02 civic Ex. i would like to know which manifold will fit my d17. - D-series.org
Old 01-08-2009, 12:41 PM   #1 (permalink)
starpostrera's Avatar
Rep Power: 0 starpostrera is nobody
Smile 02 civic Ex. i would like to know which manifold will fit my d17.
since you guys know the d17 manifold is plastic.. so i want to run 20 psi of boost n my d17 and im not sure if the manifold will be able to handle that..
im running 9 psi but now i want to change my internals to boost the thing up to 20 psi. which internals should i use and where can i get it from...
thanks
most b people
@ my d17 but they
on the the streets.
starpostrera is offline   Reply With Quote Quick reply to this message
Old 01-08-2009, 01:18 PM   #2 (permalink)
Rep Power: 11 baron340 is nobody
have you researched anything? at all? go look at dezod.com ... oooh and aaahh at all the shiny parts. they have just about every part you need to fully build an engine. the only options for manifold are a modified d16y8 intake mani, or a custom made one. or finding a used one from gerry at jdmfabtech... but good luck with that.
baron340 is offline   Reply With Quote Quick reply to this message
Old 01-11-2009, 07:34 PM   #3 (permalink)
unevolved's Avatar
Rep Power: 11 unevolved is learning the way of the Dunevolved is learning the way of the D
I second that. Please search. Here, 7thgen, HT, everywhere. The internet is your friend. Just read before you start asking really general questions. Odds are it's been answered before.
1992 EG Hatch- $2014 Challenge Build
2012 Formula SAE- Project Autocrosser
2003 E46 Sedan- Daily
unevolved is offline   Reply With Quote Quick reply to this message
Old 01-11-2009, 07:38 PM   #4 (permalink)
nonvtak ftw
Grounded's Avatar
Rep Power: 28 Grounded Still a JDM Star....
Grounded Still a JDM Star....Grounded Still a JDM Star....Grounded Still a JDM Star....Grounded Still a JDM Star....Grounded Still a JDM Star....Grounded Still a JDM Star....Grounded Still a JDM Star....Grounded Still a JDM Star....Grounded Still a JDM Star....Grounded Still a JDM Star....Grounded Still a JDM Star....
iTrader Score: 15 reviews
Send a message via AIM to Grounded
dont act like a fool. if you already boosted a d17 then you know any manifold you pick to run will need modified to fit.
D-B-D-D-B-F-K-4G??
Grounded is offline   Reply With Quote Quick reply to this message
Old 03-12-2009, 02:01 PM   #5 (permalink)
jamisgood's Avatar
Rep Power: 14 jamisgood is learning the way of the Djamisgood is learning the way of the D
Send a message via AIM to jamisgood
Of course Grounded is correct, he know's his shit. But to second that...most people go with the y8 IM. Probably the easist and definately the most common one to do. Still requires mounting modifications and i believe a fuel return line is added too.
2002 Honda Civic Coupe LX (silver):
Tein Basic Damper Coilovers
Fujita CAI
HP Racing 4-1 Ceramic Header
de-catted exhaust
16" Grid Full Royal Sport Bronze Rotas
2 1/4" custom exhaust
Lightened Flywheel
Apexi Neo
D17A2 engine
jamisgood is offline   Reply With Quote Quick reply to this message
Old 03-12-2009, 07:31 PM   #6 (permalink)
Rep Power: 14 gmcuajo is nobody
gmcuajo is offline   Reply With Quote Quick reply to this message
Old 03-12-2009, 07:52 PM   #7 (permalink)
MadScientist's Avatar
Rep Power: 14 MadScientist is obviously a regularMadScientist is obviously a regularMadScientist is obviously a regularMadScientist is obviously a regularMadScientist is obviously a regularMadScientist is obviously a regularMadScientist is obviously a regularMadScientist is obviously a regular
Send a message via AIM to MadScientist Send a message via MSN to MadScientist Send a message via Yahoo to MadScientist
Do some research first. Learn what you're doing to your car before you attempt it and blow it up.
Here are some links to get you started:
Turbo essential information:
https://d-series.org/forums/showthread.php?t=77291
Contains a bunch of links for more info:
https://d-series.org/forums/showthread.php?t=102717
Some more:
http://www.superhonda.com/forum/f87/...k-here-331005/
Some info about your the d motor:
http://www.superhonda.com/forum/f87/...rchive-218226/
The most comprehensive(but not complete) tuner directory that I know of:
http://www.honda-tech.com/showthread.php?t=2368887
this link contains many FAQ that you might have:
http://www.honda-tech.com/showthread.php?t=1024174
As for parts, I would highly recommend
http://www.rcautoworks.com and http://www.go-autoworks.com/
Welcome to dark side.
T3 Super 60 - RCAutoworks build.
MadScientist is offline   Reply With Quote Quick reply to this message
Old 03-12-2009, 08:39 PM   #8 (permalink)
1cln_eg's Avatar
Rep Power: 0 1cln_eg is nobody
the d17 is similar to the y8 and y7 same style head so as far as intake manifold goes u should be able to slap a y8 manifold on with a little modifiction
GOT MY OWN STYLE!
1cln_eg is offline   Reply With Quote Quick reply to this message
Old 03-12-2009, 08:58 PM   #9 (permalink)
Close close close close close close close close close close close close close close close close close close close close close close close close close close close close close close close close close close close close close close close close close close close close close close close close close close close close close close close close close close close close close close close
HTML code is On
iconAll times are GMT -8. The time now is 03:42 AM. | Welcome to Forum, please register to access all of our features.
