Replaced My Clutch-Now My Speedometer Doesnt Work - D-series.org
Old 02-13-2010, 01:39 AM   #1 (permalink)
Rep Power: 9 TURBOB20 is almost a somebodyTURBOB20 is almost a somebodyTURBOB20 is almost a somebodyTURBOB20 is almost a somebody
iTrader Score: 22 reviews
Default Replaced My Clutch-Now My Speedometer Doesnt Work
I have a 1990 civic hatch with a D15b1 motor. Has 197,000 miles on it. I swapped it to a 1990 Civic Si 5 speed from a 4 speed manual and replaced the clutch as well. Everything worked fine.
The Issue:
It ended up first having a defective clutch- had to replace it again. I put it back together and now I dont have a speedometer. Tachometer works though(swapped to Si cluster as well.)
What is causing this? Speedometer cable not hooked up right? Does it have to be inserted a certain way?
Thanks in Advance
1995 Ford Taurus SHO-FOR SALE
1995 corvette- lt-1 6 speed-long tubes, 1.6 RR. Tuned
1993 civic hatch-dd#2
TURBOB20 is offline   Reply With Quote Quick reply to this message
Old 02-13-2010, 02:35 AM   #2 (permalink)
jmn822000's Avatar
Rep Power: 18 jmn822000 is the fucking MAN!!!!jmn822000 is the fucking MAN!!!!jmn822000 is the fucking MAN!!!!
jmn822000 is the fucking MAN!!!!jmn822000 is the fucking MAN!!!!jmn822000 is the fucking MAN!!!!jmn822000 is the fucking MAN!!!!jmn822000 is the fucking MAN!!!!jmn822000 is the fucking MAN!!!!jmn822000 is the fucking MAN!!!!jmn822000 is the fucking MAN!!!!jmn822000 is the fucking MAN!!!!jmn822000 is the fucking MAN!!!!jmn822000 is the fucking MAN!!!!jmn822000 is the fucking MAN!!!!jmn822000 is the fucking MAN!!!!jmn822000 is the fucking MAN!!!!jmn822000 is the fucking MAN!!!!
is the sensor plugged in?
1994 EH9 RIP -- 1992 BB2 RIP -- 1992 CB7 RIP
2004 Ram 1500 QCSB Hemi
jmn822000 is offline   Reply With Quote Quick reply to this message
Old 02-13-2010, 03:21 AM   #3 (permalink)
99EJ6T's Avatar
Rep Power: 42 99EJ6T is on a level you can only DREAM about! ! !99EJ6T is on a level you can only DREAM about! ! !99EJ6T is on a level you can only DREAM about! ! !
iTrader Score: 32 reviews
two things..
1) are the plugs (including the cable from the VSS) to the cluster all plugged in?
2) is the input end of the cable fully inserted into the "VSS"?
after that, its probably an issue with the cluster. the cluster in your car has a direct link to the trans diff via the cable. if the cable is fully installed (correctly), then the needle should move as speed increases.
Old 02-13-2010, 05:26 AM   #4 (permalink)
Rep Power: 100 transzex is on a level you can only DREAM about! ! !transzex is on a level you can only DREAM about! ! !
transzex is on a level you can only DREAM about! ! !transzex is on a level you can only DREAM about! ! !transzex is on a level you can only DREAM about! ! !transzex is on a level you can only DREAM about! ! !transzex is on a level you can only DREAM about! ! !transzex is on a level you can only DREAM about! ! !transzex is on a level you can only DREAM about! ! !transzex is on a level you can only DREAM about! ! !transzex is on a level you can only DREAM about! ! !transzex is on a level you can only DREAM about! ! !transzex is on a level you can only DREAM about! ! !transzex is on a level you can only DREAM about! ! !transzex is on a level you can only DREAM about! ! !transzex is on a level you can only DREAM about! ! !transzex is on a level you can only DREAM about! ! !
cable.
Old 02-13-2010, 05:31 AM   #5 (permalink)
patprimmer's Avatar
Like bone says, cable
Regards
Pat. RIP Feb 22, 2013.
my CRX thread
my intro
Old 02-13-2010, 09:07 AM   #6 (permalink)
Originally Posted by 99EJ6T View Post
two things..
Is there any special way it inserts into the transmission? I checked the cluster and it is hooked up there.
It worked fine the first time about 3 months ago, but this time when I tried hooking it up the speedometer wasnt working.
I know that after driving for a few minutes the check engine light comes on due to the speedometer not working if that helps any
Old 02-13-2010, 09:09 AM   #7 (permalink)
Default re
Originally Posted by transzex View Post
cable.
Do you think it needs replaced or it just isnt hooked up right? I dont think the cable is inserting all the way into the transmission. But I cant figure out why.
I assume the brass colored portion should be flush all the way into the transmission? correct?
Old 02-13-2010, 09:09 AM   #8 (permalink)
Rep Power: 441 ryan89crx is on a level you can only DREAM about! ! !ryan89crx is on a level you can only DREAM about! ! !ryan89crx is on a level you can only DREAM about! ! !ryan89crx is on a level you can only DREAM about! ! !ryan89crx is on a level you can only DREAM about! ! !ryan89crx is on a level you can only DREAM about! ! !ryan89crx is on a level you can only DREAM about! ! !ryan89crx is on a level you can only DREAM about! ! !ryan89crx is on a level you can only DREAM about! ! !ryan89crx is on a level you can only DREAM about! ! !ryan89crx is on a level you can only DREAM about! ! !ryan89crx is on a level you can only DREAM about! ! !ryan89crx is on a level you can only DREAM about! ! !ryan89crx is on a level you can only DREAM about! ! !ryan89crx is on a level you can only DREAM about! ! !
Cable isn't in the trans all the way
12.87@109mph
Old 02-13-2010, 09:15 AM   #9 (permalink)
bman200437's Avatar
Rep Power: 10 bman200437 It's a JDM Star Bitches....
bman200437 It's a JDM Star Bitches....bman200437 It's a JDM Star Bitches....bman200437 It's a JDM Star Bitches....bman200437 It's a JDM Star Bitches....bman200437 It's a JDM Star Bitches....
iTrader Score: 25 reviews
Im going to say that the cable isnt seated into the trans right OR when you pulled the trans you pinched the cable and it has snapped internally...there is NO electronics involved with the speedo other than the lights that illumiate it..unless you have upgraded the ecu and harness.. i have seen spedo cables on egay for about $30 if you need a new one...
Horsepower is not rated by how hard you hit the wall its rated
by how much you moved the wall when you hit it..(unkown)
88 civic standard hatch (R.I.P.)
90 civic dx hatch
You definetly have a tranny issue and not the kind that makes you want to put on lipstick and womens clothing.
first love= honda
second love=hand
third=girl!
bman200437 is offline   Reply With Quote Quick reply to this message
Old 02-13-2010, 09:17 AM   #10 (permalink)
Is there any way it needs to seat into the tranny? like how far down in is all the way?
Old 02-13-2010, 09:19 AM   #11 (permalink)
Well that good at least they cheap. lol. I am going to continue looking into it. But yeah I think the cable hopefully just isnt seating in all the way
Old 02-13-2010, 09:20 AM   #12 (permalink)
bman200437's Avatar
there is a small U-shaped clip that will only clip in if its seated all the way down. if i remeber right the "brass-colored" portion should be all the way down
90 civic dx hatch
first love= honda
second love=hand
third=girl!
Old 02-13-2010, 09:37 AM   #13 (permalink)
Ok, that makes alot of sense now. That is what I was thinking. I will have to keep trying. lol that clip is being quite a pain to get in there
Old 02-13-2010, 12:56 PM   #14 (permalink)
\/Your Mom Was Here\/
BeerDrinkin's Avatar
Rep Power: 46 BeerDrinkin is on a level you can only DREAM about! ! !BeerDrinkin is on a level you can only DREAM about! ! !BeerDrinkin is on a level you can only DREAM about! ! !BeerDrinkin is on a level you can only DREAM about! ! !
BeerDrinkin is on a level you can only DREAM about! ! !BeerDrinkin is on a level you can only DREAM about! ! !BeerDrinkin is on a level you can only DREAM about! ! !BeerDrinkin is on a level you can only DREAM about! ! !BeerDrinkin is on a level you can only DREAM about! ! !
disconnect the speedo cable at the transmission end and attach it to a drill and see if it starts to work then (it may be the gears that drive the speedo cable). if it works then you have a speedo gear problem or your not seating the cable properly. If it doesnt work you either havent connected it properly to the speedo cluster, or the cable could be busted/broke. Was the speedo jumpy/jerky at all before this happened, if so it was cable going bad.
Hope this helps a little
2005 Civic EX Sedan (ES2)
Old 02-13-2010, 01:05 PM   #15 (permalink)
99EJ6T's Avatar
yes and no. yes, the gears are driven mechanically. however, the cluster sends an electronic signal back to the ecu. even when you upgrade to obd1 management, you still keep the cable speedo.
Old 02-13-2010, 02:03 PM   #16 (permalink)
Live,love,laugh,be real
4Door's Avatar
Rep Power: 36 4Door is on a level you can only DREAM about! ! !4Door is on a level you can only DREAM about! ! !
4Door is on a level you can only DREAM about! ! !4Door is on a level you can only DREAM about! ! !4Door is on a level you can only DREAM about! ! !4Door is on a level you can only DREAM about! ! !4Door is on a level you can only DREAM about! ! !4Door is on a level you can only DREAM about! ! !4Door is on a level you can only DREAM about! ! !
iTrader Score: 20 reviews
you should be able to test the cable by pulling it out of the trans and hooking a drill up to it and spinning it in reverse/forward, it should read a speed on the cluster if its good...
R.I.P. my mom - I miss you
10/3/1945-6/16/2007
R.I.P. - MiloReaper & Pat Primmer
96' CE1 Lx - Wags
04' Pilot EXL - Black Pile - Love it
is your friend, try it
[youtube ][ /youtube]
4Door is offline   Reply With Quote Quick reply to this message
Old 02-13-2010, 03:49 PM   #17 (permalink)
Rep Power: 50 FarmerD is on a level you can only DREAM about! ! !FarmerD is on a level you can only DREAM about! ! !FarmerD is on a level you can only DREAM about! ! !FarmerD is on a level you can only DREAM about! ! !
FarmerD is on a level you can only DREAM about! ! !FarmerD is on a level you can only DREAM about! ! !FarmerD is on a level you can only DREAM about! ! !FarmerD is on a level you can only DREAM about! ! !FarmerD is on a level you can only DREAM about! ! !FarmerD is on a level you can only DREAM about! ! !FarmerD is on a level you can only DREAM about! ! !FarmerD is on a level you can only DREAM about! ! !FarmerD is on a level you can only DREAM about! ! !FarmerD is on a level you can only DREAM about! ! !FarmerD is on a level you can only DREAM about! ! !FarmerD is on a level you can only DREAM about! ! !FarmerD is on a level you can only DREAM about! ! !FarmerD is on a level you can only DREAM about! ! !
jam that fucker into the tranny. sometimes they are a bit of a reverse slut, and are a trick to penetrate.
Old 02-14-2010, 12:36 AM   #18 (permalink)
I will definitely be trying to do that. I can see that now. it is also ina shitty area to work with if you have big hands as well.
I am also going to try the drill method to test as well.
Old 02-14-2010, 12:39 AM   #19 (permalink)
Not really jumpy or anything. worked great until this time. But Iknow it is at least not seated right for sure too. I will drill test it first. if it works, then I will try danz method of forcing it in.
Old 02-14-2010, 04:59 PM   #20 (permalink)
the one on my 1990 cx is tricky.. sometimes it goes right in, and sometimes it takes a little coercion.
iconAll times are GMT -8. The time now is 09:22 AM. | Welcome to Forum, please register to access all of our features.
