How much compression could I gain by milling the head? - D-series.org
Go Back   D-series.org Everything Else n00b Forum
Old 02-28-2011, 02:41 PM   #1 (permalink)
qqq
Rep Power: 7 qqq is nobody
Default How much compression could I gain by milling the head?
D16z6 engnie
Vitara pistons
full length H beam rods
what is the most compression I could gain by milling the head.. ?
qqq is offline   Reply With Quote Quick reply to this message
Old 02-28-2011, 02:46 PM   #2 (permalink)
sick1camcivic's Avatar
Rep Power: 14 sick1camcivic is a Top Aussie
sick1camcivic is a Top Aussiesick1camcivic is a Top Aussiesick1camcivic is a Top Aussiesick1camcivic is a Top Aussiesick1camcivic is a Top Aussiesick1camcivic is a Top Aussiesick1camcivic is a Top Aussiesick1camcivic is a Top Aussiesick1camcivic is a Top Aussiesick1camcivic is a Top Aussiesick1camcivic is a Top Aussie
Honda D-Series Compression Calculator by ZealAutowerks
RIP <3Jayda<3 2 yr old Boxer 8-14-2009
teamdohc.org
95 civic coupe ex. Vitara-hbeam Z6
New Project Built Turbo F2B F22A nonvtec into civic
93 Accord SE 4dr black9stock)
Owner @ Grab-a-Nekbrace ENT like us on Facebook!
sick1camcivic is offline   Reply With Quote Quick reply to this message
Old 02-28-2011, 02:50 PM   #3 (permalink)
qqq
Originally Posted by sick1camcivic View Post
I didn't build my engine, so I don't no the variables...
I believe its just a regular Z6 head, the engine builder has not milled anything from it .
Old 02-28-2011, 02:57 PM   #4 (permalink)
if its an all stock z nothing cut with vitaras then its 7:5:1
teamdohc.org
Old 02-28-2011, 03:06 PM   #5 (permalink)
patprimmer's Avatar
It kinda depends on how much you take off the head and if you also take something off the block.
If you have no data you can not do your sums.
Regards
Pat. RIP Feb 22, 2013.
my CRX thread
my intro
Old 02-28-2011, 07:48 PM   #6 (permalink)
qqq
yes i know what my compression is now.
Is there a limit to how much milling can be done?
how much compression could I gain at the maximum amount of milling done
Old 02-28-2011, 07:56 PM   #7 (permalink)
Rep Power: 0 sxysweed It's a JDM Star Bitches....
sxysweed It's a JDM Star Bitches....sxysweed It's a JDM Star Bitches....
IIRC, the combustion chamber loses ~4.3cc of volume for every 1mm milled.
Plug that into the zeal calculator (take away from the combustion chamber volume if milling head).
But that's only constant if you aren't cutting material away from the combustion chamber (like 1mm of a Z6 head should reduce the volume by 4.3cc, but once you hit the quench areas, it's not a linear decrease in volume).
sxysweed is offline   Reply With Quote Quick reply to this message
Old 02-28-2011, 08:06 PM   #8 (permalink)
Full_Tilt's Avatar
Rep Power: 26 Full_Tilt is on a level you can only DREAM about! ! !Full_Tilt is on a level you can only DREAM about! ! !Full_Tilt is on a level you can only DREAM about! ! !
Full_Tilt is on a level you can only DREAM about! ! !Full_Tilt is on a level you can only DREAM about! ! !Full_Tilt is on a level you can only DREAM about! ! !Full_Tilt is on a level you can only DREAM about! ! !Full_Tilt is on a level you can only DREAM about! ! !Full_Tilt is on a level you can only DREAM about! ! !Full_Tilt is on a level you can only DREAM about! ! !Full_Tilt is on a level you can only DREAM about! ! !Full_Tilt is on a level you can only DREAM about! ! !Full_Tilt is on a level you can only DREAM about! ! !Full_Tilt is on a level you can only DREAM about! ! !Full_Tilt is on a level you can only DREAM about! ! !Full_Tilt is on a level you can only DREAM about! ! !
Getting longer rods would be an infinitely better option imo
Old 03-01-2011, 12:57 AM   #9 (permalink)
Bishop's Avatar
Rep Power: 7 Bishop is learning the way of the DBishop is learning the way of the D
oh boy, already a thread for this, except my question is:
how much can i mill the head before the pistons and valves get to close for comfort?
stock cam for now but will upgrade to turbo cam later.
Getting out of Honda
Bishop is offline   Reply With Quote Quick reply to this message
Old 03-01-2011, 01:27 AM   #10 (permalink)
patprimmer's Avatar
You can mill the head until the deck gets to thin or the cut gets to close to the valve seats, whichever happens first. With a D it is normally the cut gets to close to the seats. You can check this with a depth mic if the head is off.
Piston to valve depends on a l;ot of things, not the least of which is which head and which pistons you have.
Regards
my CRX thread
my intro
Old 03-01-2011, 07:20 AM   #11 (permalink)
The_Acid_Beaver's Avatar
The Vitaras should clear anything you could take off the head with almost any cam. The dish is )(#$)(#$ huge.
RTFM. No, really. Do it.
Old 03-01-2011, 08:45 AM   #12 (permalink)
Bishop's Avatar
thanks for the info guys
Old 03-01-2011, 08:48 AM   #13 (permalink)
90civichillclimber's Avatar
Rep Power: 14 90civichillclimber is hot as a volcano90civichillclimber is hot as a volcano
90civichillclimber is hot as a volcano90civichillclimber is hot as a volcano90civichillclimber is hot as a volcano90civichillclimber is hot as a volcano90civichillclimber is hot as a volcano90civichillclimber is hot as a volcano90civichillclimber is hot as a volcano90civichillclimber is hot as a volcano90civichillclimber is hot as a volcano90civichillclimber is hot as a volcano90civichillclimber is hot as a volcano
D16z6 engnie
Vitara pistons
I'm getting 10.9 -1 compression with vitara pistons, fjt rods, and a milled y8 head. The Zeal calculator is wrong when milling the y8 head. You have to cc it when done.
1990 Honda Civic Si Hillclimb/twisty track
2014 Fiesta ST
90civichillclimber is offline   Reply With Quote Quick reply to this message
Old 03-01-2011, 09:16 AM   #14 (permalink)
Bizzar's Avatar
Rep Power: 38 Bizzar is on a level you can only DREAM about! ! !Bizzar is on a level you can only DREAM about! ! !Bizzar is on a level you can only DREAM about! ! !Bizzar is on a level you can only DREAM about! ! !Bizzar is on a level you can only DREAM about! ! !
Bizzar is on a level you can only DREAM about! ! !Bizzar is on a level you can only DREAM about! ! !Bizzar is on a level you can only DREAM about! ! !Bizzar is on a level you can only DREAM about! ! !Bizzar is on a level you can only DREAM about! ! !Bizzar is on a level you can only DREAM about! ! !Bizzar is on a level you can only DREAM about! ! !Bizzar is on a level you can only DREAM about! ! !Bizzar is on a level you can only DREAM about! ! !Bizzar is on a level you can only DREAM about! ! !Bizzar is on a level you can only DREAM about! ! !Bizzar is on a level you can only DREAM about! ! !Bizzar is on a level you can only DREAM about! ! !
iTrader Score: 15 reviews
Not enough to feel a difference.
16.5 psi full interior run
7.80 @ 88mph 1/8 mile.
297 Mustang Dyno whp @ 20psi
Bizzar is offline   Reply With Quote Quick reply to this message
Old 03-01-2011, 12:53 PM   #15 (permalink)
patprimmer's Avatar
You can actually measure how much to take off to get the ccs you want by setting the head upside down and PERFECTLY LEVEL on a bench then filling it with the correct volume of fluid. Make sure you use the same valves already seated or at least close to seated and the same plugs for real accuracy.
Measure from the deck to the fluid with a depth mike. Allow for the meniscus. Measure in several places to verify level.
Observe the amount the fluid covers the valve seat.
Regards
my CRX thread
my intro
Old 03-01-2011, 01:40 PM   #16 (permalink)
qqq
how do you find the 10:1 compression as compared to a 7.5:1 compression.
does the car feel much more responsive?
does the turbo spool noticeably quicker?
does the car feel much quicker out of boost?
Old 03-01-2011, 01:47 PM   #17 (permalink)
twitch927's Avatar
Rep Power: 7 twitch927 will become famous soon enoughtwitch927 will become famous soon enoughtwitch927 will become famous soon enough
How many times do i shit in one years time?
when you're able to answer that i'll answer your question.
i haz a b-series.....shoot me
twitch927 is offline   Reply With Quote Quick reply to this message
Old 03-01-2011, 02:12 PM   #18 (permalink)
Well, how often do you shit?
Old 03-01-2011, 02:18 PM   #19 (permalink)
This is the way I find out how much to cut.
Don't know yet. Still not completed. I hope to have it in the car in the next two weeks. Race season is here in 5 weeks.
The answers should be:
Yes
don't know
yes
I'm hoping to make more power with less boost and lots of torque down below 2500 rpm. I should have instant spool with the turbo I'm running.
2014 Fiesta ST
Old 03-01-2011, 03:23 PM   #20 (permalink)
qqq
90civicclimber, do you have the standard length rods with vitara pistons?
HTML code is On
iconAll times are GMT -8. The time now is 03:22 PM. | Welcome to Forum, please register to access all of our features.
