Obx Lsd - D-series.org
Old 08-20-2005, 09:37 PM   #1 (permalink)
jozzy
Default Obx Lsd
Any body in here use the obx lsd?? i hear they give problems can anybopdy elaborate?
Old 08-20-2005, 10:17 PM   #2 (permalink)
Neighborhood Asshole is Back!
00kickercivic's Avatar
Rep Power: 12 00kickercivic is about to kiss the sky
00kickercivic is about to kiss the sky00kickercivic is about to kiss the sky00kickercivic is about to kiss the sky00kickercivic is about to kiss the sky00kickercivic is about to kiss the sky00kickercivic is about to kiss the sky
do a search... there are several threads about this
93 Toyota Supra TT
13 Hyundai Genesis 2.0T
05 SeaDoo RXT
00kickercivic is offline   Reply With Quote
Old 08-21-2005, 12:58 PM   #3 (permalink)
Rep Power: 8 Jim Truett is learning the way of the DJim Truett is learning the way of the D
Here is my post from h-t:
Well, as I sit staring at my brand new Quaife that just came in from camp1320, I am reminded of the brand new OBX LSD that is installed in my tranny right now.
Here is my review of the OBX LSD:
It was .033" wider than the stock unit. The stock shim in the tranny was .057". Fine. So I need a .024" shim. I go to Honda, and what do I find? Their thinnest shim is 1mm, or .03937". Shit. Ok, custom machined shim time.
Now I have a .024" shim. Cool. Time to press on the bearings. Fuck!!!! The god damn diff bolts stick up so far that I can't press the bearing all of the way down on the ring gear side. I had to pull off the brand new carrier bearing, and remove all of the bolts that hold the diff together. I find that one of the counterbores for the bolts was not finish machined. Time to grind all of the bolt heads thinner for clearance.
Now the bearings are on, and It's time for the ring gear. You must be kidding. The OBX diff body is so much larger than the stock diff, that all of the ring gear bolts bind when they are tightened. Time to grind .020" off of the washer head of the ring gear bolts. Now with the thinnest wall Snap-On socket I could find, I was able to assemble the ring gear to the diff.
It's now in the tranny, and time to insert the axles. No problems.
First drive, what the hell? I just installed remanufactured axles, and it shudders badly under load. Ok, I've gotten bad axles before, so back to the parts store.
Came back with brand new axles. Normal installation, no problems.
Out on the road again, same shudder. I pull it into the driveway and jack it up. I can seriously move the axle cup within the diff .110", as measured with a dial indicator.
Basically the axle bores are tapered, or way out of tolerance. My OBX LSD is a piece of shit. Many people have great success with the B-Series unit, but the D-Series models are really fucked.
Yes, I will be pulling my tranny on Saturday and installing my new Quaife. I thought I could save $400 by going OBX, but now I have spent over $600 more considering I ended up purchasing two new sets of 80mm carrier bearings.
I put my new Quaife in yesterday, and it was worth the time/effort/expense.
Jim Truett is offline   Reply With Quote
Old 08-22-2005, 01:42 AM   #4 (permalink)
eg4
eg4's Avatar
Rep Power: 10 eg4 is a name known to alleg4 is a name known to alleg4 is a name known to alleg4 is a name known to alleg4 is a name known to alleg4 is a name known to alleg4 is a name known to alleg4 is a name known to alleg4 is a name known to all
most people are really happy with the obx lsd
current setup:
ported d16y8 head
AEM TRUTIME camgear
105300 cam
ferrea 20º Super Flo. 1 mm oversize valves
zex valve springs
Edelbrock Performer X
62mm TB
d16a6 block
76mm p29 pistons
walbro 255lph
100cel catalytic convertor
fidanza 7lbs flywheel
dc2 catback
comptech header
CROME tuned p28 ecu
12,5:1 cr
4,43FD
http://img143.imageshack.us/img143/6483/civicoi8.jpg
eg4 is offline   Reply With Quote
Old 08-22-2005, 02:25 PM   #5 (permalink)
jozzy
Jim Truett what trany did u put this in??
Old 08-22-2005, 02:34 PM   #6 (permalink)
MyblkVTEC's Avatar
Rep Power: 18 MyblkVTEC is the fucking MAN!!!!MyblkVTEC is the fucking MAN!!!!MyblkVTEC is the fucking MAN!!!!
hmmm I am gonna get a KAAZ I think.....
MyblkVTEC is offline   Reply With Quote
Old 08-22-2005, 06:43 PM   #7 (permalink)
JDM_EK3
Any other options for LSD?
Old 08-22-2005, 07:51 PM   #8 (permalink)
MyblkVTEC's Avatar
Quaife..... good shit from what Ive heard....
Old 08-22-2005, 08:31 PM   #9 (permalink)
rotory20's Avatar
Rep Power: 0 rotory20 is hot as a volcano
rotory20 is hot as a volcanorotory20 is hot as a volcanorotory20 is hot as a volcanorotory20 is hot as a volcanorotory20 is hot as a volcanorotory20 is hot as a volcanorotory20 is hot as a volcanorotory20 is hot as a volcanorotory20 is hot as a volcanorotory20 is hot as a volcanorotory20 is hot as a volcanorotory20 is hot as a volcano
if you have the money..
rotory20 is offline   Reply With Quote
Old 08-23-2005, 08:32 PM   #10 (permalink)
'95 EX trans. This would apply to any 40mm carrier bearing equipped tranny from '88-'00.
Old 08-23-2005, 08:33 PM   #11 (permalink)
Or just want to do it once and be done.
iconAll times are GMT -8. The time now is 08:56 AM. | Welcome to Forum, please register to access all of our features.
