2001-2004 Tranny Ratios - D-series.org
Closed Thread
Old 01-26-2006, 12:50 PM   #1 (permalink)
Default 2001-2004 Tranny Ratios
........DX/LX.........HX...........EX
1......3.461.........3.461......3.142
2......1.869.........1.750......1.869
3......1.241.........1.116......1.241
4......0.969.........0.857......0.969
5......0.710.........0.710......0.756
FD....4.111.........3.842......4.411
Info if from Factory Honda manual for 2001-2004 Civics.
transzex is offline   Quick reply to this message
Old 01-26-2006, 12:54 PM   #2 (permalink)
D-Series Destruction Master
f00ker's Avatar
Rep Power: 36 f00ker is on a level you can only DREAM about! ! !f00ker is on a level you can only DREAM about! ! !f00ker is on a level you can only DREAM about! ! !
f00ker is on a level you can only DREAM about! ! !f00ker is on a level you can only DREAM about! ! !f00ker is on a level you can only DREAM about! ! !f00ker is on a level you can only DREAM about! ! !f00ker is on a level you can only DREAM about! ! !f00ker is on a level you can only DREAM about! ! !f00ker is on a level you can only DREAM about! ! !
iTrader Score: 31 reviews
Send a message via AIM to f00ker Send a message via MSN to f00ker Send a message via Yahoo to f00ker
thanks boner
1996 Subaru Legacy L
1998 Ford Explorer XLT
f00ker is offline   Quick reply to this message
Old 01-26-2006, 01:38 PM   #3 (permalink)
Rep Power: 0 berettagtz117 is a Top Aussie
berettagtz117 is a Top Aussieberettagtz117 is a Top Aussieberettagtz117 is a Top Aussieberettagtz117 is a Top Aussieberettagtz117 is a Top Aussieberettagtz117 is a Top Aussieberettagtz117 is a Top Aussieberettagtz117 is a Top Aussieberettagtz117 is a Top Aussieberettagtz117 is a Top Aussieberettagtz117 is a Top Aussie
iTrader Score: 17 reviews
Foshizznit! I new it was better than previous tranny's !!!
berettagtz117 is offline   Quick reply to this message
Old 01-26-2006, 06:28 PM   #4 (permalink)
f00ker's Avatar
*knew
Old 02-03-2006, 11:21 AM   #5 (permalink)
the taller tires offset the advantage........
Old 02-03-2006, 11:24 AM   #6 (permalink)
f00ker's Avatar
are the tranny's compatible with 92-2k civics?
Old 02-03-2006, 11:31 AM   #7 (permalink)
nope.
2001 + use cable linkage to shift.
PS might wanna add this as a sticky in the 7th gen forum.
Old 02-03-2006, 12:41 PM   #8 (permalink)
f00ker's Avatar
nope.
cable, as in...just like the 4th gen, or completely different.
Old 02-03-2006, 02:28 PM   #9 (permalink)
K2e2vin's Avatar
Rep Power: 18 K2e2vin It's a JDM Star Bitches....
Send a message via AIM to K2e2vin
cable shift linkage as in prelude/accord/RSX.
88-00 had solid linkages.
-Kevin N. E.
1992 Honda Accord LX coupe
K2e2vin is offline   Quick reply to this message
Old 02-03-2006, 02:34 PM   #10 (permalink)
f00ker's Avatar
ahhhhhh, i was thinking of the clutch!
Old 04-28-2006, 11:04 AM   #11 (permalink)
Rep Power: 14 gmcuajo is nobody
nope.
If the problems is the cable linkage, I can say yes it fit. Just use the 01-5 civic shifter (with its plastic mounts) and clables and use your imagination to fit it on the car.
On Honda Tuning magazine they swap a K20 or K24 on an older civic. They cut the floor where the shifter is, use aluminum sheet to build a custom mount. Ask a friend who receive that magazine...
gmcuajo is offline   Quick reply to this message
Old 04-28-2006, 11:16 AM   #12 (permalink)
f00ker's Avatar
wow, you are so helpful, thanks for all of your information, and your sources!
:fairies:
Old 05-28-2006, 07:40 AM   #13 (permalink)
maxquebec
question please
the casing is it the same
Old 07-22-2006, 05:42 AM   #14 (permalink)
Rep Power: 0 Chiovnidca is a name known to allChiovnidca is a name known to allChiovnidca is a name known to allChiovnidca is a name known to allChiovnidca is a name known to allChiovnidca is a name known to allChiovnidca is a name known to allChiovnidca is a name known to allChiovnidca is a name known to all
You sure that hx 3rd isnt 1.166? That's what the 01-05 manual says.
Chiovnidca is offline   Quick reply to this message
Old 10-19-2006, 03:32 PM   #15 (permalink)
blackDseries's Avatar
Rep Power: 14 blackDseries is almost a somebodyblackDseries is almost a somebodyblackDseries is almost a somebodyblackDseries is almost a somebody
yes the trannys out of 01-05 civics are the same as the older ones minus the linkage. you can bolt an 01 tranny to a Y8 or Z6 so ive read , ive never tried yet.
built k24/k20 - full custom AllInFab turbo kit - PT6766 - best time 9.83 at 151
blackDseries is offline   Quick reply to this message
Old 10-20-2006, 06:16 AM   #16 (permalink)
The Great Weldini
remoer's Avatar
Rep Power: 32 remoer Still a JDM Star....remoer Still a JDM Star....
remoer Still a JDM Star....remoer Still a JDM Star....remoer Still a JDM Star....remoer Still a JDM Star....remoer Still a JDM Star....remoer Still a JDM Star....remoer Still a JDM Star....remoer Still a JDM Star....remoer Still a JDM Star....
iTrader Score: 54 reviews
Send a message via AIM to remoer Send a message via MSN to remoer Send a message via Yahoo to remoer
soooooooooooooooooooo.... what would be the ratio on the conversion from 5 speed to 6 speed? the only reason i ask cause i'm in the process in buying a EP3 and i made a thread on it a while back. lol
https://www.d-series.org/forums/showthread.php?t=43370
1 monkey power = 0.332 hp.
The suspension should always be faster than the engine - BMW
The term stage was created to make mentally slow ppl feel physically fast.
my DOHC ZC - 133.73whp and 108.48wtq (tuned on a Dynojet)
remoer is offline   Quick reply to this message
Old 07-26-2007, 11:52 AM   #17 (permalink)
Rep Power: 0 Shireen is nobody
How hard would it be to make it a 6 speed (matter of adding an extra gear, or is it a matter of getting a new mount able to handle the 7 gear settings [with reverse].)
I saw on another thread that it would be advantagous to swap first gear for a 2.75 gear, does that still apply to our DX/EX models?
Shireen is offline   Quick reply to this message
Old 08-22-2007, 10:17 PM   #18 (permalink)
You saying that the 05 manual has a typo or the earlier ones?
One of them has a typo which is quite common.
Old 08-22-2007, 10:29 PM   #19 (permalink)
Old 08-22-2007, 10:30 PM   #20 (permalink)
Closed Thread
HTML code is On
iconAll times are GMT -8. The time now is 11:18 PM. | Welcome to Forum, please register to access all of our features.
