Redline manual tranny fluid - tranny fluid info - D-series.org
Go Back   D-series.org D-series Knowledge Factory Archived Technical Info Posts
Old 09-08-2003, 08:46 PM   #1 (permalink)
i am the walrus.
seano's Avatar
Rep Power: 21 seano is hot as a volcanoseano is hot as a volcano
seano is hot as a volcanoseano is hot as a volcanoseano is hot as a volcanoseano is hot as a volcanoseano is hot as a volcano
Send a message via ICQ to seano Send a message via AIM to seano
I'm going to be replacing my manual tranny fluid and want to put Redline fluid in my trans. What weight do I need?
- hatched
Many people advise not to use that stuff. - cybrpunko
rip apart a tranny that has run Redline and you'll see why.
Use dino 10w30 or Honda MTF
- Mista Bone
seano is offline   Reply With Quote Quick reply to this message
Old 09-08-2003, 08:46 PM   #2 (permalink)
i am the walrus.
seano's Avatar
I have used Dextron 3 ATF, Castrol 10w-30, and Mobil 1 synthetic 10w-30 in my race car. The Dex. 3 did not shift as smooth as the Castrol or the Mobil 1. I have been using the Mobil 1 synthetic now for two years and the gears look perfect. I cannot see any visible signs of wear on the main gears and only slight wear on the final drive gears. The final drive gears have been used for 2 years worth of racing behind my 418 hp drag car. I am a firm believer in the film strength properties of Mobil 1 synthetic in reducing wear inside your transmission......I recommend it.
Later,
ZEX man
Old 09-08-2003, 08:47 PM   #3 (permalink)
i am the walrus.
seano's Avatar
I had a problem in the past of constantly breaking the 3-4 shift fork in my drivetrain. That led to a quest of finding the ideal transmission fluid that not only protected my tranny components....but allowed ideal alighnment of my assemblies (gear and synchro) for ease of shifting...thus no more forced gear changes at high RPMs...leading to broken components.
After much ado...Torco MTF Synthetic Manual Fluid was my answer.....2 seasons so far: no broken forks..and it doesn't foam like other lubricants. I have a habit of inspecting my tranny components as well: they look great. The oil also has a centistoke viscosity rating equivalent to a 20wt oil...helps with power and economy efficiency too.
Long live the d series!!
'Bisimoto D15
Old 09-08-2003, 08:47 PM   #4 (permalink)
i am the walrus.
seano's Avatar
here's their website
www.torcoracingoils.com
GaryO
Similar Threads
Thread Thread Starter Forum Replies Last Post
tranny fluid..... whiteex DIY Forum 3 03-07-2005 02:01 PM
checking tranny fluid 00EXProject Transmission alley 3 03-06-2005 07:51 PM
How much tranny fluid? mellon General Tech 8 02-27-2005 01:39 PM
Redline MTL ok to use on a 98 EX 5 speed tranny??? silver98EX Transmission alley 9 01-24-2005 02:12 PM
L3 Tranny Fluid. Apex001 Transmission alley 2 06-05-2004 11:05 PM
iconAll times are GMT -8. The time now is 05:11 PM. | Welcome to Forum, please register to access all of our features.
