D16z6 intake manifold on d16y7 - D-series.org
Old 02-18-2004, 11:08 PM   #1 (permalink)
dx-r
Default D16z6 intake manifold on d16y7
hey i have a d16y7 motor, and am planning to swap a ported d16z6 intake manifold with b16 throttle body. I little cheaper. But i am having trouble finding installation instructions for it. I found instructions on installing a d16y8 manifold on a d16y7. Is it the same thing , or will i have to change a few things. If i do, what would i have to modify in order to install it. If you can please give me a link to a site that has the installation instructions of a d16z6 manifold to d16y7 motor. thanks!!!!
Old 02-19-2004, 01:17 PM   #2 (permalink)
DOG
DOG's Avatar
Rep Power: 16 DOG is approaching greatnessDOG is approaching greatnessDOG is approaching greatnessDOG is approaching greatnessDOG is approaching greatnessDOG is approaching greatnessDOG is approaching greatnessDOG is approaching greatnessDOG is approaching greatnessDOG is approaching greatnessDOG is approaching greatnessDOG is approaching greatnessDOG is approaching greatness
iTrader Score: 18 reviews
Send a message via AIM to DOG
http://www.makuragi.s5.com/civic_99/Y8maniswap/
z6 intake manifold will be pretty much the same. Use the B16 TB gasket. instead of the Y8 IAT (intake air temp sensor)being on the intake tube that connects to the TB it will be on the back of the z6 intake manifold.
Should be a pretty straightforward swap.
DOG is offline   Reply With Quote Quick reply to this message
Old 02-19-2004, 04:02 PM   #3 (permalink)
pearl62's Avatar
Rep Power: 14 pearl62 is starting to learn the ropespearl62 is starting to learn the ropespearl62 is starting to learn the ropespearl62 is starting to learn the ropespearl62 is starting to learn the ropespearl62 is starting to learn the ropes
I have a Z6 intake and 60mm TB on my Y7 and it was very easy.
pearl62 is offline   Reply With Quote Quick reply to this message
Old 01-03-2009, 04:19 AM   #4 (permalink)
civic13dx92's Avatar
Rep Power: 0 civic13dx92 is nobody
Send a message via AIM to civic13dx92
ive done the d16z6 manifold swap on the y7 it went but later on he called to tell me that the car had white smoke comming from the exhaust and the engine is behaving like a missfire and he smells petrol ....im wondering if could be anything ive done wrong ??? he say theres no code and leakes ...
go boogy go !!
civic13dx92 is offline   Reply With Quote Quick reply to this message
Old 01-03-2009, 07:07 AM   #5 (permalink)
threeHONDA's Avatar
Rep Power: 9 threeHONDA is trying to make new friends
you might have to swap dizzys to stay obd-2, im not a hundred percent sure though.
who says honda's need a swap to be fast? pshh
threeHONDA is offline   Reply With Quote Quick reply to this message
Old 01-03-2009, 05:35 PM   #6 (permalink)
Rep Power: 9 Berta is learning the way of the DBerta is learning the way of the D
I've heard that swapping to the z6 or y8 mani really wakes up the y7!
Berta is offline   Reply With Quote Quick reply to this message
Old 01-03-2009, 07:13 PM   #7 (permalink)
threeHONDA's Avatar
definitely can see that, the y7 manifold is so stupid. I looked like a retard when I hooked up the bg system cleaner to my car, I eventually just had friend hold the nozzle in there while I hit the gas.
Old 01-07-2009, 12:17 PM   #8 (permalink)
civiclsi's Avatar
Rep Power: 0 civiclsi is nobody
I was the person talked about is this topic about the smoke...simply had a problem with one of the injectors...sorted now.. D16z6 intake mainfold makes a great differnece on the y7....doesn't feel like its starving.
civiclsi is offline   Reply With Quote Quick reply to this message
Old 01-07-2009, 12:47 PM   #9 (permalink)
JSNB143's Avatar
Rep Power: 9 JSNB143 is learning the way of the DJSNB143 is learning the way of the D
The y8 manifold def made a difference to my friend's y7. I think the Z6 would do the same.
JSNB143 is offline   Reply With Quote Quick reply to this message
Old 01-07-2009, 02:20 PM   #10 (permalink)
civic4dr2000's Avatar
Rep Power: 12 civic4dr2000 is a name known to allcivic4dr2000 is a name known to allcivic4dr2000 is a name known to allcivic4dr2000 is a name known to allcivic4dr2000 is a name known to allcivic4dr2000 is a name known to allcivic4dr2000 is a name known to allcivic4dr2000 is a name known to allcivic4dr2000 is a name known to all
^^^^^ All of you are idiots... This thread is almost five years old,I am pretty sure he figured it out by now????????
I REP BACK
wow... and to think i gave up weed and heavy drinking to make money and be successful when all this time i could have been putting lime juice in my eye...
civic4dr2000 is offline   Reply With Quote Quick reply to this message
Old 01-07-2009, 02:23 PM   #11 (permalink)
Rep Power: 0 bmxmacdaddy is nobody
i have a z6, and have read the y8 is just a tad better... just buy looking at the y8 mani, it seems like a better design....
a y8 IM will bolt on a z6 with out fab wont it?
bmxmacdaddy is offline   Reply With Quote Quick reply to this message
Old 01-07-2009, 02:26 PM   #12 (permalink)
JSNB143's Avatar
lmao thanks for the heads up. FAIL.
Maybe new members could look this up and figure it out for themselves before posting a new thread.
Old 08-16-2009, 06:53 PM   #13 (permalink)
98dxNooby's Avatar
Rep Power: 9 98dxNooby is da #1 stunna98dxNooby is da #1 stunna98dxNooby is da #1 stunna98dxNooby is da #1 stunna98dxNooby is da #1 stunna98dxNooby is da #1 stunna98dxNooby is da #1 stunna
Talking
Okay, so this is my first post ever...but i just did this swap today (actually it took two days ) and it really wasn't extremely hard, the only problems i ran into were that i had two open spots on the back of my manifold (i am guessing one was cruise control and the other i had no clue), so i had to custom fab some block off plates...but other than that not hard at all, and it sounds AWESOME! o and its a bit quicker too
98dxNooby is offline   Reply With Quote Quick reply to this message
Old 09-14-2009, 08:44 PM   #14 (permalink)
airkhin's Avatar
Rep Power: 0 airkhin is nobody
buddy has a z6 manifold layin around... what are all the steps in swapping it over? anybody have a diy on how to do it??? (im still searchin around...)
airkhin is offline   Reply With Quote Quick reply to this message
Old 10-11-2009, 04:01 AM   #15 (permalink)
Rep Power: 9 toadcivic is nobody
i know the post is old but im just about to put the z6 mani on my y7 and i have a few questions.
do i have to use the y7 throttle body or will the z6 hook straight up?
i need the y7 injectors?
what other parts should i swap out while im at it... fuel filter etc etc?
thanks in advance
toadcivic is offline   Reply With Quote Quick reply to this message
Old 10-11-2009, 10:54 AM   #16 (permalink)
weise's Avatar
Rep Power: 8 weise is almost a somebodyweise is almost a somebodyweise is almost a somebodyweise is almost a somebody
get the Y8 its way better, ive had the Z6, skunk2, and Y8 and its been the best so far.
OOOHH YEEAH 3 rep power woah! woah!
16.7@78.62mph D16Y7,Y8 I.M.,DC header.full interior
weise is offline   Reply With Quote Quick reply to this message
Old 10-12-2009, 10:44 AM   #17 (permalink)
not gona happen because i've got the z6 now and want to get it on!
you sound like your got a load of experience doing the swaps, any advice you can give me to make it a smooth moving job please?
Old 10-12-2009, 07:34 PM   #18 (permalink)
metalishblue_lx's Avatar
Rep Power: 8 metalishblue_lx is nobody
I will pick up a Z6 IM form yunk yard tomorrow, i will still use y7 fuel rail, injectors, and TB.
Let me know if i'm missing something..oh yea a Z6 IM gasket of course!
metalishblue_lx is offline   Reply With Quote Quick reply to this message
Old 10-20-2009, 02:40 PM   #19 (permalink)
Rep Power: 0 carmanvti is nobody
I'm planing to swap d15b7 intake manifold to d16y7 engine, it is possible?
carmanvti is offline   Reply With Quote Quick reply to this message
Old 10-20-2009, 10:36 PM   #20 (permalink)
89s1's Avatar
Rep Power: 14 89s1 is hot as a volcano
89s1 is hot as a volcano89s1 is hot as a volcano89s1 is hot as a volcano89s1 is hot as a volcano89s1 is hot as a volcano89s1 is hot as a volcano89s1 is hot as a volcano89s1 is hot as a volcano89s1 is hot as a volcano89s1 is hot as a volcano89s1 is hot as a volcano89s1 is hot as a volcano89s1 is hot as a volcano89s1 is hot as a volcano
iTrader Score: 12 reviews
It sure is.
89s1 is offline   Reply With Quote Quick reply to this message
iconAll times are GMT -8. The time now is 02:30 AM. | Welcome to Forum, please register to access all of our features.
