Go Back   D-series.org » Everything Else » Showcase
Old 03-18-2010, 10:25 PM   #1 (permalink)
6262 > Holset
danz's Avatar
Rep Power: 20 danz Still a JDM Star....
danz Still a JDM Star....danz Still a JDM Star....danz Still a JDM Star....danz Still a JDM Star....danz Still a JDM Star....danz Still a JDM Star....
Default danz 2010 1/4 mile saga
first off i want to say thank you to greg at go-autoworks.com for always hooking me up! i owe you! thanks a million to geoff at coltcams.com for helping me with a cam! it should make a huge difference! thanks to rob at RTFab for the reservoir! and a furure thanks to chris @ polarbeartuning.com for the sick sick sick 74mm tb's and plates.
well heres my new build thread for 2010. i have set a very extreme goal for myself of trying to touch a 9. i dont know if it will happen, but i will keep pushing the car until i get close. i have a nitrous kit ready to rock if i need it, but ive been saving up and decided to use a sc6262 instead of a garret t3/t4 i was going to use. as such, i have set a difficult but doable goal.
anyways..
i was tired of jamming stuff in the engine bay of my 90 civic CX and i didnt want to mess around with that anymore. i also didnt want to cage the 90 because i learned how to drive in it way back in the day, and its just been around for ever.
so i elected to go with a 1998 civic CX i got for dirty cheap.
its really clean for what i paid for it.
so we got to work quick and pulled the stock y7 out. its a back up block now in case someone blows up their d and needs to get back in the game quick.
rusted in
a little test fittin to check stuff out. they look so small. haha
my EJ6 build thread here!
2010 - 11.536@117.75mph - Z6
2009 - 10.912@127.33mph - A6
Special thanks to ColtCams.com and Go-Autoworks.com!
danz is offline   Reply With Quote
Old 03-18-2010, 10:26 PM   #2 (permalink)
6262 > Holset
danz's Avatar
since i want to drive my car to the track, i found myself with a problem. its about an hour and a bit drive to get there, sometimes up to 40 minutes in bumper to bumper rush hour traffic on the high way. the car was getting heat soaked really bad.
i would get to the track, and have to wait 2 hours before i could race or else i was just wasting time.
so i decided ill go water to air, with a reservoir for ice and water, and just replace the ice when it melts. in comes Rob from RTFab. he made me a KILLER reservoir and i got him to snap a couple fab pics. for anyone in the lower mainland,if u can get rob to do some work for you, do it!
finished product
i got myself a bilge pump and a nice 14inch core too
Old 03-18-2010, 10:26 PM   #3 (permalink)
6262 > Holset
danz's Avatar
there are some other "problems" with the new car. the first problem is its heavier. i figure if i can get the car to weigh the same as the ED then i will go faster no matter what. so i got to work!! haha
the dash is going back in, but im going to try to lighten it as much as possible. i want to see this car at 2000lb or less!
custom carbon cotton bezel courtesy of darin
next thing i had to fix from last year was my gearing. it was so shitty with the stock si gearing. man, i would hit 3rd gear and it would take sooo long for the rpm to rise. it was not optimal. i would cross the line around 7000rpm and it just was not working for me.
so i got my hands on a set of zc gears, finally, and swapped everything into a y8 tranny.
heres my awesome bearing puller. im so glad i got this thing!
and hopefully you can chime in bone, does this look all good and proper? i used std 3rd w/o any mods.
Old 03-18-2010, 10:27 PM   #4 (permalink)
6262 > Holset
danz's Avatar
yet another problem i had to fix.... the cylinder head! i just didnt have any luck with the a6 head. so im going to try with a z6 head this year. i am getting a colt cam, and its going to be a pretty wild little profile. i cant wait to try it out. should make most torque from 6000-9000rpm. perfect.
fresh 3 angle valve job, ported, ready to rock.
i also tossed in a walbro for now. if it doesnt flow enough for my goals ill add a bosch inline. (reused the stock sock)
i rebuild the engine for curiosity sake. everything was good except the cyl walls has some decent gouging and one piston had a bunch of pits from a ground strap falling off. i polished the SRP out and put it back in. the a6 SPR's with a z6 head should give me a nice little bump in compression too
it still needs a cam in it, my colt isnt ready yet. but i have a stock z6 cam i can use. or a y8 zex 300.
Old 03-18-2010, 10:27 PM   #5 (permalink)
6262 > Holset
danz's Avatar
i went back to solid mounts, the same as i had in my ED. going to try and run the tranny mount and both front torque mounts if i can fit em both.
darin cant stand a dirty engine bay so he gave it a quick douching
before
after. not bad for 15 minutes and no pressure washer. haha.
Old 03-18-2010, 10:28 PM   #6 (permalink)
6262 > Holset
danz's Avatar
heres the wiring harness. its a y7 harness. i swapped and extended the IAT sensor plug, did a 2 wire IACV conversion, swapped the dizzy plugs from OBD2A to OBD1, swapped injector plugs to OBD1, and added in a resistor box. this pic is right before i did the resistor box.
car chillin in its own filth
since im broke as ever ill be using these on stock struts and seeing what happens. stank2 drags with maxspeed perches. they were cheap!
got my canadian made kirkey
lookin pretty mean and pretty clean in gold baby
got it in the ebay. just need to fab up a mount or buy one and take it from there i cant wait.
heavy metal paint edelbrock
there is still a lot left for me to do. my issue right now is a lack of funds. so im putting wants behind needs and getting done what needs to be done to make tuning passes and so forth
things that need to still be done is the manifold, the exhaust, dump tube, charge piping, routing the plumbing for the water to air, setting up the ecu, swapping over my BOV from the old car to this one.. etc, im sure there is much more.
some things ill be getting in the near future are progress drag coils, a full cage from S&W, new 24.5 slicks, maybe a meth kit (way cheaper than race gas) body work and more gutting once the cage is in.
a side project with this car is to drive long distances with the water to air pump off, putting a nice warm charge into the engine. i think i can get some really decent gas mileage from this car as well as it being very fast!
Old 03-18-2010, 10:34 PM   #7 (permalink)
D16EG8's Avatar
Rep Power: 2 D16EG8 is trying to make new friends
WOW, Looks awesome. Keep up the good work. Sorry if you said but what valvetrain are you using?
D16EG8 is offline   Reply With Quote
Old 03-18-2010, 10:41 PM   #8 (permalink)
\/ apply baby lotion here \/
Pata's Avatar
Rep Power: 22 Pata Still a JDM Star....
Pata Still a JDM Star....Pata Still a JDM Star....Pata Still a JDM Star....Pata Still a JDM Star....Pata Still a JDM Star....Pata Still a JDM Star....Pata Still a JDM Star....Pata Still a JDM Star....Pata Still a JDM Star....Pata Still a JDM Star....Pata Still a JDM Star....Pata Still a JDM Star....Pata Still a JDM Star....Pata Still a JDM Star....Pata Still a JDM Star....
Might have missed it, but is there any pix of the Blocks goodies? and any snail teaser pix?
Pata is offline   Reply With Quote
Old 03-18-2010, 10:51 PM   #9 (permalink)
6262 > Holset
danz's Avatar
snail is coming soon, still havent paid for it. valve train is zex springs with stock retainers and a colt cam when it comes.
block is going to be in the upper 9's for CR, since its using A6 SRP's with a z6 head and a metal layer head gasket. eagle rods, taiho bearings, NPR rings, stone hone, ARP's @ 65ftlb
Old 03-18-2010, 11:04 PM   #10 (permalink)
sick1camcivic's Avatar
Rep Power: 8 sick1camcivic is almost there....
sick1camcivic is almost there....sick1camcivic is almost there....sick1camcivic is almost there....sick1camcivic is almost there....sick1camcivic is almost there....sick1camcivic is almost there....sick1camcivic is almost there....sick1camcivic is almost there....
sickkk. Cant wait to see what it runs. Sounds like its gonna be badass!
RIP <3Jayda<3 2 yr old Boxer 8-14-2009
http://www.youtube.com/watch?v=HPmIu...layer_embedded
teamdohc.org
95 civic coupe ex. Vitara-hbeam Z6
z6 tranny with 4.7FD Blown up after 120miles.
New Project Built Turbo F2B F22A nonvtec into civic
93 Accord SE 4dr black mint-stock- FOR TRADE
sick1camcivic is online now   Reply With Quote
Old 03-18-2010, 11:30 PM   #11 (permalink)
vtec_bomber's Avatar
Rep Power: 6 vtec_bomber is a name known to allvtec_bomber is a name known to allvtec_bomber is a name known to allvtec_bomber is a name known to allvtec_bomber is a name known to allvtec_bomber is a name known to allvtec_bomber is a name known to allvtec_bomber is a name known to allvtec_bomber is a name known to all
Sh#t badass.
vtec_bomber is offline   Reply With Quote
Old 03-19-2010, 12:00 AM   #12 (permalink)
back it up an dump it
jimmyb34's Avatar
Rep Power: 41 jimmyb34 is on a level you can only DREAM about! ! !jimmyb34 is on a level you can only DREAM about! ! !
jimmyb34 is on a level you can only DREAM about! ! !jimmyb34 is on a level you can only DREAM about! ! !jimmyb34 is on a level you can only DREAM about! ! !jimmyb34 is on a level you can only DREAM about! ! !jimmyb34 is on a level you can only DREAM about! ! !jimmyb34 is on a level you can only DREAM about! ! !jimmyb34 is on a level you can only DREAM about! ! !jimmyb34 is on a level you can only DREAM about! ! !jimmyb34 is on a level you can only DREAM about! ! !jimmyb34 is on a level you can only DREAM about! ! !
Should be an awesome build man. You son of a bitches keep going faster and faster! Your fanning up your own mani and stuff right??
Originally Posted by TING View Post
jimmy runs this bitch
jimmyb34 is online now   Reply With Quote
Old 03-19-2010, 02:07 AM   #13 (permalink)
I AM A MF!
Rep Power: 45 transzex is on a level you can only DREAM about! ! !transzex is on a level you can only DREAM about! ! !transzex is on a level you can only DREAM about! ! !transzex is on a level you can only DREAM about! ! !transzex is on a level you can only DREAM about! ! !
Kirkey Pro Street, how wide is your ass?????
I need an 18" wide chair.
Limited tranny pics, I see nothing wrong............but I'm not seeing much right now.
St Pattys day....a day late!
I will always feed an inquisitive mind, prod a lazy noob and blast a disrespectfull bum.
transzex is offline   Reply With Quote
Old 03-19-2010, 02:34 AM   #14 (permalink)
turbopumpkin's Avatar
Rep Power: 2 turbopumpkin is learning the way of the Dturbopumpkin is learning the way of the D
FINALLY! Looks great dan. youve been busy. Cant wait to see the progress. Good luck with 9's
old-
y7/ z6 head
garrett .42/.48
tial 38mm
10psi
s300
14.4 @96.8 2.39 60ft:tu:
current- y7/z6 stock
building currently...z6 with vitaras, fjts, arps,comp stg 4, holset hy 35
turbopumpkin is offline   Reply With Quote
Old 03-19-2010, 03:55 AM   #15 (permalink)
Rep Power: 4 jamato0331 is a name known to alljamato0331 is a name known to alljamato0331 is a name known to alljamato0331 is a name known to alljamato0331 is a name known to alljamato0331 is a name known to alljamato0331 is a name known to alljamato0331 is a name known to all
dude, this is sick. what kind of power do you think you will need to hit 9's?
jamato0331 is offline   Reply With Quote
Old 03-19-2010, 04:09 AM   #16 (permalink)
boost ben's Avatar
Rep Power: 3 boost ben is a name known to allboost ben is a name known to allboost ben is a name known to allboost ben is a name known to allboost ben is a name known to allboost ben is a name known to allboost ben is a name known to allboost ben is a name known to allboost ben is a name known to all
1996-2000 engine bay is the bomb. Are you going to be making a crazy manifold like the one on Daren's car? Hope you get this thing to the track soon.... I also have lots of work left :s
boost ben is offline   Reply With Quote
Old 03-19-2010, 04:18 AM   #17 (permalink)
Shoot me!
Hellhatch's Avatar
Rep Power: 40 Hellhatch is on a level you can only DREAM about! ! !Hellhatch is on a level you can only DREAM about! ! !Hellhatch is on a level you can only DREAM about! ! !
Hellhatch is on a level you can only DREAM about! ! !Hellhatch is on a level you can only DREAM about! ! !Hellhatch is on a level you can only DREAM about! ! !Hellhatch is on a level you can only DREAM about! ! !Hellhatch is on a level you can only DREAM about! ! !Hellhatch is on a level you can only DREAM about! ! !Hellhatch is on a level you can only DREAM about! ! !Hellhatch is on a level you can only DREAM about! ! !
Nice job coming along well.
MY RIDE THREAD!!http://www.d-series.org/forums/showcase/45569-few-pics-whip-progress.html
GO STEELERS!
Hellhatch is offline   Reply With Quote
Old 03-19-2010, 04:29 AM   #18 (permalink)
mindless's Avatar
Rep Power: 33 mindless is on a level you can only DREAM about! ! !mindless is on a level you can only DREAM about! ! !mindless is on a level you can only DREAM about! ! !mindless is on a level you can only DREAM about! ! !
mindless is on a level you can only DREAM about! ! !mindless is on a level you can only DREAM about! ! !mindless is on a level you can only DREAM about! ! !mindless is on a level you can only DREAM about! ! !mindless is on a level you can only DREAM about! ! !mindless is on a level you can only DREAM about! ! !mindless is on a level you can only DREAM about! ! !
This thread makes the pic gods happy.
Btw I hate you. You have a cx and I don't.
www.teamdohc.org
Oh noez a chat thread (sign up and join in):http://teamdohc.org/forums/index.php?topic=1428.0
Originally Posted by 99EJ6T View Post
Originally Posted by Dweezil View Post
mindless is offline   Reply With Quote
Old 03-19-2010, 05:05 AM   #19 (permalink)
formerly Kit88
Hugo Boost's Avatar
Rep Power: 19 Hugo Boost is the fucking MAN!!!!Hugo Boost is the fucking MAN!!!!Hugo Boost is the fucking MAN!!!!Hugo Boost is the fucking MAN!!!!
Hugo Boost is the fucking MAN!!!!Hugo Boost is the fucking MAN!!!!Hugo Boost is the fucking MAN!!!!Hugo Boost is the fucking MAN!!!!Hugo Boost is the fucking MAN!!!!Hugo Boost is the fucking MAN!!!!
it looks very nice Danz, you have a lot of new ideas, and a great goal.
GL, and keep us updated.
11.07 at 118 mph
Thanks to my sponsors:
FJ Distributors, Special Project Motorsports (Kiwi) ,Performance Porting,Transzex, Alexracing, RSM motorsports, Go-Autoworks, D-series.org, SpeedFactory, Bisimoto
Hugo Boost is online now   Reply With Quote
Old 03-19-2010, 05:08 AM   #20 (permalink)
meet the girls...
myHonda1's Avatar
Rep Power: 36 myHonda1 is on a level you can only DREAM about! ! !myHonda1 is on a level you can only DREAM about! ! !myHonda1 is on a level you can only DREAM about! ! !myHonda1 is on a level you can only DREAM about! ! !myHonda1 is on a level you can only DREAM about! ! !
myHonda1 is on a level you can only DREAM about! ! !myHonda1 is on a level you can only DREAM about! ! !myHonda1 is on a level you can only DREAM about! ! !myHonda1 is on a level you can only DREAM about! ! !myHonda1 is on a level you can only DREAM about! ! !myHonda1 is on a level you can only DREAM about! ! !myHonda1 is on a level you can only DREAM about! ! !myHonda1 is on a level you can only DREAM about! ! !myHonda1 is on a level you can only DREAM about! ! !
i agree with this guy.
ive been looking for a shell for a couple weeks now and i havent come across anything as nice as that.
looks awsome man!
im in.
Originally Posted by danz View Post
"when life gives you lemons, paint that shit gold"
Originally Posted by eddcartes View Post
i love to rape kids...*silence*
let me touch you.
myHonda1 is offline   Reply With Quote
iconAll times are GMT -8. The time now is 08:21 PM. | Welcome to Forum, please register to access all of our features.
