Driving with slightly bent drive shaft cause any immediate damage to transmission? - D-series.org
Old 04-05-2011, 08:52 PM   #1 (permalink)
qqq
Rep Power: 7 qqq is nobody
Default Driving with slightly bent drive shaft cause any immediate damage to transmission?
can a "slightly" bent drive shaft cause immediate major damage ?
I am planning on having the drive shaft replaced within the next 5 days...If i drive lets say another 200kms on the slightly bent drive shaft, will this hurt anything inside my transmission?
I can hear the vibration of the driver side drive shaft, at 100km very evidently.
I just had my transmission replaced and it works like a charm, I just not informed enough to know if a bad drive shaft will harm my transmission if I drive on it for another 200 kms or so...
I am aware that the drive shaft will prematurely damage wheel bearings...
My main question is this, how much leeway in terms of regular daily driving do i have with a slightly bent drive shaft? Before it actually starts to break down other related parts prematurely?
qqq is offline   Reply With Quote Quick reply to this message
Old 04-05-2011, 09:08 PM   #2 (permalink)
a5hatch's Avatar
Rep Power: 12 a5hatch is hot as a volcanoa5hatch is hot as a volcano
depends on how badly its bent....
But I would suggest NOT DRIVING IT AT ALL
Is the car RWD? or are you talking about an axle on FWD transmission?
Either way it will probably destroy the output seal of the transmission/axle seal. Probably do damage to the input seal of the pinion if it has a rear diff.
It could quite possibly do damage to the casing, and possibly gearing inside as well if its the bend is putting any pressure at odd angles into the trans.
as soon as you drive it like this, it will start wearing other components prematurely. HOw much you drive it, will determine how fast they fail.
if you expect 5 days, just bum rides for 5 days till you fix it. Cant hurt to wait, but not waiting can definitely hurt
D16B Turbo
377WHP 292Lbs TQ
Sir, how the eff do you rebuild oil?
a5hatch is offline   Reply With Quote Quick reply to this message
Old 04-05-2011, 09:10 PM   #3 (permalink)
wheres my money man!!
sleepingciv's Avatar
Rep Power: 40 sleepingciv is on a level you can only DREAM about! ! !sleepingciv is on a level you can only DREAM about! ! !sleepingciv is on a level you can only DREAM about! ! !
sleepingciv is on a level you can only DREAM about! ! !sleepingciv is on a level you can only DREAM about! ! !sleepingciv is on a level you can only DREAM about! ! !sleepingciv is on a level you can only DREAM about! ! !sleepingciv is on a level you can only DREAM about! ! !sleepingciv is on a level you can only DREAM about! ! !sleepingciv is on a level you can only DREAM about! ! !sleepingciv is on a level you can only DREAM about! ! !sleepingciv is on a level you can only DREAM about! ! !sleepingciv is on a level you can only DREAM about! ! !sleepingciv is on a level you can only DREAM about! ! !sleepingciv is on a level you can only DREAM about! ! !sleepingciv is on a level you can only DREAM about! ! !
iTrader Score: 143 reviews
ya better safe then sorry
PM me for
also do tucked harnesses
sleepingciv is offline   Reply With Quote Quick reply to this message
Old 04-05-2011, 09:10 PM   #4 (permalink)
Sentry's Avatar
Rep Power: 16 Sentry is the fucking MAN!!!!Sentry is the fucking MAN!!!!Sentry is the fucking MAN!!!!
Sentry is the fucking MAN!!!!Sentry is the fucking MAN!!!!Sentry is the fucking MAN!!!!Sentry is the fucking MAN!!!!
Keep it to one thread bud
Sentry is offline   Reply With Quote Quick reply to this message
Old 04-05-2011, 09:30 PM   #5 (permalink)
qqq
other thread was closed..
Old 04-05-2011, 09:31 PM   #6 (permalink)
qqq
Its a civic
Old 04-05-2011, 11:19 PM   #7 (permalink)
Rep Power: 100 transzex is on a level you can only DREAM about! ! !transzex is on a level you can only DREAM about! ! !transzex is on a level you can only DREAM about! ! !
transzex is on a level you can only DREAM about! ! !transzex is on a level you can only DREAM about! ! !transzex is on a level you can only DREAM about! ! !transzex is on a level you can only DREAM about! ! !transzex is on a level you can only DREAM about! ! !transzex is on a level you can only DREAM about! ! !transzex is on a level you can only DREAM about! ! !
You're gonna DIE driving this deathtrap!
Old 04-05-2011, 11:26 PM   #8 (permalink)
Anonymoussquid's Avatar
Rep Power: 11 Anonymoussquid is about to blow upAnonymoussquid is about to blow upAnonymoussquid is about to blow upAnonymoussquid is about to blow upAnonymoussquid is about to blow upAnonymoussquid is about to blow upAnonymoussquid is about to blow upAnonymoussquid is about to blow upAnonymoussquid is about to blow upAnonymoussquid is about to blow upAnonymoussquid is about to blow upAnonymoussquid is about to blow upAnonymoussquid is about to blow upAnonymoussquid is about to blow up
iTrader Score: 27 reviews
A bent driveshaft can;
Wear out U joints,
Destroy bearings, be it rear end or transmission.
Pinion gears may also be damaged.
Drive shafts aren't constant velocity, they change speed as the rotate, they speed up twice and slow down twice per revolution due to the U joints. the bend can throw this out of wake causing vibration. Vibration kills bearings etc.
271 WHP/ 235tq 14 psi.
other DD 1995 Toyota Tacoma 3 inch lift 33x12.5 toyo M/T tires
On my way to my AA in Diesel technology
Anonymoussquid is offline   Reply With Quote Quick reply to this message
Old 04-06-2011, 12:01 AM   #9 (permalink)
Sentry's Avatar
THIS THREAD.
Noise at 3k rpm only when car is driving
THE THREAD YOU MADE OTHER THREADS ABOUT
Old 04-06-2011, 12:07 AM   #10 (permalink)
a5hatch's Avatar
Wear out U joints,
This, EXACTLY THIS
D16B Turbo
377WHP 292Lbs TQ
Old 04-06-2011, 04:08 AM   #11 (permalink)
patprimmer's Avatar
Front wheel drive drive shafts work at an angle at each end. That is why there are CV and tripod joints. A bent shaft simply changes that angle as the shaft rotates and also runs out of balance. It depends on how bad it is bent, but it will do as much damage or not as a similar out of balance tyre.
How it got bent and what other damaged may have occured then is more of an issue.
Regards
Pat. RIP Feb 22, 2013.
my CRX thread
my intro
Old 04-06-2011, 04:50 AM   #12 (permalink)
qqq
I am assuming its bent because when I looked under the car while it was up on a hoist running the mechanic pointed out that the drive shaft had a slight out of norm rotation (wobble) at the tire end of the drive shaft.
Old 04-06-2011, 05:13 AM   #13 (permalink)
patprimmer's Avatar
To be honest I doubt it is bent. A CV or a tripod may be on the way out.
Regards
my CRX thread
my intro
Old 04-06-2011, 08:11 AM   #14 (permalink)
qqq
oh ok =)
well if i replace the whole drive shaft that will cover the CV right?
tripod you mean control arm?
Old 04-06-2011, 08:31 AM   #15 (permalink)
Sentry's Avatar
Inner joint.
Old 04-06-2011, 10:35 AM   #16 (permalink)
Rep Power: 9 bake82 is da #1 stunnabake82 is da #1 stunnabake82 is da #1 stunnabake82 is da #1 stunnabake82 is da #1 stunnabake82 is da #1 stunnabake82 is da #1 stunna
oh ok =)
yes. replace the drive shaft and you'll be good to go. Keep the old one and return it to the store as a core.
bake82 is offline   Reply With Quote Quick reply to this message
Old 04-06-2011, 11:35 AM   #17 (permalink)
BLK92_D16's Avatar
Rep Power: 27 BLK92_D16 Still a JDM Star....
iTrader Score: 78 reviews
It is a half-shaft, not a drive shaft on a Honda Civic.
Just replace the half shaft...like $50-60 plus labor.
Old 04-06-2011, 03:47 PM   #18 (permalink)
qqq
Thank you ladies and gentlemen for your contribution.
Car will be parked until monday.
Hopefully me driving on it already for 400kms has not done any dmg. Thankfully of those 400kms more than half were inner city under 100kms.. It wasnt until I reached 100km that was the tell tail sign something was wrong... I only drove about 150km on hi way at around 100 to 120kms. I hope my transmission is not fooked up =*(
Old 04-06-2011, 04:47 PM   #19 (permalink)
cervan's Avatar
cervan is the fucking MAN!!!!cervan is the fucking MAN!!!!cervan is the fucking MAN!!!!cervan is the fucking MAN!!!!cervan is the fucking MAN!!!!cervan is the fucking MAN!!!!cervan is the fucking MAN!!!!cervan is the fucking MAN!!!!cervan is the fucking MAN!!!!cervan is the fucking MAN!!!!cervan is the fucking MAN!!!!cervan is the fucking MAN!!!!cervan is the fucking MAN!!!!
i hope you drive it and it goes through your heart so you cant make any more useless threads like this EVER AGAIN.
1990 crx - 12.2 @ 119mph Sold
Old 04-06-2011, 04:49 PM   #20 (permalink)
OMG TOTALLY COOL TITLE!!!!
si-hatch86's Avatar
Rep Power: 28 si-hatch86 is on a level you can only DREAM about! ! !si-hatch86 is on a level you can only DREAM about! ! !si-hatch86 is on a level you can only DREAM about! ! !
iTrader Score: 15 reviews
lol
RIP Pat Primmer
RIP MILO
si-hatch86 is offline   Reply With Quote Quick reply to this message
iconAll times are GMT -8. The time now is 03:15 PM. | Welcome to Forum, please register to access all of our features.
