D15b7 stock head bolts torque specs - D-series.org
Old 05-18-2008, 01:41 PM   #1 (permalink)
94..civic..ex's Avatar
Rep Power: 12 94..civic..ex is learning the way of the D94..civic..ex is learning the way of the D
Default D15b7 stock head bolts torque specs
yea im reusing them lol, but i need to know the torque specs and sequence of putting them back in. dont have a manual where im at. its a stock d15b7 engine for a del sol. so anyone with a book that can help i need it!
94..civic..ex is offline   Reply With Quote Quick reply to this message
Old 05-18-2008, 02:22 PM   #2 (permalink)
a_691's Avatar
Rep Power: 10 a_691 is learning the way of the Da_691 is learning the way of the D
first step-22 ft lbs
second step 49 ft lbs
a_691 is offline   Reply With Quote Quick reply to this message
Old 05-18-2008, 03:04 PM   #3 (permalink)
ddd4114's Avatar
Rep Power: 18 ddd4114 is hot as a volcanoddd4114 is hot as a volcano
ddd4114 is hot as a volcanoddd4114 is hot as a volcanoddd4114 is hot as a volcanoddd4114 is hot as a volcanoddd4114 is hot as a volcanoddd4114 is hot as a volcanoddd4114 is hot as a volcano
Send a message via ICQ to ddd4114 Send a message via AIM to ddd4114 Send a message via MSN to ddd4114 Send a message via Yahoo to ddd4114
Dan
Read My Stuff:
ddd4114 is offline   Reply With Quote Quick reply to this message
Old 06-21-2008, 02:32 PM   #4 (permalink)
Rep Power: 0 90 CRX zc is nobody
Question head tightening specs.
Originally Posted by ddd4114 View Post
Ok I've been looking around everywhere trying to find the torque settings to tighten my head down to my block. So far no such luck. I have a 90 crx si with a 90 jdm dohc zc in it. I have not separated the block from the head yet but I'm planning on rebuilding the whole motor with all new gaskets, seals, pistons, and hoses. As for right now my head gasket is leaking a little and I want to tighten it to the specified settings. could somebody help me please?
90 CRX zc is offline   Reply With Quote Quick reply to this message
Old 06-21-2008, 02:35 PM   #5 (permalink)
ddd4114's Avatar
http://www.hondahookup.com/manuals/
Dan
Read My Stuff:
Old 06-21-2008, 03:09 PM   #6 (permalink)
OMG TOTALLY COOL TITLE!!!!
si-hatch86's Avatar
Rep Power: 28 si-hatch86 is on a level you can only DREAM about! ! !si-hatch86 is on a level you can only DREAM about! ! !si-hatch86 is on a level you can only DREAM about! ! !
iTrader Score: 15 reviews
Send a message via AIM to si-hatch86 Send a message via MSN to si-hatch86 Send a message via Yahoo to si-hatch86
http://www.honda-tech.com/zerothread?id=1169414
This is for everyone, I made this torque spec thread since I and many others here always ask about torque specs. Plus I myself, find myself looking trough all my Haynes and Chilton books for torque specs while I know I can make a list like this one to make it easier. I hope this can be some help and it can be made a sticky on these boards.
These torque specs are straight from the Chilton and Haynes manuals. I might also add some ARP torque specs as well. I still need to add more as you can see Ive been a little busy so as soon as I can I will add more. I would also be cool if others can add to it as well.
ALL TOQUE SPECS ARE IN FT-LB.
A/T Tranny Drain plug......................... 29
M/T Tranny Drain and fill plug..............30-40
Wheel Lug Nuts....................................80
Fuel Filter
Banjo Bolt............................................16
Service Bolt.........................................9
Clamp Bolt...........................................9
Valve cover Bolts...................................7
Spark Plugs..........................................13
Cam Gear Bolt.......................................27
Cam cover crown nuts.............................7
Crank(vibration) damper bolt...................119
Cylinder Head Studs....................1st step..22...2nd..49
Flywheel Bolts M/T................................76
Drive Plate bolts for A/T........................54
Header Bolts to Cylinder Head................22
Header to downpipe bolts.......................33
Intake Manifold Bolts..............................16
Oil Pan bolts...........................................9
Oil pick up tube bolts..............................17
Oil Pump to engine block bolts/nuts...........9
Oil Pump Screen bolts..............................8
Oil pump cover Screws.............................5
Oil filter Housing Bolts..............................9
Rocker arm shaft pedestal bolts................16
Rocker arm shaft end caps bolts................9
Timing belt adjstment bolt.........................31
Rod Bolts............................................. ....23
Main Bearings cap bolts
Separate caps and bridge..........................48
One piece cap assembly............................33
Water pump pulley bolts.............................9
Thersmostat housing bolts..........................9
Water pump attaching bolts.........................9
Fuel injection service bolts
88-90................................................ ......9
91up.............................................. ..........11
Throttle Body nuts.....................................16
Fuel Rail nut..............................................9
Manual Transmission
Countershaft locknuts................................65
End cover bolts.........................................9
Selector arm holder bolts...........................9
Tranny case to Flywhee housing..................20
Tranny to engine bolts
4 speed............................................. ........33
5 speed............................................. ........50
Clutch pressure plate bolts...........................19
Release fork bolts........................................22
Driveaxle/hub nuts.......................................134
Brake hose to caliper banjo bolts (front/Rear)...25
Master Cylinder Mounting nuts.......................11
Brake Booster mounting nuts.........................9
RIP Pat Primmer
RIP MILO
si-hatch86 is offline   Reply With Quote Quick reply to this message
iconAll times are GMT -8. The time now is 11:36 AM. | Welcome to Forum, please register to access all of our features.
