What happens if your upper ball joint gives out? - D-series.org
Old 02-10-2011, 02:29 PM   #1 (permalink)
takiniteasy's Avatar
Rep Power: 7 takiniteasy is nobody
Default What happens if your upper ball joint gives out?
my upper ball joint on the driver side is squeaking like a mofo, whenever i slow down or go over a bump. What happens if i put it off for a bit? i'm gonna have to sell some shit to get that 100 bucks for the replacement upper control arm (why dont they sell the upper ball joint seperate???).
And will i have to get a new alignment after i replace the upper control arm?
i've tried reading around, but all i find are guides and stories on the lower ball joints.
takiniteasy is offline   Reply With Quote Quick reply to this message
Old 02-10-2011, 02:35 PM   #2 (permalink)
patprimmer's Avatar
You will need an alignment.
Can you get a second hand one cheaper.
If it fully fails the wheel will lay over and the chassis will hit the ground. Wheel, tyre and body will all potentially be seriously damaged, and that is without actually considering other damaged to property and persons caused by loss of control.
Regards
Pat. RIP Feb 22, 2013.
my CRX thread
my intro
Old 02-10-2011, 02:48 PM   #3 (permalink)
Rep Power: 100 transzex is on a level you can only DREAM about! ! !transzex is on a level you can only DREAM about! ! !transzex is on a level you can only DREAM about! ! !
transzex is on a level you can only DREAM about! ! !transzex is on a level you can only DREAM about! ! !transzex is on a level you can only DREAM about! ! !transzex is on a level you can only DREAM about! ! !transzex is on a level you can only DREAM about! ! !transzex is on a level you can only DREAM about! ! !transzex is on a level you can only DREAM about! ! !
Ebay, pair of arms is like $70.
Lube well.
Also I'll bet money its not the ball joint.
Some white litium grease will prove this.
Old 02-10-2011, 02:51 PM   #4 (permalink)
Lube well.
where do i apply the grease? and i'm pretty sure its coming from the upper ball joint, i took the tire off, took out that long bolt that goes through the LCA and the knuckle, and pushed the knuckle down several times, and i could hear that the squeaking was coming from up top near the ball joint.
Old 02-10-2011, 02:52 PM   #5 (permalink)
bushings
Old 02-10-2011, 02:54 PM   #6 (permalink)
patprimmer's Avatar
Are you sure the noise is not coming from the shock or spring seat areas.
Regards
my CRX thread
my intro
Old 02-10-2011, 02:57 PM   #7 (permalink)
ya, when i was pushing on the knuckle, the shocks/spring seat werent connected and were stationary the whole time.
Old 02-10-2011, 03:02 PM   #8 (permalink)
Rep Power: 50 FarmerD is on a level you can only DREAM about! ! !FarmerD is on a level you can only DREAM about! ! !FarmerD is on a level you can only DREAM about! ! !FarmerD is on a level you can only DREAM about! ! !
FarmerD is on a level you can only DREAM about! ! !FarmerD is on a level you can only DREAM about! ! !FarmerD is on a level you can only DREAM about! ! !FarmerD is on a level you can only DREAM about! ! !FarmerD is on a level you can only DREAM about! ! !FarmerD is on a level you can only DREAM about! ! !FarmerD is on a level you can only DREAM about! ! !FarmerD is on a level you can only DREAM about! ! !FarmerD is on a level you can only DREAM about! ! !FarmerD is on a level you can only DREAM about! ! !FarmerD is on a level you can only DREAM about! ! !FarmerD is on a level you can only DREAM about! ! !FarmerD is on a level you can only DREAM about! ! !FarmerD is on a level you can only DREAM about! ! !FarmerD is on a level you can only DREAM about! ! !
something like this happens when it finally lets loose....
Old 02-10-2011, 03:05 PM   #9 (permalink)
ya, i saw that, but wasnt that actually the lower ball joint (which ive replaced recently)?
And when you replace your Upper ball joints, do you just go with the whole control arm set up? or do you replace the balljoints themselves? i konw its harder to find the joints themselves, perhaps due to the fact that its difficult to install them, but what are your thoughts on it?
Old 02-10-2011, 03:13 PM   #10 (permalink)
qweakers's Avatar
Rep Power: 10 qweakers is obviously a regularqweakers is obviously a regularqweakers is obviously a regularqweakers is obviously a regularqweakers is obviously a regularqweakers is obviously a regularqweakers is obviously a regularqweakers is obviously a regular
iTrader Score: 56 reviews
what car is it? i know the 88-89 ef chasis you had to do the whole arm, 90-91 you can just get the ball joint.
90 crx dx no heart
88 crx dx (future drag whore)
88 crx si (stock)
88 crx si y-49
93 ACURA INTEGRA LS
93 civic cx, poor mans type r, stroked, jrsc (coming soon)
qweakers is offline   Reply With Quote Quick reply to this message
Old 02-10-2011, 03:25 PM   #11 (permalink)
bushings
wow, you're good, i removed the shock/strut to get a better listen, and discovered that its coming from the bushing closer to the front of the car, so do i just put lithium grease all over it? or can i unbolt the UCA from the chassis, unbolt the 14mm bolt and nut and put the grease in there? will that screw up my alignment?
Its a 96 teg, which would be the same as a 92-95 civic right?
Old 02-10-2011, 03:30 PM   #12 (permalink)
Formally known as SPONSOREDCRX
ESD_DA9's Avatar
Rep Power: 18 ESD_DA9 is hot as a volcanoESD_DA9 is hot as a volcano
ESD_DA9 is hot as a volcanoESD_DA9 is hot as a volcanoESD_DA9 is hot as a volcanoESD_DA9 is hot as a volcanoESD_DA9 is hot as a volcanoESD_DA9 is hot as a volcanoESD_DA9 is hot as a volcanoESD_DA9 is hot as a volcano
iTrader Score: 27 reviews
That looks more like the "i forgot to put a cotter pin back in my lca" accident. lol
1991 CRX Si (Traded) It will definitely be missed
1990 Integra LS (Traded) 09-2014
1997 Civic DX
2003 Dodge Durango 4WD
most of mans motivation is motivated by...vag or money and the only reason we care about money is cause we can use it to get...vag
My mom came into my room and thought i was watching porn because i was stroking myself to your car!
ESD_DA9 is offline   Reply With Quote Quick reply to this message
Old 02-10-2011, 03:33 PM   #13 (permalink)
damn, while i was checkin things out, i noticed my bellows boot is fucked
How difficult is that to replace? i've heard the clamp on the inside is a bitch to get to.
Has anyone done this before?
Old 02-10-2011, 03:50 PM   #14 (permalink)
patprimmer's Avatar
Yes.
The hardest part is getting the half shaft out and the CVs off it and everything marked so they go back exactly the same.
Regards
my CRX thread
my intro
Old 02-10-2011, 04:01 PM   #15 (permalink)
qweakers's Avatar
quick autoparts lookup show you can go either way
90 crx dx no heart
88 crx si (stock)
88 crx si y-49
93 ACURA INTEGRA LS
Old 02-10-2011, 05:12 PM   #16 (permalink)
BLK92_D16's Avatar
Rep Power: 27 BLK92_D16 Still a JDM Star....
iTrader Score: 78 reviews
Mine has looked like that for 2 yrs+, never an issue.
Old 02-10-2011, 05:17 PM   #17 (permalink)
patprimmer's Avatar
If grease comes out, dirt and water gets in. It might not be instant death to the parts, but it sure as hell increases rates of wear and reduces life.
Regards
my CRX thread
my intro
Old 02-10-2011, 06:35 PM   #18 (permalink)
90dirtydsi's Avatar
Rep Power: 10 90dirtydsi It's a JDM Star Bitches....
90dirtydsi It's a JDM Star Bitches....90dirtydsi It's a JDM Star Bitches....
Hardest part is taking the outer tie rod off of the inner tie rod. be warned, the below is quite expensive.
94 Civic Sedan - shooting for 11.99 at full weight
Rocket cams
Injector Nation
RIP
90dirtydsi is offline   Reply With Quote Quick reply to this message
Old 02-10-2011, 06:40 PM   #19 (permalink)
OMG TOTALLY COOL TITLE!!!!
si-hatch86's Avatar
Rep Power: 28 si-hatch86 is on a level you can only DREAM about! ! !si-hatch86 is on a level you can only DREAM about! ! !si-hatch86 is on a level you can only DREAM about! ! !
iTrader Score: 15 reviews
not sure bout others but all 5 of my ed chassis cars that ive replaced the outter tie rods on came off with ease
RIP Pat Primmer
RIP MILO
si-hatch86 is offline   Reply With Quote Quick reply to this message
Old 02-11-2011, 12:06 AM   #20 (permalink)
Instead of messing with the bellow, save you pennies up and buy a reman rack. If the bellow is like that inner joint will be toast.
I just bought a reman 90-91 PS rack for $189 shipped, will get $30 back when I return the core.
EF racks are easier to change.
iconAll times are GMT -8. The time now is 08:03 PM. | Welcome to Forum, please register to access all of our features.
