Honda Engine D16Y3 Interfernce/Non-Interference engine - D-series.org
Old 03-08-2008, 01:48 PM   #1 (permalink)
Rep Power: 0 jbleakley is nobody
Question Honda Engine D16Y3 Interfernce/Non-Interference engine
My 1997 Rover has a Honda D16Y3 engine(Honda owned Rover thru the 1990's) and the timing belt just snapped. My wife was driving it at low speed at the time...I thought it was an electrical problem at the time and was checking the Distributor when I realized the Rotor was not turning as I hand cranked the crankshaft...I took off the rocker cover and discovered the timing belt had broken...it had seemed relatively easy to hand crank the engine and there seemed no obvious damage to the valve/rocker assembly...Do I need to take the head off to do a visual or can I just go ahead and change the belt...so ,is this engine an Interference or Non-interference engine...thanks for any help
jbleakley is offline   Reply With Quote Quick reply to this message
Old 03-08-2008, 06:36 PM   #2 (permalink)
RandysSOHC's Avatar
Rep Power: 11 RandysSOHC is a name known to allRandysSOHC is a name known to allRandysSOHC is a name known to allRandysSOHC is a name known to allRandysSOHC is a name known to allRandysSOHC is a name known to allRandysSOHC is a name known to allRandysSOHC is a name known to all
iTrader Score: 26 reviews
this would be an interference engine...
but really all you gotta do is take the head off & see if you bent the valves..(which is most likley...)
if so...buy another head...possible a cheap junkyard head...have it checked if you could (to make sure the head itself is not bent)
buy a new head gasket
put the head on
put the engine in time & put on a new timing belt & your good to go
RandysSOHC is offline   Reply With Quote Quick reply to this message
Old 03-09-2008, 01:37 PM   #3 (permalink)
13g-crx's Avatar
Rep Power: 15 13g-crx It's a JDM Star Bitches....
13g-crx It's a JDM Star Bitches....13g-crx It's a JDM Star Bitches....13g-crx It's a JDM Star Bitches....13g-crx It's a JDM Star Bitches....13g-crx It's a JDM Star Bitches....
I've always said that it will always bend a valve, but I've been proven wrong twice in the last month. Go figure.
13g-crx is offline   Reply With Quote Quick reply to this message
Old 03-09-2008, 11:44 PM   #4 (permalink)
hondainspired's Avatar
Rep Power: 13 hondainspired is trying to make new friends
my buddy bought an a6 that had broken a timing belt at idle. Put a new belt, tensioner and water pump and runs to this day like a top.
PLAINFIELD, IL
SHOP SOL- TurboD in progress
hondainspired is offline   Reply With Quote Quick reply to this message
Old 03-31-2008, 06:35 PM   #5 (permalink)
sprayedsol's Avatar
Rep Power: 0 sprayedsol is nobody
yea mine snapped this weekend and i had no bent valves either, its kinda hit or miss i guess
sprayedsol is offline   Reply With Quote Quick reply to this message
Old 03-31-2008, 06:40 PM   #6 (permalink)
tepco's Avatar
Rep Power: 10 tepco will become famous soon enoughtepco will become famous soon enoughtepco will become famous soon enough
Put pressure in the cylinder rotate it to TDC and see if it holds it, or not.
Do it right the first time. Or as best as you can........
I run 2stroke oil in my crank case because it burns cleaner
Rep Up!!
tepco is offline   Reply With Quote Quick reply to this message
Old 05-05-2011, 07:18 PM   #7 (permalink)
strategy400's Avatar
Rep Power: 0 strategy400 is nobody
Found this thread through a search so I'm going to revive it for info purposes. Just had my D engine rebuilt (had 200k) and the shop discovered a bent valve. I'd been driving it this way forever, never broke a belt that I know of but I bought the car at 135k. Anyway it did make an annoying tapping. Couldn't tell by looking at the valve that it was bent except that it was worn funny where it seats. I tested the compression before and it was ok for so many miles. I have a slight headgasket issue right before the rebuild (the reason for it) so possibly the coolant in the cylinder bent or warped the valve, however the car still ran ok except for slight coolant loss leading to overheating (never went to the red, not even white smoke out the pipe, just bubbles in the radiator).
Soaking up the cathode rays
strategy400 is offline   Reply With Quote Quick reply to this message
Old 05-05-2011, 11:27 PM   #8 (permalink)
Rep Power: 100 transzex is on a level you can only DREAM about! ! !transzex is on a level you can only DREAM about! ! !transzex is on a level you can only DREAM about! ! !
transzex is on a level you can only DREAM about! ! !transzex is on a level you can only DREAM about! ! !transzex is on a level you can only DREAM about! ! !transzex is on a level you can only DREAM about! ! !transzex is on a level you can only DREAM about! ! !transzex is on a level you can only DREAM about! ! !transzex is on a level you can only DREAM about! ! !
Might have a cracked head near a valve seat which led to the weird wear issue due to the valve seat shifting around.
BTW, Thank you for using the search function, if it brings up an old thread, then so be it!!!!
Old 05-06-2011, 07:24 AM   #9 (permalink)
I'm assuming the mach. shop checked for cracks. All they reported was a bent valve. It's a D15B7 - 95 Del Sol. They also did nothing to my cam/rocker assy. Is this normal? They said it was - "Oh you never mess with that stuff". I'm hearing a very faint tapping in the engine (800 miles so far). Could that be worn rockers?
iconAll times are GMT -8. The time now is 05:00 AM. | Welcome to Forum, please register to access all of our features.
