d16y8 head build or no?? - D-series.org
Go Back   D-series.org Everything Else n00b Forum
Old 03-17-2017, 04:59 PM   #1 (permalink)
Rep Power: 0 bamboost1.6 is nobody
Default d16y8 head build or no??
I'm building a boosted y8. block is vitara pistons 75.5 and manley h beams
my power goal is 450.
I'm reading a lot that i should keep my head stock and its do able.
any recomendations or should i just leave it stock?
bamboost1.6 is offline   Reply With Quote Quick reply to this message
Old 03-25-2017, 01:48 PM   #2 (permalink)
Rep Power: 0 evotec1 is nobody
Cleaning up the casting never hurts, i wouldnt make major changes though u dont wanna hurt swirl
93 dx coupe jdm d15b nonvtec + si manual swap + PS -> manual rack swap + AC delete + Bosch WBO2 + MOATES
Theodore Raye Rupert is happy and healthy!
evotec1 is offline   Reply With Quote Quick reply to this message
Old 03-26-2017, 10:06 AM   #3 (permalink)
FarmerD is on a level you can only DREAM about! ! !FarmerD is on a level you can only DREAM about! ! !FarmerD is on a level you can only DREAM about! ! !FarmerD is on a level you can only DREAM about! ! !FarmerD is on a level you can only DREAM about! ! !FarmerD is on a level you can only DREAM about! ! !FarmerD is on a level you can only DREAM about! ! !
I have seen a stock Y8 head with stock springs (intake springs on both sides) and stock ports, and a stock cam, make 480whp, with a genuine t3/t4 50 trim with a go autoworks 82 ar hotside. It was crazy. Car ran lots of 10s and trapped 139-136mph. It revved to around 8200rpm.
Old 03-26-2017, 11:03 AM   #4 (permalink)
Rep Power: 5 Animag771 will become famous soon enoughAnimag771 will become famous soon enoughAnimag771 will become famous soon enough
I still have plenty to learn, but from my understanding, you should be able to reach your goal with a stock head. Porting will just make it a little easier... If done correctly. If you are doing your own porting, I would stick to just cleaning up the casting marks (as already suggested) to get a little better flow. I wouldn't take off any more than that, because without a flow bench or prior porting experience there is no real way of telling if you are helping or hurting your flow.
Animag771 is offline   Reply With Quote Quick reply to this message
Old 04-04-2017, 09:29 AM   #5 (permalink)
D-series SoCal Division
AJAY's Avatar
Rep Power: 14 AJAY is the fucking MAN!!!!AJAY is the fucking MAN!!!!AJAY is the fucking MAN!!!!
AJAY is the fucking MAN!!!!AJAY is the fucking MAN!!!!AJAY is the fucking MAN!!!!AJAY is the fucking MAN!!!!AJAY is the fucking MAN!!!!AJAY is the fucking MAN!!!!AJAY is the fucking MAN!!!!AJAY is the fucking MAN!!!!
Originally Posted by jtmurr02 View Post
I have a ton of heads sitting around if you need one for the build or want a spare!
867-5309
Where's Batman?
1993 civic dx hatch
jdm d15b vtec obd1
web level 1 cam
15g turbo 13 psi
AJAY is offline   Reply With Quote Quick reply to this message
Old 04-04-2017, 06:08 PM   #6 (permalink)
Rep Power: 50 slo_eg8 is on a level you can only DREAM about! ! !slo_eg8 is on a level you can only DREAM about! ! !
slo_eg8 is on a level you can only DREAM about! ! !slo_eg8 is on a level you can only DREAM about! ! !slo_eg8 is on a level you can only DREAM about! ! !slo_eg8 is on a level you can only DREAM about! ! !slo_eg8 is on a level you can only DREAM about! ! !slo_eg8 is on a level you can only DREAM about! ! !slo_eg8 is on a level you can only DREAM about! ! !slo_eg8 is on a level you can only DREAM about! ! !slo_eg8 is on a level you can only DREAM about! ! !slo_eg8 is on a level you can only DREAM about! ! !slo_eg8 is on a level you can only DREAM about! ! !slo_eg8 is on a level you can only DREAM about! ! !slo_eg8 is on a level you can only DREAM about! ! !slo_eg8 is on a level you can only DREAM about! ! !slo_eg8 is on a level you can only DREAM about! ! !
Originally Posted by AJAY View Post
Where's Batman?
totaled. 93 EJ2
NEW 95 ej1
d16y7 block with z6 head
y7 transmission
ls meshies, oem wing, blacked out tails with h.i.d head lights
HTML code is On
iconAll times are GMT -8. The time now is 03:48 PM. | Welcome to Forum, please register to access all of our features.
