green Stripe
Right Front - = Brown with Black Stripe
Left Rear + = Blue with Yellow Stripe
Left Rear - = Gray with White Stripe
Right Rear + = Red with Yellow Stripe
Right Rear - = Brown with White Stripe
Found this here www.installdr.com/harnesses/ha-wiring.pdf
If something is known to be incorrect or misleading, post up and I will edit this post. The pdf says to use the same wire from one of the speakers for the "power antenna", I don't suspect many of us have factory power antennae on our cars though lol, I just ignored it.
Thanks,
Rob
"Believe none of what you hear and half of what you see."
Pat Primmer, gone but not forgotten, RIP mate!
Function > Form
RTFM!!!
Cali Noob is offline   Reply With Quote Quick reply to this message
iconAll times are GMT -8. The time now is 09:09 PM. | Welcome to Forum, please register to access all of our features.
