P0430 and P0431 - D-series.org
Old 09-12-2012, 06:07 PM   #1 (permalink)
Rep Power: 11 Birdley97EKHB08 is learning the way of the DBirdley97EKHB08 is learning the way of the D
iTrader Score: 18 reviews
Send a message via AIM to Birdley97EKHB08
Default P0430 and P0431
2003 Civic LX bone stock
When it is cold the car runs like crap and falls on its face then picks back up. I get CEL for P0430 and P0431 all pointing to the catalytic converter. But my experience with Honda's I've never had an issue with a cat on a civic with only 130k. I don't mind replacing the cat or o2 sensors. I have read that the cat can become clogged from a misfire engine. Never got a CEL for misfire or low voltage on o2. In the past I have had issues on a different civic misfiring bc of the distributor. Anyone have any related issue? I plan to check to make sure no major damage. After that possibly replace exhaust manifold/cat?
Any advice would help....
Thanks.
97 Civic HB - JDM D15b/z6
T66 - junk
12.7 @ 106mph
Birdley97EKHB08 is offline   Reply With Quote Quick reply to this message
Old 09-13-2012, 07:45 PM   #2 (permalink)
boosted ef9's Avatar
Rep Power: 0 boosted ef9 is nobody
Before replacing the cat I'd check the o2 ans see if they are working and see whale your car is running.. Or if the o2 are lazy then I'd switch them first and then check it again.. Your cat should be good since you've had no problems with your car
91 EF9 [D16a6]
89 MK3 SUPRA [7mgte]
99 Gs400 [Static]
boosted ef9 is offline   Reply With Quote Quick reply to this message
Old 09-20-2012, 06:03 AM   #3 (permalink)
Joey Misanthropy
Joseph Davis's Avatar
Rep Power: 16 Joseph Davis is a name known to allJoseph Davis is a name known to allJoseph Davis is a name known to allJoseph Davis is a name known to allJoseph Davis is a name known to allJoseph Davis is a name known to allJoseph Davis is a name known to allJoseph Davis is a name known to all
Send a message via AIM to Joseph Davis
On that topic, this is a great cheap way to check OBD2 datastreams, codes, etc.
Amazon.com: BAFX Products (TM) - ELM 327 Bluetooth OBD2 scan tool - For check engine light and other diagnostics - Android compatible: Car Electronics Amazon.com: BAFX Products (TM) - ELM 327 Bluetooth OBD2 scan tool - For check engine light and other diagnostics - Android compatible: Car Electronics
It streams to a freeware Torque app for Android (there's probably a variant for crApple, but those guys only care about blogging and can't change oil correctly), and can be used with most of the PC-based ELM327 scanner softwares.
Click link, leave constructive visitor message:
Joseph Davis is offline   Reply With Quote Quick reply to this message
Old 10-06-2012, 07:41 PM   #4 (permalink)
Rep Power: 15 signorelli21 is nobody
Joey your link sucks, however thanks for the tip, I'm buying one of those to see if it works in my Scion :P
signorelli21 is offline   Reply With Quote Quick reply to this message
HTML code is On
iconAll times are GMT -8. The time now is 09:16 PM. | Welcome to Forum, please register to access all of our features.
