Piston in caliper won't collapse...pls help me - D-series.org
Go Back   D-series.org Everything Else n00b Forum
Old 06-19-2009, 03:29 PM   #1 (permalink)
91 Si love in the 209's Avatar
Rep Power: 9 91 Si love in the 209 is fly like an eagle91 Si love in the 209 is fly like an eagle91 Si love in the 209 is fly like an eagle91 Si love in the 209 is fly like an eagle91 Si love in the 209 is fly like an eagle91 Si love in the 209 is fly like an eagle91 Si love in the 209 is fly like an eagle91 Si love in the 209 is fly like an eagle91 Si love in the 209 is fly like an eagle91 Si love in the 209 is fly like an eagle91 Si love in the 209 is fly like an eagle91 Si love in the 209 is fly like an eagle
Default Piston in caliper won't collapse...pls help me
I'm trying to change pads on a rear disc brake swap. I think they're 91 integra rear discs but the 94 pads were a match. The point is that my piston won't retract as I've done time and time again. It goes in slightly then stops. Used a c-clamp and is there something I'm missing like something to do with the e-brake(which isn't hooked up.) Is it just a bitch or is this a sign they're bad? Please help I need my car on the road in 3.5 hours.
91 Si love in the 209 is offline   Reply With Quote Quick reply to this message
Old 06-19-2009, 03:32 PM   #2 (permalink)
cjhef2's Avatar
Rep Power: 9 cjhef2 is starting to learn the ropescjhef2 is starting to learn the ropescjhef2 is starting to learn the ropescjhef2 is starting to learn the ropescjhef2 is starting to learn the ropescjhef2 is starting to learn the ropes
could need a rebuil kit real easy to do tho and cheap
cjhef2 is offline   Reply With Quote Quick reply to this message
Old 06-19-2009, 03:41 PM   #3 (permalink)
jls_frog's Avatar
Rep Power: 8 jls_frog is learning the way of the Djls_frog is learning the way of the D
its not the type of caliper that u have to turn the piston to go down is it, does it have a plus sign cut into the piston face
jls_frog is offline   Reply With Quote Quick reply to this message
Old 06-19-2009, 03:53 PM   #4 (permalink)
D-series.org Sponsor
fireant's Avatar
Rep Power: 14 fireant is a name known to allfireant is a name known to allfireant is a name known to allfireant is a name known to allfireant is a name known to allfireant is a name known to allfireant is a name known to allfireant is a name known to allfireant is a name known to allfireant is a name known to all
For the 91 rear discs, you use a big flathead screwdriver or the tip of a crowbar to twist the piston just like a screw and it will go in. It's difficult to do, and it takes forever, but that's how they are made...they arent like front brake calipers that just float when you push them. Make sure you do not bind up the seal when you are turning it, lubing it first will help. Also make certain the little TAB on the back of the brake pad goes inside the groove or it wont sit flat against the rotor!
'01 BMW Z3 coupe 3.0i :: '00 Civic DX HB :: '96 Ford Ranger 4.0
My old CRX burned in the wildfire that wiped out a big swath of central TX back in Sept 2011.
fireant is offline   Reply With Quote Quick reply to this message
Old 06-19-2009, 04:30 PM   #5 (permalink)
has the plus sign. passenger side went down and drivers won't. Gonna try harder. If it has bound is there any recourse?
Old 06-20-2009, 12:16 AM   #6 (permalink)
Rep Power: 100 transzex is on a level you can only DREAM about! ! !transzex is on a level you can only DREAM about! ! !transzex is on a level you can only DREAM about! ! !
transzex is on a level you can only DREAM about! ! !transzex is on a level you can only DREAM about! ! !transzex is on a level you can only DREAM about! ! !transzex is on a level you can only DREAM about! ! !transzex is on a level you can only DREAM about! ! !transzex is on a level you can only DREAM about! ! !transzex is on a level you can only DREAM about! ! !
crank it in, C clamp is useless.
Old 06-20-2009, 01:45 AM   #7 (permalink)
Live,love,laugh,be real
4Door's Avatar
Rep Power: 36 4Door is on a level you can only DREAM about! ! !4Door is on a level you can only DREAM about! ! !
4Door is on a level you can only DREAM about! ! !4Door is on a level you can only DREAM about! ! !4Door is on a level you can only DREAM about! ! !4Door is on a level you can only DREAM about! ! !4Door is on a level you can only DREAM about! ! !4Door is on a level you can only DREAM about! ! !4Door is on a level you can only DREAM about! ! !
iTrader Score: 20 reviews
do you have what looks like a big + sign..? if so you need to screw it in after its pushed back in...
R.I.P. my mom - I miss you
10/3/1945-6/16/2007
R.I.P. - MiloReaper & Pat Primmer
96' CE1 Lx - Wags
04' Pilot EXL - Black Pile - Love it
is your friend, try it
[youtube ][ /youtube]
4Door is offline   Reply With Quote Quick reply to this message
Old 06-20-2009, 02:46 AM   #8 (permalink)
Rep Power: 0 fastfood is nobody
Yup, you don't push it in, you screw it in.
fastfood is offline   Reply With Quote Quick reply to this message
Old 06-20-2009, 08:33 AM   #9 (permalink)
I got the passenger to go down with something in the garage. But I had to get the tool from autozone and it worked. Thnaks everyone.
HTML code is On
iconAll times are GMT -8. The time now is 08:03 PM. | Welcome to Forum, please register to access all of our features.
