ok well i got all the stuff i need for my transwap in my 98 ex. everything except for my trans. i was wondering if there was any tips tricks or hints to make this swap go a lil easier. and also is ther any bad after effects that will need to be taken care of after the swap is done
also here is my list o parts ive got, is there anything i missed? Pedal assy. Clutch master cylinder Clutch res. Clutch lines Clutch slave cylinder ES shifter bushings Shift linkage B&M short throw Type-R shift knob CTR shift boot 5 speed ECU (P2P) IACV pigtail IACV 5 speed intake manifold B18 throttle body 5 speed starter 5 speed long starter bolt 5 speed top bracket 5 speed front stabilizer Clutch FlywheelFlywheel and clutch bolts 5 speed transmission |
| Sponsored Links | |||
Advertisement | |||
#3 (permalink) |
To be honest, my list looks identical (minus the dressup stuff) and I dont really see anything that youre missing except fluids, something to cut the hole, and something to "weld" the metal on to keep the road heat from getting into the cabin.
your shift linkage does have a bitch pin right? |
Advertisement | |
