how to identify a ZEX cam ? - D-series.org
Old 01-26-2004, 05:18 AM   #1 (permalink)
kenairs
hi pals,
just gotten a ZEX cam but previous owner does not know which model it belongs to , 105100 or 105300.
However, all i can see is at the end of the cam there is some marking like, AX 130 .
please enlighten. tks!
Old 01-26-2004, 05:46 AM   #2 (permalink)
IslanderRx
I have a zex cam too and I really never looked at it. I was so excited when it came in and installed it right away. But you can try comparing it to your stock cam. If its similiar or close to the stock one it could be the 105100. The 105300 should have larger lobes than the stock. Its worth a try unless someone out there can identify the markings on the cam.
Old 01-26-2004, 06:17 AM   #3 (permalink)
kenairs
Hi Rx,
nice to see u reply. Anyway waht car u driving ? Does it have any effect after u install ? i try to take a pic of the cam if possible and email u. U take a look and advise me ?
cheers
Old 01-26-2004, 07:25 AM   #4 (permalink)
D-series wise guy
kommon_sense's Avatar
Rep Power: 14 kommon_sense is da #1 stunnakommon_sense is da #1 stunnakommon_sense is da #1 stunnakommon_sense is da #1 stunnakommon_sense is da #1 stunnakommon_sense is da #1 stunnakommon_sense is da #1 stunna
iTrader Score: 12 reviews
Send a message via AIM to kommon_sense Send a message via Yahoo to kommon_sense
contact zex and/or comp cams.
'98 Civic EX
kommon_sense is offline   Reply With Quote Quick reply to this message
Old 01-26-2004, 07:31 AM   #5 (permalink)
kenairs
try email to zex but no reply from them..
wat's comp cams ?
Old 01-26-2004, 08:26 AM   #6 (permalink)
egcivicboy
Comp cams owes the ZEX company... do a search for Comp Cams
Old 01-28-2004, 12:22 PM   #7 (permalink)
mdt017
you can't really identify zex cams... on mine all I had for identification was '59300' scratch etched lightly on the cam on the end that goes into the c-gear...
Got mine brand new with spec card that said 59300, then blank for specs
But I picked mine up from a reputable shop so I wasn't worried, and once it was in the valves were louder and the intake sounded sweeeeeet.
iconAll times are GMT -8. The time now is 02:32 AM. | Welcome to Forum, please register to access all of our features.
