Speed sensor - D-series.org
Old 06-03-2007, 10:10 PM   #1 (permalink)
Acid X's Avatar
Rep Power: 7 Acid X is starting to learn the ropesAcid X is starting to learn the ropesAcid X is starting to learn the ropesAcid X is starting to learn the ropesAcid X is starting to learn the ropesAcid X is starting to learn the ropes
Default Speed sensor
So my girlfriend recently purchased an 88 crx with a 95 si motor swap. The thing is, the tranny is still from an EF (considering its cable not hydro)..
The ECU in the car reads PM6-A09 which i read is still the stock crx ecu, but the ecu tells me something is wrong with the speed sensor (17 blinks).
The speedo in the car doesnt work, guy said something about the speedo cable though.
The guy also said that he bought the transmission seperately from a shop...
My manual tells me that the speed sensor in the ef trannys is a mechanical (gear driven) one, while the newer trannys are electronic...
The CEL doesnt come on until maybe 5 mins or so of driving though, which i find odd. So what could be wrong? Just replace the speed sensor on the trans?
Oh and the trans code reads L3-2076002, what kind of trans is it?
Off topic, but semi related question, if i were to swap to a P26 ecu what would be the downfall? I don't like having the vtec hooked up to a button and i know this ecu isnt tuned right for the motor thats hooked to it. I assume since the ecu reads from an electronic sensor, then i would be constantly throwing a code since i dont have an electronic sensor on the tranny, right?
The CRX that broke the bank!
MANUAL SWAP [See my How-To!]
(SOLD!) White '92 Civic Hatch: D15B7 Manual (Swapped!) - Butt-dyno chp: ~130 - AEM CAI, JG bored Throttle Body, AEM Fuel Rail, Edelbrock Performer X IM, A6 Camshaft, Y7 Cam Gear, Edelbrock Shorty Header, DNX 2.5" muffler
Acid X is offline   Reply With Quote
Old 06-03-2007, 10:54 PM   #2 (permalink)
Fuck Brutus
4Door's Avatar
Location: my mom is gone but will NEVER be forgotten, her love will last forever... 10/3/1945-6/16/2007 R.I.P.
Rep Power: 26 4Door is on a level you can only DREAM about! ! !4Door is on a level you can only DREAM about! ! !4Door is on a level you can only DREAM about! ! !
4Door is on a level you can only DREAM about! ! !4Door is on a level you can only DREAM about! ! !4Door is on a level you can only DREAM about! ! !4Door is on a level you can only DREAM about! ! !4Door is on a level you can only DREAM about! ! !
i had a problem with my speed sensor after my swap... turns out when i legthen my wires i f-ed up...
your should be a cable driven one, they all have gears on them... from what ive read, there all pretty much interchangeable... mine was cable driven, i swapped it for the electrical version, no problems at all after i rewired it the second time... i still have a spare electric speed sensor if you need one...
H.E.A.R.T
Honda Enthusiasts Against Ricer Trash
RIP
Milo & Pat
4Door is offline   Reply With Quote
Old 06-03-2007, 11:26 PM   #3 (permalink)
4speedpride's Avatar
Rep Power: 8 4speedpride  is slowly gaining respect4speedpride  is slowly gaining respect4speedpride  is slowly gaining respect4speedpride  is slowly gaining respect4speedpride  is slowly gaining respect
ya, install a cable in there, it should work then because even the ef and da clusters send a speedo signal to the ecu. same way 2 step rev limiter works in turbo edit
Originally Posted by ZackieDarko View Post
buttsecks?
Originally Posted by S Q A D
hondas love boost .... boost loves you
*1990 EX 4dr*
B18C1 w/ CTR pistons, B16 head, skunk2 valve springs, crower stage 3 cams and CBR1000 Throttle bodies
*1993 LX 4dr*
H23A1, QSD H2B kit, GSR trans, log mani, HX35, 27x7x2.5 FMIC, 2.25" ic piping
My ride thread:
http://www.d-series.org/forums/showcase/87510-1990-ex-4-door.html:bravo:
4speedpride is offline   Reply With Quote
Old 06-03-2007, 11:30 PM   #4 (permalink)
oh yand yes, both cable and hydro trannys use a gear driven sensor, make sure the one you have has a hole in the top of it and not a plug
buttsecks?
*1990 EX 4dr*
*1993 LX 4dr*
My ride thread:
http://www.d-series.org/forums/showthread.php?t=87510:bravo:
Old 06-03-2007, 11:33 PM   #5 (permalink)
I neither dread nor desire.
Rep Power: 60 transzex is on a level you can only DREAM about! ! !transzex is on a level you can only DREAM about! ! !transzex is on a level you can only DREAM about! ! !transzex is on a level you can only DREAM about! ! !
transzex is on a level you can only DREAM about! ! !transzex is on a level you can only DREAM about! ! !transzex is on a level you can only DREAM about! ! !transzex is on a level you can only DREAM about! ! !transzex is on a level you can only DREAM about! ! !transzex is on a level you can only DREAM about! ! !transzex is on a level you can only DREAM about! ! !transzex is on a level you can only DREAM about! ! !transzex is on a level you can only DREAM about! ! !
cable if the OBD-0 giving no signal to the ECU
transzex is offline   Reply With Quote
iconAll times are GMT -8. The time now is 05:23 AM. | Welcome to Forum, please register to access all of our features.
