so i thought i would start a new project log as my build has gone in a very different direction...
for those that dont know the back story here is the old project log:
http://www.d-series.org/forums/showcase/107827-95-civic-cx-hatch-project-d15b7.html
the name "miss civic" was given to my car by my g/f ..... she claims i'm having an affair with miss civic and she is just going to have to learn to live with the fact i got two ladies in my life that need constant attention and money
anyways i will start from just a few months back to get you up to speed
last year for the few weeks it actually lived before spinning a bearing
and now....block and arp's are in, head and turbokit are just sitting as i was test fitting the new intercooler pipes
current mod list:
engine:
-block
built d16y7 (eagle rods/std bore vitara)
arp head studs
-head (z6)
skunk2 valves
crower valve springs
272-2(bisi 2.4 clone) delta cam
milled
port and polish
Cleaned up bowls
Back cut valves
Competionion 3 angle (5 angle) valve job
Deshrouded valves
aem cam gear
y8 head gasket
3" exhaust
Edlebrock performer x intake manifold
Skunk2 70mm throttle body
spoon oil cap
Dual core aluminum radiator
Slim fan with shroud
Speed factory thermo intake mani gasket
turbo:
Holset hx35
Custom ramhorn
mini external ebay wastegate
3" v-band down pipe
2.5 ic pipes
genuine blitz blow off valve
godspeed fmic
Rc 750cc saturated injectors
stealthmode oil line kit
tuner toys block fitting
ngk- bkr7e
drivetrain:
egay short shifter (over 4years now )
Shift extender
Weighted knob
f1 stage 3 sprung 6 puck clutch and performance pressure plate
H22 slave cylinder
si 5-speed
Suspention & rollers;
K-sport full bodied coilovers with adj dampning
Aftermarket red rlca's
street - 16x7 asa -bf goodrich g-force tires
track- 24.5x8x14 mickey tompson drag slicks on 15" hx rims with screws
exterior:
spoon style front lip
ek sideskirts
amber corners
50/50 tail lights
spoon style mirrors
carbon fiber duckbill
Vis vented carbon fiber hood
Vent visors
diy black housing headlights
interior:
knock off red recaros
4 point harness
autopower 4 point cage with custom harness bar
clock
jdm center audio consol
autometer dash gauge pod
5" autometer monster tach
aem uego wideband
2 5/8s water temp gauge
carbon fiber radio block off plate w/ autometer boost and oil pressure gauges
carbon fiber gauge cluster shroud
rear strut bar
red l.e.d's in gauge cluster(looks nice)
itr shift knob
armrest
v3 dvd/cd player
5 1/4 pioneer door speakers
6x8 sony rear speakers
pioneer immp 12"sub
generic 450watt amp(250rms)
tune will be done by RCautoworks
Goals are 11.999 or faster / 130mph+ traps / 400whp+ all on pump 93oct.
Car needs to be good for 10s ....and I will work my way to it
current mod list:
engine:
-block
arp head studs
-head (z6)
skunk2 valves
milled
port and polish
Cleaned up bowls
Back cut valves
Deshrouded valves
aem cam gear
y8 head gasket
3" exhaust
spoon oil cap
turbo:
Holset hx35
Custom ramhorn
3" v-band down pipe
2.5 ic pipes
godspeed fmic
ngk- bkr7e
drivetrain:
Shift extender
Weighted knob
H22 slave cylinder
si 5-speed
exterior:
ek sideskirts
amber corners
50/50 tail lights
spoon style mirrors
Vent visors
interior:
4 point harness
clock
aem uego wideband
rear strut bar
itr shift knob
armrest
v3 dvd/cd player
pioneer immp 12"sub
