Dead bearings... tranny replacement - D-series.org
Old 05-24-2007, 01:18 PM   #1 (permalink)
Rep Power: 0 bgladfelter is nobody
Default Dead bearings... tranny replacement
My tranny started shifting hard. When I checked the level of oil in it... there was none. Apparently my axle seals went or Jiffy Lube left something loose. From searching/reading its gonna be exspensive to rebuild. I refilled it but it still shifts very hard into every gear.
Its an 89 Si tranny. If I switch to a 90-91 do I need a new flywheel and clutch since its a different size, or is is just the spline count that matters? Main reason I also ask is I've got Raxle axles and don't want to switch them (why I'm not installing my buddy's 88 DX tranny and axles). The clutch and PP are still good.
Thanks for any suggestions.
89 Y49 CRX Si
DOHC ZC I/H/E - Spun bearing
d16a6 Exospeed 909 cam/P29 pistons - Dead(dropped valve)
SOHC ZC I/H/E now
94 Civic coupe EX
Stock
91 CRX DX - Wrecked
bgladfelter is offline   Reply With Quote
Old 05-24-2007, 01:29 PM   #2 (permalink)
D-Series Post Be-itch... gimme gimme gimme
Rep Power: 13 Richie_A_19 is hot as a volcano
Richie_A_19 is hot as a volcanoRichie_A_19 is hot as a volcanoRichie_A_19 is hot as a volcanoRichie_A_19 is hot as a volcanoRichie_A_19 is hot as a volcanoRichie_A_19 is hot as a volcanoRichie_A_19 is hot as a volcanoRichie_A_19 is hot as a volcanoRichie_A_19 is hot as a volcanoRichie_A_19 is hot as a volcanoRichie_A_19 is hot as a volcanoRichie_A_19 is hot as a volcanoRichie_A_19 is hot as a volcanoRichie_A_19 is hot as a volcanoRichie_A_19 is hot as a volcano
Won't the Raxles fit in the 88 DX?? I have 00 EX axles in my 93 DX tranny??
Richie_A_19 is offline   Reply With Quote
Old 05-25-2007, 03:04 PM   #3 (permalink)
Rep Power: 7 gearhead98 will become famous soon enoughgearhead98 will become famous soon enoughgearhead98 will become famous soon enough
the 89 and the 90 trannies both have the same spline count, 20. the difference is in the size of the clutch disk, the 89 is 200 and the 90-00 is 210mm.
gearhead98 is offline   Reply With Quote
Old 05-29-2007, 09:55 AM   #4 (permalink)
Thanks, I know the 89 and 90 do, its the 88 I thought was 21
89 Y49 CRX Si
SOHC ZC I/H/E now
94 Civic coupe EX
Stock
91 CRX DX - Wrecked
iconAll times are GMT -8. The time now is 01:01 AM. | Welcome to Forum, please register to access all of our features.
