2001 Honda EX Junkyard D17 Swap - D-series.org
Old 03-05-2013, 09:35 AM   #1 (permalink)
Rep Power: 0 Wildcard007 is nobody
Default 2001 Honda EX Junkyard D17 Swap
I have a 2001 Honda Civic EX which had the D17A2 Engine with a rod knock. So me and a buddy grabbed a Engine from the local junkyard. It happened to be the D17A1 Block from a LX. After reading a bunch of the forums it appeared that as long as we kept the Head from my EX (VTec) and since my ECU is a EX (VTec) it would work. So we got a D17A1 Block with my D17A2 Head back in the car, everything is hooked back up. Were getting the engine to crank but not start. We checked fuel lines and fuel is pumping to it. When we try to start it after theres a bunch of clicking on the passenger side which i assume is probably the computer. We tried pulling the ECU fuse to reset the computer along with most fuses under the hood. Before the swap the car started fine just had a terrible knock. Any ideas?
Wildcard007 is offline   Reply With Quote Quick reply to this message
Old 03-06-2013, 12:06 PM   #2 (permalink)
NaveLB's Avatar
Rep Power: 0 NaveLB is trying to make new friends
Check your grounds. That would be my first thing
1994 Honda del Sol Si-sleeved d16z6
DO NOT GET WORK DONE BY JG ENGINE DYNAMICS
NaveLB is offline   Reply With Quote Quick reply to this message
Old 03-06-2013, 01:36 PM   #3 (permalink)
SteelCityZC's Avatar
Rep Power: 9 SteelCityZC will become famous soon enoughSteelCityZC will become famous soon enoughSteelCityZC will become famous soon enough
Check grounds
Sent from AutoGuide.com Free App
98 Civic LX 4 door
1st-d16y7 rod knock
2nd-d16z6 block with y7 put a hole in the block
3rd-d16a6 block with z6 head
SteelCityZC is offline   Reply With Quote Quick reply to this message
Old 03-06-2013, 02:37 PM   #4 (permalink)
I did a compression test which tested to 180 psi so i think thats pretty good
i got a Spark tester and tested the coils and got no spark which i mean we all kinda assumed that here that it was a spark issue but i tried some different coils still no spark
Grounds look good
anyone know how to properly test a relay?
Thanks
Old 03-06-2013, 04:57 PM   #5 (permalink)
Get a Pin out of the relay and a ohm meter and test it, thats how I would do it
98 Civic LX 4 door
1st-d16y7 rod knock
Old 03-10-2013, 06:18 PM   #6 (permalink)
Replaced the relay still no luck? Any more ideas why it won't send spark to the coils?
Old 03-11-2013, 03:22 PM   #7 (permalink)
Start checking crank sensor and cam sensor
98 Civic LX 4 door
1st-d16y7 rod knock
Old 03-12-2013, 11:37 AM   #8 (permalink)
Never finishes (TWSS)
Evanguy's Avatar
Rep Power: 18 Evanguy is the fucking MAN!!!!Evanguy is the fucking MAN!!!!Evanguy is the fucking MAN!!!!Evanguy is the fucking MAN!!!!
if your grounds arnt hooked up a spark tester may not work depending where you ground the tester or the plug.. see if the longest plug wire will reach your - battery post and just leave the plug in the wire and ground the thread area
but the car turns over so i dont tihink its the grounds anyway.
ill bet its the crank sensor or cam sensor though..spark is based off of the readings from those sensors
Old 03-12-2013, 06:59 PM   #9 (permalink)
It's a d17 coil on plug set up. Check grounds, if there are good then check for crank and cam sensor, the PCM has to see both, if not then it will not have spark
98 Civic LX 4 door
1st-d16y7 rod knock
Old 03-18-2013, 10:05 AM   #10 (permalink)
HiProfile's Avatar
Check the basics - fuel and spark. Use starting fluid if you have to. If it's all there, it's not sparking at the right time. Hook up a timing light is possible (not sure how on COP), see when it's sparking.
Old 04-22-2013, 09:08 PM   #11 (permalink)
Rep Power: 0 red94 is nobody
there are a group of 3 ground wires together on an eye lit on the left hand side of the motor they ground the ignition system if they are not there then the coils will not fire also check and make sure you have the crank sensor and the cam sensor plugged in the cam sensor is a pain to get plugged in so make sure its plugged in I just got done doing rebuilding the head and trans on my 01 civic the car will crank but wont fire if the grounds are not hooked up and you will get no spark
red94 is offline   Reply With Quote Quick reply to this message
Old 04-23-2013, 08:38 AM   #12 (permalink)
Rep Power: 0 Nitrous1024 is nobody
This doesn't fix your problem, but i hope you do know that the D17A1 block doesn't have the VTEC oil passage ways to engage the VTEC-E operation of your D17A2 (thus starting may be difficult).
Nitrous1024 is offline   Reply With Quote Quick reply to this message
HTML code is On
iconAll times are GMT -8. The time now is 04:04 AM. | Welcome to Forum, please register to access all of our features.
