accord radious rods to adjust caster - D-series.org
Old 11-03-2007, 08:28 PM   #1 (permalink)
guest's Avatar
Rep Power: 21 guest is hot as a volcanoguest is hot as a volcano
iTrader Score: 46 reviews
Default accord radious rods to adjust caster
I read this on h-t, but no one answered if they've tried it or not. I have access to an alignment machine and it would be sick to dial all my shit in. I have a 89 dx.
XP4EVER
Old 11-03-2007, 09:53 PM   #2 (permalink)
K2e2vin's Avatar
Rep Power: 15 K2e2vin It's a JDM Star Bitches....
What's the difference except maybe length?
-Kevin N. E.
1992 Honda Accord LX coupe
K2e2vin is offline   Reply With Quote Quick reply to this message
Old 11-04-2007, 07:09 AM   #3 (permalink)
guest's Avatar
I believe there threaded so you can actually adjust caster.
XP4EVER
Old 11-04-2007, 03:08 PM   #4 (permalink)
D-series Champ
4drturboD's Avatar
Rep Power: 13 4drturboD is approaching greatness4drturboD is approaching greatness4drturboD is approaching greatness4drturboD is approaching greatness4drturboD is approaching greatness4drturboD is approaching greatness4drturboD is approaching greatness4drturboD is approaching greatness4drturboD is approaching greatness4drturboD is approaching greatness4drturboD is approaching greatness4drturboD is approaching greatness4drturboD is approaching greatness
I wouldn't imagine there would end up being that much usable adjustment, if you're talking about the rods that go from the front lower sub frame to the lower control arms. If you shorten or lengthen those rods it will pull your lca's out of alignment with the uppers, which will most likely inhibit your suspension travel by distorting your lca bushings and creating binding while also creating unpredictable camber on turns due too the unknown effect it will have on the travel of your upper control arms. exaggerated caster adjustments are really only effective on full race cars and cars with macpherson strut setups as opposed to the double wishbone setup. the macpherson setup does not generally create as much camber in turns as the double wishbone and is more prone to understeer for that reason. sorry that got a bit long.
the only constant in the tuning world is the female reaction to the cost of car parts!
this pic is so old
4drturboD is offline   Reply With Quote Quick reply to this message
Old 11-04-2007, 03:27 PM   #5 (permalink)
guest's Avatar
o yeah..... I'm really a noob when it comes to suspension, other then being able to use an alignment machine. Actually I dont even think I checked my caster. But a 93 prelude caster is off when put on the machine. my camber is off still so I figured get a camber kit and this if my caster is off (need to check).
so you say dont even fuck with it.
XP4EVER
Old 11-04-2007, 04:01 PM   #6 (permalink)
D-series Champ
4drturboD's Avatar
basically, it's just gonna cause unwanted problems
this pic is so old
Old 11-04-2007, 04:29 PM   #7 (permalink)
Resident Crab
krychek57's Avatar
Rep Power: 50 krychek57 is on a level you can only DREAM about! ! !krychek57 is on a level you can only DREAM about! ! !krychek57 is on a level you can only DREAM about! ! !krychek57 is on a level you can only DREAM about! ! !krychek57 is on a level you can only DREAM about! ! !
krychek57 is on a level you can only DREAM about! ! !krychek57 is on a level you can only DREAM about! ! !krychek57 is on a level you can only DREAM about! ! !krychek57 is on a level you can only DREAM about! ! !krychek57 is on a level you can only DREAM about! ! !krychek57 is on a level you can only DREAM about! ! !krychek57 is on a level you can only DREAM about! ! !krychek57 is on a level you can only DREAM about! ! !krychek57 is on a level you can only DREAM about! ! !krychek57 is on a level you can only DREAM about! ! !krychek57 is on a level you can only DREAM about! ! !
iTrader Score: 32 reviews
What?
Being able to adjust caster is never a bad thing, but as you mentioned you need to adjust the UCA's to match. With the right camber kit, this can be done.
krychek57 is offline   Reply With Quote Quick reply to this message
Old 11-04-2007, 05:19 PM   #8 (permalink)
D-series Champ
4drturboD's Avatar
Originally Posted by krychek57 View Post
What?
i never meant to say it was a bad thing. it's just more complicated than changing the rod length, and in this case probably not really necessary unless he's racing the car. i never said don't do it, only that just doing the rod adjustments wouldn't guarantee a positive effect. just wanted to put my thoughts out there. could have been more specific but i felt long winded.
this pic is so old
Old 11-04-2007, 05:28 PM   #9 (permalink)
guest's Avatar
it's not going to be raced.
I have access to adjust camber before and after, as well as tie rods according to the alignment rack. what do you mean the right camber kit? the ebay ones with 1.25 to 3 pos. wont work.
I'm jumping the gun. I need to check if its even off first.
XP4EVER
iconAll times are GMT -8. The time now is 04:09 PM. | Welcome to Forum, please register to access all of our features.
