b16a just doesnt pull anymore :( - D-series.org
Old 11-02-2011, 09:05 PM   #1 (permalink)
braxtonsag's Avatar
Rep Power: 7 braxtonsag is a name known to allbraxtonsag is a name known to allbraxtonsag is a name known to allbraxtonsag is a name known to allbraxtonsag is a name known to allbraxtonsag is a name known to allbraxtonsag is a name known to allbraxtonsag is a name known to all
Default b16a just doesnt pull anymore :(
I have been having this weird problem the past couple of days. I ordered my b16a sir2 off of hmotorsonline and everything has been great except I didn't have vtec at first. Replaced the speed sensor, no problem. Vtec pulled hard. Litteraly I'm not exagerating when I say it felt like a sort of turbo lag. Vtec pulled a lot harder than the smaller profile. So everythings going great and I fix my wideband so I can run my p28 with ectune instead of the jdm p30. So I take out my p30 and put in the p28. From that point on, vtec actually feels like it pulls less than the smaller cam profile.. its litterally a massive disappointment. So I figure the timing map must not be right and advance it a little on the vtec map at WOT. It pulled just as it used to, but the map had flaws because it just felt choppy at points while driving. So I put the p30 back in because there's really no reason to run a less aggressive map. Now it just quit pulling in vtec all together. It barely chirps second when it used to scream into second. So I check my oil, oil level is full, and I can hear vtec engaging. But it simply just isn't doing anything. I took a look at my wideband and at WOT in vtec it actually went to a 10.9 for a split second then jumped up to low 12s. I don't know if that's what it was at before when it was pulling hard or not, I didn't pay attention. So I figured maybe my ecu was messed up and put the p28 back in. And even it doesn't pull hard in vtec. I really don't know what could be going on. It ran fine one day now it doesn't. Anyone have any clues? All help is greatly appreciated.
CROME Help/Basemap Services- PM me
Built&Boosted 94 Civic LX Sedan - TRADED
braxtonsag is offline   Reply With Quote Quick reply to this message
Old 11-02-2011, 09:10 PM   #2 (permalink)
baajaa's Avatar
Rep Power: 7 baajaa is fly like an eaglebaajaa is fly like an eaglebaajaa is fly like an eaglebaajaa is fly like an eaglebaajaa is fly like an eaglebaajaa is fly like an eaglebaajaa is fly like an eaglebaajaa is fly like an eaglebaajaa is fly like an eaglebaajaa is fly like an eaglebaajaa is fly like an eagle
You know for a fact the solenoid is engaging?
easy answer, pump and dump, just wrap your PTO shaft!
baajaa is offline   Reply With Quote Quick reply to this message
Old 11-02-2011, 09:13 PM   #3 (permalink)
Full_Tilt's Avatar
Rep Power: 26 Full_Tilt is on a level you can only DREAM about! ! !Full_Tilt is on a level you can only DREAM about! ! !Full_Tilt is on a level you can only DREAM about! ! !
Full_Tilt is on a level you can only DREAM about! ! !Full_Tilt is on a level you can only DREAM about! ! !Full_Tilt is on a level you can only DREAM about! ! !Full_Tilt is on a level you can only DREAM about! ! !Full_Tilt is on a level you can only DREAM about! ! !Full_Tilt is on a level you can only DREAM about! ! !Full_Tilt is on a level you can only DREAM about! ! !Full_Tilt is on a level you can only DREAM about! ! !Full_Tilt is on a level you can only DREAM about! ! !Full_Tilt is on a level you can only DREAM about! ! !Full_Tilt is on a level you can only DREAM about! ! !Full_Tilt is on a level you can only DREAM about! ! !Full_Tilt is on a level you can only DREAM about! ! !
Cam timing. Check it.
Old 11-02-2011, 09:37 PM   #4 (permalink)
braxtonsag's Avatar
the car gets noticeably louder. So I'm ALMOST positive.
Would it really jump a tooth that easy? This timing cover is going to be a bitch to pull off
Old 11-02-2011, 09:46 PM   #5 (permalink)
Rep Power: 0 Darkman6909 is  EVIL !!!!!!!!
Maybe its time for a d16z6 swap
Darkman6909 is offline   Reply With Quote Quick reply to this message
Old 11-02-2011, 10:01 PM   #6 (permalink)
Full_Tilt's Avatar
It can jump, yes.
Its easy to check. just put the engine at TDC and the pull the valve cover off. the cam gears have little marks that point inward at each other and the arrows should be pointed vertically.
Old 11-02-2011, 10:05 PM   #7 (permalink)
Black91CRXsi's Avatar
Rep Power: 33 Black91CRXsi is on a level you can only DREAM about! ! !Black91CRXsi is on a level you can only DREAM about! ! !Black91CRXsi is on a level you can only DREAM about! ! !Black91CRXsi is on a level you can only DREAM about! ! !
Black91CRXsi is on a level you can only DREAM about! ! !Black91CRXsi is on a level you can only DREAM about! ! !Black91CRXsi is on a level you can only DREAM about! ! !Black91CRXsi is on a level you can only DREAM about! ! !Black91CRXsi is on a level you can only DREAM about! ! !Black91CRXsi is on a level you can only DREAM about! ! !Black91CRXsi is on a level you can only DREAM about! ! !
iTrader Score: 17 reviews
B-series...lol
91' CRX Si All motor A6 running 14.67@93.87mph (old build).
14' Accord Sport 6spd, K-sports, 19" TSW's, K&N typhoon and Borla axle back
"I don't want it. I just need it. To feel, to breathe, to know I'm alive."
R.I.P - Pat Primmer
Beat them, cheat on them, treat them like shit and you'll get a hot woman that won't ever leave you. Women are a stupid breed that don't use fucking sense.
Black91CRXsi is offline   Reply With Quote Quick reply to this message
Old 11-02-2011, 10:09 PM   #8 (permalink)
braxtonsag's Avatar
It can jump, yes.
I knew it could jump I just don't see how stock motor could put enough torque to make it jump. I will definately check though..
Old 11-02-2011, 10:22 PM   #9 (permalink)
psjones13's Avatar
Rep Power: 10 psjones13 It's a JDM Star Bitches....
Originally Posted by braxtonsag View Post
Litteraly I'm not exagerating when I say it felt like a sort of turbo lag. .. its litterally a massive disappointment.
Literally
lol
Maybe try putting the p30 back in it and watch those afr's when its pulling hard so you have something to compare against. Good luck
A.A.S. degree in Motorsports Technology and Automotive Service as of May 2015
DSM Small 16g - 10:1 cr d16z6 - 91 sedan
R.I.P. PatPrimmer
psjones13 is offline   Reply With Quote Quick reply to this message
Old 11-02-2011, 10:27 PM   #10 (permalink)
baajaa's Avatar
My exhaust tone makes 3 noticeable changes in exhaust note at full throttle. It changes at 4500 and 6500. Yet there's no vtack because it's a y7. Check to see if the solenoid is getting power.
Old 11-02-2011, 10:28 PM   #11 (permalink)
jumpncrash's Avatar
Rep Power: 7 jumpncrash smells like Boratjumpncrash smells like Boratjumpncrash smells like Boratjumpncrash smells like Boratjumpncrash smells like Borat
Originally Posted by psjones13 View Post
Literally
lol
He said it doesn't pull hard with the p30 now either, so that won't help
jumpncrash is offline   Reply With Quote Quick reply to this message
Old 11-02-2011, 10:50 PM   #12 (permalink)
v8killaz's Avatar
Rep Power: 10 v8killaz is almost there....
v8killaz is almost there....v8killaz is almost there....v8killaz is almost there....v8killaz is almost there....v8killaz is almost there....v8killaz is almost there....v8killaz is almost there....v8killaz is almost there....v8killaz is almost there....v8killaz is almost there....
check timing and compression
most epic thread-
v8killaz is offline   Reply With Quote Quick reply to this message
Old 11-03-2011, 10:49 AM   #13 (permalink)
braxtonsag's Avatar
I checked timing, and what a surprise.. The crank pulley mark is dead on with the timing cover, but my cam gears "up" mark on BOTH cams are facing downward.. wtf.. Is it even supposed to run like that?
Old 11-03-2011, 10:58 AM   #14 (permalink)
braxtonsag's Avatar
Wait im a dumbass... brb. let me go spin the crank around 1 more time
Old 11-03-2011, 10:58 AM   #15 (permalink)
Im Bringing TSEXY Back!
T-MacK's Avatar
Rep Power: 30 T-MacK is on a level you can only DREAM about! ! !T-MacK is on a level you can only DREAM about! ! !T-MacK is on a level you can only DREAM about! ! !
T-MacK is on a level you can only DREAM about! ! !T-MacK is on a level you can only DREAM about! ! !T-MacK is on a level you can only DREAM about! ! !T-MacK is on a level you can only DREAM about! ! !T-MacK is on a level you can only DREAM about! ! !T-MacK is on a level you can only DREAM about! ! !T-MacK is on a level you can only DREAM about! ! !
Big surprise you bought a motor offine and I bet it was guranteed to have less then 40,000kms?
The first thing anybody should do if you are forced to buy an engine offline is comp test it. Find out what condition the engine is really in. 9 times out of 10 they will/should get a mild rebuild.
I would check the timing then once the timing cover is off just keep the bottom piece on and leave the top open. This will give you access to your cangears without the hassle and the bottom piece on will keep rocks out of your timing belt.
Hella Flush.....Were waiting!
Xbox gamer tag: THErealTMACK
T-MacK is offline   Reply With Quote Quick reply to this message
Old 11-03-2011, 11:21 AM   #16 (permalink)
Tibby's Avatar
Rep Power: 19 Tibby is the fucking MAN!!!!Tibby is the fucking MAN!!!!Tibby is the fucking MAN!!!!
Tibby is the fucking MAN!!!!Tibby is the fucking MAN!!!!Tibby is the fucking MAN!!!!Tibby is the fucking MAN!!!!Tibby is the fucking MAN!!!!Tibby is the fucking MAN!!!!Tibby is the fucking MAN!!!!Tibby is the fucking MAN!!!!Tibby is the fucking MAN!!!!
comp test maybe hg take off rad cap start car if water shoots out its hg
ign timing?
ak riding shotgun literally
autox/ touge ej1
Built 12.5 d., ac, pic selects, itr sway, wide wheels, more bracing than a dentist office lol
09 Chevy 3500hd crew cab long bed 4x4 just because I felt like it
Tibby is offline   Reply With Quote Quick reply to this message
Old 11-03-2011, 11:27 AM   #17 (permalink)
braxtonsag's Avatar
Hmotorsonline is a very reputable company though? Thats actually why i went to them. And the timing is DEAD on.. The car ran amazing for a couple days and now its very sluggish after switching ecus, even after i switched back it was still sluggish. I just dont understand how that could have affected anything.
Old 11-03-2011, 11:36 AM   #18 (permalink)
Rep Power: 22 xile6 is the fucking MAN!!!!xile6 is the fucking MAN!!!!xile6 is the fucking MAN!!!!xile6 is the fucking MAN!!!!
What was the compression? Does it smoke any?
Also if you where running the p28 without a b16 map on it then you where leaning out the motor. Which could of caused some problems.
But yea check the comp and maybe do a leak down test to see if the rings are going. Also check your plugs if they dont fire you dont get smooth power.
Old 11-03-2011, 11:43 AM   #19 (permalink)
Tibby's Avatar
reputable yes but my zc used a quart every 3 weeks which dont seem like alot but i think it is
autox/ touge ej1
Old 11-03-2011, 11:57 AM   #20 (permalink)
v8killaz's Avatar
yeah i had a b16 from hmo and it was the best running and looking b16 i have ever seen in my life period. you couldnt even hear it, it was quiet. and the block was shiny like it came from the factory. seemed like it had 5k miles on it. i wouldnt doubt it either
they put the hmo stamp on their engines.
line up both cam gear up first.
most epic thread-
iconAll times are GMT -8. The time now is 07:59 PM. | Welcome to Forum, please register to access all of our features.
