Si Tranny Not catching 3rd.or 5th. - D-series.org
Old 05-15-2007, 12:45 PM   #1 (permalink)
Rep Power: 0 92EG8 is nobody
Default Si Tranny Not catching 3rd.or 5th.
This is my 3rd Tranny ....I put in a New Exedy Stage 1 Clutchw/ Pressure Plate....on a used Si Tranny from a friend. When i installed my tranny i could hit every gear except 5th gear and sometimes 4th would pop out. People told me it was because my motor mounts might be bad but it worked fine for all my other trannys. PS> I was in the car and drove it with the Tranny before i bought it and before i put it in on the engine i went through all gears and the tranny caught them (spinned the spindle to make sure it was working properly.) Then everything was fine until i was crusing back home on some long ass back roads and i was gunning my car in 4th gear......I topped it out and then threw my car N and coasted. when i went to downshift i saw that 3rd gear was not catching ... ITs there because i put into 3rd and u feel the grinding as if the shifter needs a little more push forward to catch 3rd gear. So 3rd gear was not abused or anything during the cruise so i dont know how a simple TOP end run in 4th gear affected this. I havent looked under the car yet to see if maybe the bitch pin came out. but what do u guuys think could of happend? What do i have to do to catch 3rd gear again since it seems like if the shifter could move one inch forward it would catch it.
92EG8 is offline   Reply With Quote
Old 05-15-2007, 12:48 PM   #2 (permalink)
Rep Power: 8 EG8SIR is starting to learn the ropesEG8SIR is starting to learn the ropesEG8SIR is starting to learn the ropesEG8SIR is starting to learn the ropesEG8SIR is starting to learn the ropesEG8SIR is starting to learn the ropesEG8SIR is starting to learn the ropes
sounds like that tranny was abused
http://www.pbase.com/minority_report/image/64672006.jpg
you know what it is...we fuck spiders in each one of their eyes
1995 Civic 5 Speed, SOHC ZC Vtec, Fake J's Intake, DC Header, Greddy Catback, Street Tuned on the HeebSpeed laptop by myself
15.23@90.66 with a 2.29 60'
http://media.putfile.com/sohcvtec1
EG8SIR is offline   Reply With Quote
Old 05-15-2007, 02:59 PM   #3 (permalink)
Rep Power: 0 Rexin24/7 is nobody
You might want to try a syncronizer kit, only if your looking to keep that transmission. Otherwise I would by another one.
Rexin24/7 is offline   Reply With Quote
Old 05-15-2007, 03:06 PM   #4 (permalink)
D-Series Post Be-itch... gimme gimme gimme
Rep Power: 13 Richie_A_19 is hot as a volcano
Richie_A_19 is hot as a volcanoRichie_A_19 is hot as a volcanoRichie_A_19 is hot as a volcanoRichie_A_19 is hot as a volcanoRichie_A_19 is hot as a volcanoRichie_A_19 is hot as a volcanoRichie_A_19 is hot as a volcanoRichie_A_19 is hot as a volcanoRichie_A_19 is hot as a volcanoRichie_A_19 is hot as a volcanoRichie_A_19 is hot as a volcanoRichie_A_19 is hot as a volcanoRichie_A_19 is hot as a volcanoRichie_A_19 is hot as a volcanoRichie_A_19 is hot as a volcano
When a syncro goes bad, the gear will end up going in, it will just sound like hell. The syncro is used for like .75 seconds DURING shifting. Once it is in gear, the syncro doesn't apply.
Also, if it feels like the gear is almost in, but the shifter is where it is supposed to be, syncro's aren't relevant.
Just a rule of thumb.
Richie_A_19 is offline   Reply With Quote
Old 05-15-2007, 03:13 PM   #5 (permalink)
Sorry, didnt mean to give any misleading info.
Old 05-15-2007, 03:45 PM   #6 (permalink)
It's all good... Just trying to help. Most people automatically say syncros when it comes to a tranny.
Old 05-15-2007, 06:07 PM   #7 (permalink)
FAMILY MEMBER #316
rattmann316's Avatar
Rep Power: 10 rattmann316 It's a JDM Star Bitches....
i will second this statement all day long
Sarah Chalke: Boner Material
http://images.dr3vil.com/files2/defa...halke17f6b.gif
New Whip: 94 DX Hatch w/ 64k original miles and no power steering.
Xbox Gamertag: Rattmann316
(if you tryin to get moked out in COD4)
rattmann316 is offline   Reply With Quote
Old 05-15-2007, 06:19 PM   #8 (permalink)
SLO SOHC's Avatar
Rep Power: 8 SLO SOHC  is accepted as part of the communitySLO SOHC  is accepted as part of the communitySLO SOHC  is accepted as part of the communitySLO SOHC  is accepted as part of the community
sounds like a bearing problem!
Maybe counter shaft bearing walked or something is broken!
SLO SOHC is offline   Reply With Quote
Old 05-15-2007, 07:26 PM   #9 (permalink)
I neither dread nor desire.
Rep Power: 60 transzex is on a level you can only DREAM about! ! !transzex is on a level you can only DREAM about! ! !transzex is on a level you can only DREAM about! ! !transzex is on a level you can only DREAM about! ! !
transzex is on a level you can only DREAM about! ! !transzex is on a level you can only DREAM about! ! !transzex is on a level you can only DREAM about! ! !transzex is on a level you can only DREAM about! ! !transzex is on a level you can only DREAM about! ! !transzex is on a level you can only DREAM about! ! !transzex is on a level you can only DREAM about! ! !transzex is on a level you can only DREAM about! ! !transzex is on a level you can only DREAM about! ! !
worse, countershaft outer BEARINGS.....it's not gonna be cheap to fix it either.
transzex is offline   Reply With Quote
Old 05-16-2007, 06:43 AM   #10 (permalink)
Hmm i dunno I still havent put in 5th gear to this day.....So how much am I looking to pay for a Repair . I think my 3rd is still there because when i put it in gear (3rd) and start the car it jumps.......And my 3rd gear was abused in the 1 month ive had it and i havent missed my 3rd either...
Old 05-19-2007, 02:27 PM   #11 (permalink)
Ok 3rd gear is gone how much am i look forward to for repairs?
Old 05-19-2007, 07:18 PM   #12 (permalink)
how deep is your wallet?
iconAll times are GMT -8. The time now is 12:57 AM. | Welcome to Forum, please register to access all of our features.
