my car dies when i press the clutch in......anyone know why or how to fix it? - D-series.org
Old 06-01-2007, 06:18 AM   #1 (permalink)
94z6ex's Avatar
Rep Power: 12 94z6ex is a name known to all94z6ex is a name known to all94z6ex is a name known to all94z6ex is a name known to all94z6ex is a name known to all94z6ex is a name known to all94z6ex is a name known to all94z6ex is a name known to all94z6ex is a name known to all
Default my car dies when i press the clutch in......anyone know why or how to fix it?
When my car gets warmed up and the idle is steadied out and everything, when i push my clutch in, the rpms drop to about 100, sometimes even low enough to make the car die. when i let the clutck back out, the rpms go out and stable out as well.
when im driving on he interstate or around town, and im coming to a stop and press the clutch in from a roll, it will most always die, but if i just press the clutch in and pull the car out of gear and let go of the clutch and come to a stop with it out, the car has no trouble at all staying running and catching the target idle rpm....
anyone know why its doing this and how to fix it?
is it because with the clutch in, there is alot less load, and when the load is taken away the engine responds by dropping rpms.....?
thanks
My Turbo Build Thread
4 psi pull....
Me and my Dad's new G35's (mines the coupe):
94z6ex is offline   Reply With Quote Quick reply to this message
Old 06-01-2007, 06:24 AM   #2 (permalink)
SOHC_STUDENT's Avatar
Rep Power: 13 SOHC_STUDENT is approaching greatnessSOHC_STUDENT is approaching greatnessSOHC_STUDENT is approaching greatnessSOHC_STUDENT is approaching greatnessSOHC_STUDENT is approaching greatnessSOHC_STUDENT is approaching greatnessSOHC_STUDENT is approaching greatnessSOHC_STUDENT is approaching greatnessSOHC_STUDENT is approaching greatnessSOHC_STUDENT is approaching greatnessSOHC_STUDENT is approaching greatnessSOHC_STUDENT is approaching greatnessSOHC_STUDENT is approaching greatness
whats it tuned on?
D16b5/y8 - race port, Crower 3 cam, 12.5:1
42mm CBR 1000rr ITBs, Bisimoto V2, Bluegrass Muffler custom stainless 2.5" Magnaflow
SI trans- OBX LSD, Exedy 1 clutch, Fidanza 7lb flywheel
Hondata S300/P28, Innovate LC1 wideband
SOHC_STUDENT is offline   Reply With Quote Quick reply to this message
Old 06-01-2007, 06:33 AM   #3 (permalink)
Rep Power: 12 Zoobi is nobody
Seems like a similar problem i had when i swapped my fuel pump to walbro.
Thought i needed an FPR, but i just let the car rest few days and suddenly everything was ok.
But my car is stock thoug!
Zoobi is offline   Reply With Quote Quick reply to this message
Old 06-01-2007, 06:34 AM   #4 (permalink)
christopher_davis's Avatar
Rep Power: 13 christopher_davis is about to kiss the sky
christopher_davis is about to kiss the skychristopher_davis is about to kiss the skychristopher_davis is about to kiss the skychristopher_davis is about to kiss the skychristopher_davis is about to kiss the skychristopher_davis is about to kiss the sky
iTrader Score: 23 reviews
the load will affect it but there's probably a bigger underlying issue.
my rpm's drop to when the clutch is in and the car is not in nuetral.
christopher_davis is offline   Reply With Quote Quick reply to this message
Old 06-01-2007, 06:37 AM   #5 (permalink)
94z6ex's Avatar
anyone know what underlying issue could cause this.....i have a walbro fuel pump, stock fpr, but i hihgly doubt those are the culprats.
clutch is act xtreme pressure plate, performance street disc.....flywheel is stock.
4 psi pull....
Old 06-01-2007, 06:41 AM   #6 (permalink)
it could be a vacuum leak.
Old 06-01-2007, 06:47 AM   #7 (permalink)
Originally Posted by SOHC_STUDENT View Post
whats it tuned on?
Old 06-01-2007, 06:54 AM   #8 (permalink)
94z6ex's Avatar
tuned on crome pro......
4 psi pull....
Old 06-01-2007, 03:10 PM   #9 (permalink)
Rep Power: 15 gearhead98 is hot as a volcano
gearhead98 is hot as a volcanogearhead98 is hot as a volcanogearhead98 is hot as a volcanogearhead98 is hot as a volcanogearhead98 is hot as a volcanogearhead98 is hot as a volcanogearhead98 is hot as a volcanogearhead98 is hot as a volcanogearhead98 is hot as a volcanogearhead98 is hot as a volcanogearhead98 is hot as a volcanogearhead98 is hot as a volcanogearhead98 is hot as a volcano
might wanna check the iac and clean it if dirty, also check for vac leaks as said above
gearhead98 is offline   Reply With Quote Quick reply to this message
Old 06-01-2007, 06:18 PM   #10 (permalink)
94z6ex's Avatar
wouldnt vac leaks and a bad iac cause a bad idle as well?
4 psi pull....
Old 06-01-2007, 06:54 PM   #11 (permalink)
Rep Power: 12 Chiovnidca is a name known to allChiovnidca is a name known to allChiovnidca is a name known to allChiovnidca is a name known to allChiovnidca is a name known to allChiovnidca is a name known to allChiovnidca is a name known to allChiovnidca is a name known to allChiovnidca is a name known to all
Does it act like a mechanical drag pulling it down when you push the clutch? What happens if you hold the rpms higher than idle speed and press the clutch?
11.0@137
Chiovnidca is offline   Reply With Quote Quick reply to this message
Old 06-01-2007, 06:57 PM   #12 (permalink)
areskzc's Avatar
Rep Power: 14 areskzc is about to kiss the sky
areskzc is about to kiss the skyareskzc is about to kiss the skyareskzc is about to kiss the skyareskzc is about to kiss the skyareskzc is about to kiss the skyareskzc is about to kiss the sky
Send a message via MSN to areskzc
did u tuned it yourself?
REP ME I'LL REP YOU BACK
2Y 10M days without smoking
Join me
areskzc is offline   Reply With Quote Quick reply to this message
Old 06-01-2007, 08:58 PM   #13 (permalink)
94z6ex's Avatar
No, not like a mechanical drag.....its just a very weird and annoying problem thats really really hard to pinpoint anything out with it. When im just sitting still, the car idles perfect right around 700 rpms.......i press the clutch in and it drops from 0-100 in a bogging sort of state......if it doesnt die, it will stay like that for a second then it will rise back to normal idle. If i hold it in, it will stay at normal idle once it reaches it, then when i let it out, the rpms rise to about 900 rpms, stays ther for about a second and drops back down to normal idle.......
if im driving and press and hold the clutch in from a roll, it will most always die. So what i usually do is press the clutch in just long enough to get out of gear and i let it out......doing that makes it run just fine, but when im stopped i have to press the gas before the clutch to ensure it wont die.
its not a real big problem, but its a real big nucence.
no, not tuned myself, but i am watching every step of the tuning process and learning a great deal. The IAC duty cycle is actually set at 0 because anything higher will actually cause a surging idle, but i know thats not the problem because it did this before we adjusted the IAC duty cycle. We are using an ostrich to tune with.......the target cells it is seeing at idle lean out pretty bad when this glitch with the clutch happens. Adjusting the target cells actually made the rpms not drop quiet as much when the clutch was pressed in, but this was only sitting still.....while drving, it still continued to die while i pressed and held the clutch from a roll.
4 psi pull....
Old 06-02-2007, 08:21 AM   #14 (permalink)
Idling problem after fuel pump swap
This happend to me, maybe you got similar problem. Not sure but if you are interested then you can see what people said and maybe it will help you.
I doubt it! but it never hurt to read.
Old 06-02-2007, 12:57 PM   #15 (permalink)
maybe the clutch isn't disengaging all the way
Old 06-02-2007, 10:16 PM   #16 (permalink)
94z6ex's Avatar
could you explain further how you came to that please? It doesnt make sense to me because if it didnt disengauge all the way, there wouldnt really be a drastic change in load compared to when it was engauged fully........but please, if you would explain the theory more in depth. Im trying to soak in all ideas as i can right now.
thanks
4 psi pull....
Old 03-23-2015, 10:46 AM   #17 (permalink)
Rep Power: 0 keepinitG is nobody
Any remedies ever given for this issue?
keepinitG is offline   Reply With Quote Quick reply to this message
Old 03-23-2015, 10:53 AM   #18 (permalink)
Well.......
2drz6's Avatar
Rep Power: 28 2drz6 is on a level you can only DREAM about! ! !2drz6 is on a level you can only DREAM about! ! !2drz6 is on a level you can only DREAM about! ! !2drz6 is on a level you can only DREAM about! ! !
2drz6 is on a level you can only DREAM about! ! !2drz6 is on a level you can only DREAM about! ! !2drz6 is on a level you can only DREAM about! ! !2drz6 is on a level you can only DREAM about! ! !2drz6 is on a level you can only DREAM about! ! !2drz6 is on a level you can only DREAM about! ! !2drz6 is on a level you can only DREAM about! ! !2drz6 is on a level you can only DREAM about! ! !2drz6 is on a level you can only DREAM about! ! !2drz6 is on a level you can only DREAM about! ! !2drz6 is on a level you can only DREAM about! ! !2drz6 is on a level you can only DREAM about! ! !
iTrader Score: 18 reviews
You searched. That is good.
Second, are you experiencing the same exact thing the OP was?
Fucking sweet! your last names sweet!
your mother should spank your butt and put you in time out.
2drz6 is offline   Reply With Quote Quick reply to this message
Old 03-23-2015, 12:48 PM   #19 (permalink)
Whoshot's Avatar
Rep Power: 42 Whoshot is on a level you can only DREAM about! ! !Whoshot is on a level you can only DREAM about! ! !Whoshot is on a level you can only DREAM about! ! !Whoshot is on a level you can only DREAM about! ! !Whoshot is on a level you can only DREAM about! ! !Whoshot is on a level you can only DREAM about! ! !
Whoshot is on a level you can only DREAM about! ! !Whoshot is on a level you can only DREAM about! ! !Whoshot is on a level you can only DREAM about! ! !Whoshot is on a level you can only DREAM about! ! !Whoshot is on a level you can only DREAM about! ! !Whoshot is on a level you can only DREAM about! ! !Whoshot is on a level you can only DREAM about! ! !Whoshot is on a level you can only DREAM about! ! !Whoshot is on a level you can only DREAM about! ! !Whoshot is on a level you can only DREAM about! ! !Whoshot is on a level you can only DREAM about! ! !
His crank walked due to improper build from a shop. His turbo thread link told me.
I hope you dont have the same issue.
They stop laughing at your piece of shit when they can only see it through your dust.
R.I.P. - NN4S
R.I.P. - Cali Noob
You guys are gone but never forgotten, we live each day to the fullest for you, who cannot see the new day we often forget is amazing.
xbox gamer tag: angeloah
Whoshot is offline   Reply With Quote Quick reply to this message
iconAll times are GMT -8. The time now is 02:28 AM. | Welcome to Forum, please register to access all of our features.
