I just installed my 8.4lb flwheel,
changed my clutch to my used about 2000 miles oem exedy clutch I had,, now my clutch wont grab on 2nd,3rd & so on... does anybody have any reason why? or how? -my clutch i had on was almost gone.! the exedy clutch I had grabbed good before & still looks brand new... & really didnt notice a huge difference after switching flywheels... from stock 16lb to 8.4lb... difference was in 1st gear goes up pretty fast...but not like I thought it would...hops the wheels... --o yea...just an update. the clutch grabs only when at higher rpms shifting fast...
R.I.P boosted b8 ed Last edited by RandysSOHC; 04-15-2007 at 04:04 PM. |
| Sponsored Links | |||
Advertisement | |||
#2 (permalink) |
Clutch cable properly adjusted?
http://www.ipixelspot.com/files/6/burnoutsig.JPG My project car: Little Bastard 11.0@137 |
#3 (permalink) |
yea..I put it back to where it was..
(the feel of it)-freeplay I also adjusted it loose at times..& tighter at times..no luck..
R.I.P boosted b8 ed |
#4 (permalink) |
anybody?....
#6 (permalink) |
Inertia wouldn't cause it to not grip. I have a 8lb flywheel in my Accord and a 7lb in my Civic and if anything; it will just bog/shake more easily when shifting.
Did you clean the surface of the flywheel and PP when installing? PP tightened all the way? Throwout-bearing correctly on the clutch lever? Just throwing up ideas.
-Kevin N. E. 2005 Subaru Legacy GT wagon; v9 EJ207 (6spd soon!) 1988 Honda Civic hatchback; in limbo 1992 Honda Accord LX coupe Sign up for Groupon! Deals on resturaunts, stores, etc: http://www.groupon.com/r/uu16193153 |
#8 (permalink) | |
thanks for some responses, we just wiped the pp & flywheel down we tightened everything pretty dang tight...lol didnt change the throw-out bearing.which i need to,but didnt have one, I'm not sure what else it could be, it makes me wanna go back out & try it some more, im sooo tired thou... would I have to break-in the clutch again?....sort of somthing...? I dont see how..
#9 (permalink) |
Break-in implies that it's working
#10 (permalink) | |
do you or anyone else think it'll just break back in (sooner or later) without the brake cleaner mod?....lol
#11 (permalink) | |
I neither dread nor desire.
"step" aside.
What was the PP to clutch step dimensions of the old flywheel vs. the new one?
Mista Bone ![]() Quote:
#12 (permalink) | |
we sized the old clutch with the new one & they were the exact same,, same amount of fingers,,,/.. I just drove to work this morning & come back, its still doing it a little,...i guess alot.. I try a 1st to 2nd hard shift @ high rpm's....wont catch.. it also does it when going 2nd to 3rd, I have no problems yet taking off, which I dont like to dump the clutch launching, but I have spin'd & slowed down just to see, today I went on a small back road real quick & floored it reving to 7,000, then shifted real hard...lol grinded the tranny a bit.. but I did get a little pull on second to make it chirp, I took that shift out with my anger. ...but I was on small little bumps/hills, so it would make it kinda jump & wanna spin, I'm not having any luck & no clue, we busted my axel seal & were about to change that right now, after driving since yesterday leaking tranny fluid...dots even on my bumper, I love the flywheel thou, it kinda settled in today a little bit more,fell the grip on the clutch at lower rpms, I have a strange noise like my axel isnt all the way in, a clunk somtimes when I put it in reverse & start to take off, including some on take off/of a turn... were changing the axel seal today & hopfully someone or us,have any ideas or spot anything out that it could be from the outside of the tranny?// thanks for ideas & this thing is killing me, if you have any other ideas please let me know, I just dont really want to dig back in the clutch area.. -Randy
#13 (permalink) |
ok.....heres the FIX update,
we changed my axel seal which was leaking & now my clutch grabs 2nd 3rd & so on & has no clutch slippage.... I wonder how, my guess would be somthing with the axel not all the way in? (but I wouldnt think that would make the lutch act as if it was slipping) but its fixed anyway,clutch grabs every gear & the 8.4lb flywheel gets my vouch! definitley a night & day difference. thanks for the help guys!
Advertisement | |
