Go Back   D-series.org » Motor Mayhem & Suspension Satisfaction » Suspension Corner
Old 03-03-2009, 05:09 PM   #41 (permalink)
Poop Sock
wizard's blood's Avatar
Rep Power: 12 wizard's blood is the fucking MAN!!!!wizard's blood is the fucking MAN!!!!wizard's blood is the fucking MAN!!!!
wizard's blood is the fucking MAN!!!!wizard's blood is the fucking MAN!!!!wizard's blood is the fucking MAN!!!!wizard's blood is the fucking MAN!!!!wizard's blood is the fucking MAN!!!!wizard's blood is the fucking MAN!!!!wizard's blood is the fucking MAN!!!!
tokico whites
unknow blue springs
nuespeed upper rear strut
unknow upper front strut
92 vx hatch:
gsr/lsd
itr header
sri
no cat
crome pro
rex d16a6: DD
crespo stg 1 cam
gutted cat
zex 55dry shot
step 1 colder plugs
wizard's blood is offline   Reply With Quote
Old 03-04-2009, 07:52 AM   #42 (permalink)
JSNB143's Avatar
Rep Power: 2 JSNB143 is learning the way of the DJSNB143 is learning the way of the D
2000 Civic Ex coupe
Function Form Type II coilovers
Energy Suspension Master bushing kit
Hardrace endlinks
14mm GSR rear lower swaybar
Hardrace rear camber kit
DC sports front strut bar
195/65/14 wrapped BMW Bottlecaps
Still need to do rear disc brake conversion.
JSNB143 is offline   Reply With Quote
Old 03-05-2009, 01:26 AM   #43 (permalink)
Ped Rac3r's Avatar
Rep Power: 3 Ped Rac3r is learning the way of the DPed Rac3r is learning the way of the D
DC1 Integra
H&R Race springs
Koni Yellows
96 Spec Integra Type R front and rear sway bars
ISL Front and rear strut bar
282mm Prelude brakes in the front
DC2 Rear disks
15x7 Volk GR-N
Ped Rac3r is offline   Reply With Quote
Old 02-09-2010, 12:12 AM   #44 (permalink)
condom>child support
Tibby's Avatar
Rep Power: 10 Tibby is hot as a volcanoTibby is hot as a volcano
Tibby is hot as a volcanoTibby is hot as a volcanoTibby is hot as a volcanoTibby is hot as a volcanoTibby is hot as a volcanoTibby is hot as a volcanoTibby is hot as a volcano
skunk 2 sport shocks
skunk 2 coilovers
ebay extdned tophats
si rear swaybar
es lca bushings
es rta bushings
00 si knuckles 1.3in bigger brakes and bigger calliper
blox extended studs
90 civic lx, zc swap, si spec
quote by (many people)
"matt is like rainman with hondas"
big ups to all my haters
Tibby is offline   Reply With Quote
Old 02-09-2010, 04:20 AM   #45 (permalink)
39lbs attack cat!
remoer's Avatar
Rep Power: 13 remoer is hot as a volcanoremoer is hot as a volcano
remoer is hot as a volcanoremoer is hot as a volcanoremoer is hot as a volcanoremoer is hot as a volcanoremoer is hot as a volcanoremoer is hot as a volcanoremoer is hot as a volcano
Energy Suspension Hyperflex Master kit
OEM bushing
Ebay strut braces FU/RU
Jimfab traction bar
93 Acura Integra front 23mm hollow
ASR sub frame brace w/a 22mm solid ITR/R
Tokico HP Blues
RS*R Racing Springs(6.10kg(341lbs)/F & 4.20kg(235lbs)/R)
1 monkey power = 0.332 hp.
The suspension should always be faster than the engine - BMW
remoer is offline   Reply With Quote
Old 02-09-2010, 06:03 AM   #46 (permalink)
DaveEstey's Avatar
Rep Power: 0 DaveEstey is nobody
Megan sleeves with QA1 400lb springs all around
KYB AGX dampers w/DIY extended tophats
Blox smart arms rear
Some kind of adjustable front UCA
No front sway
22mm adjustable ST rear sway w/endlinks
ES Poly bushings all over
Ebay front strut bar
Kales Customs 6-point roll cage
Power steering removed.
<a href=http://img684.imageshack.us/i/sccnhsiggy.jpg/ target=_blank><a href=http://img684.imageshack.us/img684/3707/sccnhsiggy.jpg target=_blank>http://img684.imageshack.us/img684/3707/sccnhsiggy.jpg</a></a>
DaveEstey is offline   Reply With Quote
Old 02-09-2010, 06:38 AM   #47 (permalink)
You can call me SIR!
T-MacK's Avatar
Rep Power: 12 T-MacK is hot as a volcanoT-MacK is hot as a volcano
T-MacK is hot as a volcanoT-MacK is hot as a volcanoT-MacK is hot as a volcanoT-MacK is hot as a volcanoT-MacK is hot as a volcanoT-MacK is hot as a volcanoT-MacK is hot as a volcanoT-MacK is hot as a volcanoT-MacK is hot as a volcanoT-MacK is hot as a volcanoT-MacK is hot as a volcanoT-MacK is hot as a volcano
-H&R race springs
-KYB ajustables on all 4 corners
-Jdm ITR lca's
-Skunk2 front and back camber kit
-Energy Suspension master bushing kit
-ASR subframe brace
-ASR 24 mm rear sway bar
-18mm front sway bar
Just ordered a Benen tripod for engine bling.
T-MacK is offline   Reply With Quote
Old 02-09-2010, 07:51 PM   #48 (permalink)
Andrez's Avatar
Rep Power: 1 Andrez  is slowly gaining respectAndrez  is slowly gaining respectAndrez  is slowly gaining respectAndrez  is slowly gaining respectAndrez  is slowly gaining respect
Stock front 24mm sway bar with energy bushings
22mm Type R rear sway
Asr Subframe brace
Ground controls Front 380lbs rear 340lbs
stock shocks for now agx soon
front type r strut
no name strut rear
Konig Heliums Wrapped in 205/50/15 Kumhos ASX
thats it for now
Andrez is offline   Reply With Quote
Old 02-09-2010, 09:45 PM   #49 (permalink)
matt j's Avatar
Rep Power: 0 matt j is trying to make new friends
tein super street coilovers
hard race rear trailing arm bushings
integra 4 wheel disc brakes with hawk hps and brembo blanks
es swaybar bushings
blox 24mm rear sway bar
stock front sway bar
ebay strut bars fu/ru/rl
15x7 +40 rota gt3s with falken rt615
hoping for some ss lines and some new lcas
matt j is offline   Reply With Quote
Old 02-09-2010, 10:13 PM   #50 (permalink)
I no longer haz teh pink eye! Iz got STINK EYE
Bumpysbro's Avatar
Rep Power: 6 Bumpysbro It's a JDM Star Bitches....
Bumpysbro It's a JDM Star Bitches....Bumpysbro It's a JDM Star Bitches....Bumpysbro It's a JDM Star Bitches....Bumpysbro It's a JDM Star Bitches....Bumpysbro It's a JDM Star Bitches....
stock struts/springs
stock sway bar
stock bushings
no rear sway bar
lol...
Originally Posted by Pata View Post
OG SoCal mufuckers don't fear Smog
I almost had you man....you almost had me? You never had me..You never had your car LOL
http://twitter.com/Bumpysbro
Bumpysbro is offline   Reply With Quote
Old 02-09-2010, 10:17 PM   #51 (permalink)
SilentWrath*'s Avatar
Rep Power: 10 SilentWrath* It's a JDM Star Bitches....
Vehicle:
1991 Honda CRX Si
Suspension, wheels & tires:
*15x7 Kosei K1 Racing
*205/50/15 General Exclaim UHP
* Koni Yellows
*Custom extended upper strut mounts (rear)
*Omnipower Coils (F:448lb/in, R:336lb/in)
*Suspension Techniques F&R Sway bars (22.2mm)
*Neuspeed Front upper strut bar
*Cusco Front lower tie bar
*Custom Rear upper strut bar
*New OEM wheel bearings, tie rods, balljoints and bushings.
Brakes:
*New OEM Calipers (Blue ceramic paint)
*Project Mu Type NS pads(front)
*DRT drilled/slotted rotors (front)
*Carquest ceramic pads(rear)
*Brembo blank rotors (rear)
*New OEM brake hoses
*ATE Super Blue Racing brake fluid
*Super Mario brake reservoir sock
_________________________________________________
'91 CRX Si Project: DD Status. 9psi.
キタ━━━━━━(゚∀゚)━━━━━━!!!!!
<stock block d15b build complete.>
*Turbo Fabrication by Greg @ GO-AUTOWORKS.*
*Tuned by Howard @ RLZ Engineering.*
http://d-series.org/forums/showcase/...ravaganza.html
SilentWrath* is offline   Reply With Quote
Old 02-10-2010, 06:18 AM   #52 (permalink)
Bumpysbro's Avatar
Originally Posted by SilentWrath* View Post
Vehicle:
1991 Honda CRX Si
* Koni Yellows
Brakes:
very nice silent, i share your wheels and looking to use the same shock setup as you. how did the springs work out? i was looking for something as well but with not that huge of a drop.
Old 02-10-2010, 08:45 AM   #53 (permalink)
turboprelude95's Avatar
Rep Power: 13 turboprelude95 is hot as a volcanoturboprelude95 is hot as a volcano
turboprelude95 is hot as a volcanoturboprelude95 is hot as a volcanoturboprelude95 is hot as a volcanoturboprelude95 is hot as a volcanoturboprelude95 is hot as a volcanoturboprelude95 is hot as a volcanoturboprelude95 is hot as a volcanoturboprelude95 is hot as a volcanoturboprelude95 is hot as a volcanoturboprelude95 is hot as a volcano
Damn not sure if it has been said, but some of you run a way to big front sway bar.
My setup on my crx.
Ground control
Koni Yellow
Stoptech SS brake lines
Hawk Hp+ front pads
NSX front calipers
Rear disc
Asr brase and itr sway bar
Stock Hf front bar
Rear disc
Function 7 rlca
Es bushing kit in some areas
Soon to add:
HardRace front camber arms
HardRace rear camber kit
HardRace rear toe adj
Theres more but cant remember off the top of my head.
http://i105.photobucket.com/albums/m...oprelude95.png
Originally Posted by 99EJ6T View Post
^figure it out for yourself, this is d-series.org not spoon-feed-the-noob.org.
Originally Posted by ryan89crx View Post
taking it easy on new motors is weak. you need to show that bitch who is boss, then it will know not to fuck with you
i was boosting the shit out of mine after 40miles
My boosted crx thread http://www.d-series.org/forums/showt...t=23151&page=2
turboprelude95 is offline   Reply With Quote
Old 02-10-2010, 09:11 AM   #54 (permalink)
Egwhite's Avatar
Rep Power: 1 Egwhite is starting to learn the ropesEgwhite is starting to learn the ropesEgwhite is starting to learn the ropesEgwhite is starting to learn the ropesEgwhite is starting to learn the ropesEgwhite is starting to learn the ropesEgwhite is starting to learn the ropes
My setup on my crx.
Ground control
Koni Yellow
Hawk Hp+ front pads
NSX front calipers
Rear disc
Stock Hf front bar
Rear disc
Function 7 rlca
Soon to add:
I like you build. Its slow like mine but its detailed lol
99' Toyota Tacoma - Sold
02' Civic Si - Sold
93' Eg Hatch - Stolen (Fuck thieves)
89' Ef Sedan - Current
90' CRX Si - Current
The faster I go the more she likes it.
Egwhite is offline   Reply With Quote
Old 02-10-2010, 09:39 AM   #55 (permalink)
the springs are great, nice and tight but manageable on the street. some think they're too stiff, but I disagree.
Its quite well dampened with the konis.
Old 02-10-2010, 09:15 PM   #56 (permalink)
Mmmm DB1 love...
99EJ6T's Avatar
Rep Power: 33 99EJ6T is on a level you can only DREAM about! ! !99EJ6T is on a level you can only DREAM about! ! !99EJ6T is on a level you can only DREAM about! ! !99EJ6T is on a level you can only DREAM about! ! !
well... its mostly stock, but this should change very shortly.
90 DB1 "GS" w/o ABS, PS, sunroof
  1. omni power rear camber kit
  2. function and form type-1 full coil-overs
  3. innovative "traction" bar
  4. non-ride height adjusted sway bars
  5. adjusted trailing arm bushing
will be adding, next few months or so:
  • 5-lug itr conversion
  • swapped DC front control arms
  • progress rear sway
  • ST front sway
  • sk2 pro rlca
  • poly or new oem bushings in whats left
  • 16" prelude wheels
-might add some F&F type-2 also, but not 100% when i might do that. the itr stuff will happen sooner then later
Originally Posted by mindless View Post
I blew this tranny!
wow... cant believe you just said that... just wow..
90 DB1 = its alive!
1988 turbo super top secret build, less then 1500 built of this particular car
99EJ6T is offline   Reply With Quote
Old 02-11-2010, 06:33 AM   #57 (permalink)
Arcane's Avatar
Rep Power: 1 Arcane is trying to make new friends
10k/8k Omni Power Coilovers
26mm Civic SiR Front Sway Bar
22mm USDM Integra Type R Rear Sway
ASR Subframe Plate
Everything else is pretty much stock. I also have some cross drilled fronts and some replacement rear LCA's but the setup generally needs a refreshing.
My goal is.
24mm or 32mm rear sway bar.
Function and Form or PIC coilovers
11"/9.5" Brakes
Stainless Steel Lines
ITR Master Cylinder
Front Upper and Rear Upper Strut Bars.
Front and Rear Camber Kits
Rear Toe Kit
Supercharged Y7 @ 10 psi.
Arcane is online now   Reply With Quote
Old 02-11-2010, 07:22 AM   #58 (permalink)
little_nolan's Avatar
Rep Power: 1 little_nolan is learning the way of the Dlittle_nolan is learning the way of the D
DC2
-Koni yellows
-GC 450f 550r
-ITR 23mm rear sway
-ASR subframe brace
-S2 front uppers- swapped left for right and right for left (BEST MOD EVER!)
-Mugen hard rubber rear bushings
-ITR lca's
-Mugan hard rubber mounts
-98+ ITR rear upper camber bar
-Mugen Active gate brake calipers/11.8 S2K rotors
-pwjdm 3point front strut tower bar
-rear strut tower bar
-Autopower 4point roll bar
JDMLAND.COM--- ITR-EXPO10--
97' ITR #322 -- miss you
95' GSR track hoe
little_nolan is offline   Reply With Quote
Old 02-14-2010, 08:29 PM   #59 (permalink)
I been trying to update it, have about 90 pic's, but for some reason I can't get them to upload into photobucket.....
Old 02-15-2010, 04:42 AM   #60 (permalink)
You See Me Hi Hater!!!
Boosted-EH-804's Avatar
Rep Power: 23 Boosted-EH-804 Still a JDM Star....
Boosted-EH-804 Still a JDM Star....Boosted-EH-804 Still a JDM Star....Boosted-EH-804 Still a JDM Star....Boosted-EH-804 Still a JDM Star....Boosted-EH-804 Still a JDM Star....Boosted-EH-804 Still a JDM Star....Boosted-EH-804 Still a JDM Star....Boosted-EH-804 Still a JDM Star....Boosted-EH-804 Still a JDM Star....Boosted-EH-804 Still a JDM Star....Boosted-EH-804 Still a JDM Star....Boosted-EH-804 Still a JDM Star....Boosted-EH-804 Still a JDM Star....Boosted-EH-804 Still a JDM Star....Boosted-EH-804 Still a JDM Star....
Custom 1k rear eibach
dropzone struts
dropzone coilovers for the front
RCautoworks
Project D2B
Boosted-EH-804 is offline   Reply With Quote
iconAll times are GMT -8. The time now is 11:21 PM. | Welcome to Forum, please register to access all of our features.
