Checker/O'Reily 'MasterPro' branded rear hub/bearing assembly - D-series.org
Go Back   D-series.org D-series Knowledge Factory Product Reviews
Old 12-02-2010, 08:18 AM   #1 (permalink)
bopApocalypse's Avatar
Rep Power: 8 bopApocalypse will become famous soon enoughbopApocalypse will become famous soon enoughbopApocalypse will become famous soon enough
Angry Checker/O'Reily 'MasterPro' branded rear hub/bearing assembly
Good:
Price is right, bolts up just fine.
Bad:
doesn't use the 'standard' diameter for wheel studs - so, if you've got extended studs you want to install in this hub, they probably won't work. The knurl diameter they use is closer to .509" than Honda's normal .485"
It looks like the 'Late GM Camaro, Firebird, Corvette' ( 100-7708 ) and the Early Miata (100-7719) studs from ARP should work - just a PITA that I have to buy new studs. I've got a set of the GM ones on order, will post back if they work - would've preferred to get the Miata ones (they have the 'bullet nose', the GM ones don't), but the GM ones were cheaper and I could get them ASAP.
Bottom line - probably won't buy these again.
My build thread -
bopApocalypse is offline   Reply With Quote Quick reply to this message
Old 12-24-2010, 12:06 AM   #2 (permalink)
v8killaz's Avatar
Rep Power: 10 v8killaz is almost there....
v8killaz is almost there....v8killaz is almost there....v8killaz is almost there....v8killaz is almost there....v8killaz is almost there....v8killaz is almost there....v8killaz is almost there....v8killaz is almost there....v8killaz is almost there....v8killaz is almost there....
i hate when the parts you buy at autozone and shit uses diff bolts
i just did my buddies crx and hear this today
the lower ball joint used a 19mm socket
the upper used a 17. and the tie rod used a 18
then i think the control arms for one side used 18 and the other side used 19..
i mean what the fuck man
get that shit right
17mm all day
doesnt help his lug nuts are all different sizes too lol
v8killaz is offline   Reply With Quote Quick reply to this message
iconAll times are GMT -8. The time now is 05:21 PM. | Welcome to Forum, please register to access all of our features.
