D15 transmission wont fit on my D16 - D-series.org
Closed Thread
Old 07-23-2011, 10:07 AM   #1 (permalink)
Rep Power: 0 Kisune is nobody
Default D15 transmission wont fit on my D16
ok so dis is how it went i got a D16 swap but the transmission turned out to be bad ; ; so no si transmission for me :<
so now to get my car runing in the mean time i wanted to throw my old D15 trans on i have read Meny times dat dis is completly interchangalbe which im find its Not.... so what im thinking is happening is the clutch dont match up sence i bought a whole new clutch system for hte swap (stage 1)
so to clareify im asking am i just a idiot n cant get the transmission to line up right? or do i really ahve to change my clutch for dis?
88 ef
D16z6block
Y8 head
A6 intake mani distributor ecu
Kisune is offline   Quick reply to this message
Old 07-23-2011, 10:09 AM   #2 (permalink)
Never finishes (TWSS)
Evanguy's Avatar
Rep Power: 15 Evanguy is the fucking MAN!!!!Evanguy is the fucking MAN!!!!Evanguy is the fucking MAN!!!!
Evanguy is the fucking MAN!!!!Evanguy is the fucking MAN!!!!Evanguy is the fucking MAN!!!!Evanguy is the fucking MAN!!!!Evanguy is the fucking MAN!!!!Evanguy is the fucking MAN!!!!Evanguy is the fucking MAN!!!!Evanguy is the fucking MAN!!!!Evanguy is the fucking MAN!!!!Evanguy is the fucking MAN!!!!Evanguy is the fucking MAN!!!!Evanguy is the fucking MAN!!!!Evanguy is the fucking MAN!!!!Evanguy is the fucking MAN!!!!
Edit: i need to read more
but the tranny should bolt up just fine with out the clutch in there
d17y8 custom ITB's, NA HP build
homemade small IC engine
homemade alu rods pistons
Evanguy is offline   Quick reply to this message
Old 07-23-2011, 10:12 AM   #3 (permalink)
wheres my money man!!
sleepingciv's Avatar
Rep Power: 40 sleepingciv is on a level you can only DREAM about! ! !sleepingciv is on a level you can only DREAM about! ! !sleepingciv is on a level you can only DREAM about! ! !
sleepingciv is on a level you can only DREAM about! ! !sleepingciv is on a level you can only DREAM about! ! !sleepingciv is on a level you can only DREAM about! ! !sleepingciv is on a level you can only DREAM about! ! !sleepingciv is on a level you can only DREAM about! ! !sleepingciv is on a level you can only DREAM about! ! !sleepingciv is on a level you can only DREAM about! ! !sleepingciv is on a level you can only DREAM about! ! !sleepingciv is on a level you can only DREAM about! ! !sleepingciv is on a level you can only DREAM about! ! !sleepingciv is on a level you can only DREAM about! ! !sleepingciv is on a level you can only DREAM about! ! !sleepingciv is on a level you can only DREAM about! ! !
iTrader Score: 143 reviews
you need a 88 clutch and flywheel
d15 and d16 clutches and flywheels are the same as follows
1988 all same
1989 same flywheel size as 1988 but the 1989 uses a different spline clutch
1990-2000 all use same size clutch and flywheel
PM me for
also do tucked harnesses
sleepingciv is offline   Quick reply to this message
Old 07-23-2011, 10:52 AM   #4 (permalink)
Wischmaster's Avatar
Rep Power: 13 Wischmaster is hot as a volcanoWischmaster is hot as a volcano
Wischmaster is hot as a volcanoWischmaster is hot as a volcanoWischmaster is hot as a volcanoWischmaster is hot as a volcanoWischmaster is hot as a volcanoWischmaster is hot as a volcanoWischmaster is hot as a volcanoWischmaster is hot as a volcano
iTrader Score: 12 reviews
1988 all same
If you want to get technical, 1990-2005 are all the same.
God I love Honda for keeping things simple.
Wischmaster is offline   Quick reply to this message
Old 07-23-2011, 12:05 PM   #5 (permalink)
Thanks... so now i needs a new SI transmission ; ;
or get a D15clutch(my orignal one slipped hardcore)
it does bolt up could have got it bolted alot but couldnt get the stick in to the clutch cuz i bought my new clutch for a D16 sence i had found a Si transmission dat felt it worked in till i ran the engine for 20secs n i thought my engine was knocking turned out to be the transmission...
Old 07-23-2011, 12:06 PM   #6 (permalink)
it bolts up
but the d16 trans has 20 teeth on the shaft dat goes in to the block
n the D15 shaft has 21 teeth
i have read meny times of peeps putting d15's on the d16 but not one mentioned the clutch issue
Old 07-23-2011, 12:07 PM   #7 (permalink)
are you using the flywheel and clutch that came on the z6?
PM me for
Old 07-25-2011, 07:09 PM   #8 (permalink)
im using random d16 clutch sapost to fit all d16
well i got anther transmission its a 88 Si and its got the D15 shaft still ; ; so it changes from 88 to 89 i think i can see from parts numbers... but its prob the same in 88 89 n diff in 90 91
Old 07-25-2011, 09:35 PM   #9 (permalink)
OMG TOTALLY COOL TITLE!!!!
si-hatch86's Avatar
Rep Power: 28 si-hatch86 is on a level you can only DREAM about! ! !si-hatch86 is on a level you can only DREAM about! ! !si-hatch86 is on a level you can only DREAM about! ! !
iTrader Score: 15 reviews
89-00 have the same spline. 88 trans has a different one. so if your usings a "random d16" clutch you could have a d16a6 from a 88-00 need more specific year of clutch or just match the clutch to the trans and stop hassling with it all for nothing.
RIP Pat Primmer
RIP MILO
si-hatch86 is offline   Quick reply to this message
Old 07-25-2011, 09:44 PM   #10 (permalink)
Rep Power: 0 paulhonda22 is nobody
i just swaped out a d15 for a d16 useing the the stock d15 trans with the d16 flywheel clutch and pessure plate no problems the motor was out of 89 crx and it went into a 91 hatch
paulhonda22 is offline   Quick reply to this message
Old 07-25-2011, 10:33 PM   #11 (permalink)
cervan's Avatar
cervan is the fucking MAN!!!!cervan is the fucking MAN!!!!cervan is the fucking MAN!!!!cervan is the fucking MAN!!!!cervan is the fucking MAN!!!!cervan is the fucking MAN!!!!cervan is the fucking MAN!!!!cervan is the fucking MAN!!!!cervan is the fucking MAN!!!!cervan is the fucking MAN!!!!cervan is the fucking MAN!!!!cervan is the fucking MAN!!!!cervan is the fucking MAN!!!!
what year car did the tranny come out of?
-slams face on keyboard-
1990 crx - 12.2 @ 119mph Sold
cervan is online now   Quick reply to this message
Old 07-26-2011, 12:01 AM   #12 (permalink)
Rep Power: 100 transzex is on a level you can only DREAM about! ! !transzex is on a level you can only DREAM about! ! !
transzex is on a level you can only DREAM about! ! !transzex is on a level you can only DREAM about! ! !transzex is on a level you can only DREAM about! ! !transzex is on a level you can only DREAM about! ! !transzex is on a level you can only DREAM about! ! !transzex is on a level you can only DREAM about! ! !transzex is on a level you can only DREAM about! ! !transzex is on a level you can only DREAM about! ! !transzex is on a level you can only DREAM about! ! !transzex is on a level you can only DREAM about! ! !transzex is on a level you can only DREAM about! ! !transzex is on a level you can only DREAM about! ! !transzex is on a level you can only DREAM about! ! !transzex is on a level you can only DREAM about! ! !transzex is on a level you can only DREAM about! ! !
Time to retire, I give up.
transzex is offline   Quick reply to this message
Closed Thread
iconAll times are GMT -8. The time now is 09:22 AM. | Welcome to Forum, please register to access all of our features.
