OBD2 engine into OBD0 car...? - D-series.org
Old 05-30-2006, 12:26 AM   #1 (permalink)
O 16581 72452 5's Avatar
Rep Power: 12 O 16581 72452 5 is learning the way of the DO 16581 72452 5 is learning the way of the D
Default OBD2 engine into OBD0 car...?
I know an OBD1 engine can be swapped no problem to OBD0, everything plugs in, just need to change the Distributer, but can an OBD2 be put in the same way and ran on OBD0?
-'95 Civic Turbocharged EX
-'90 STD Mini-Me
I hate when people list spark plugs as a "mod".
O 16581 72452 5 is offline   Reply With Quote Quick reply to this message
Old 05-30-2006, 02:00 PM   #2 (permalink)
Bump...
-'90 STD Mini-Me
Old 06-08-2006, 02:20 PM   #3 (permalink)
Rep Power: 0 dx crx is nobody
yeah i need to know this also please help
dx crx is offline   Reply With Quote Quick reply to this message
Old 06-08-2006, 03:00 PM   #4 (permalink)
DirtyDC4's Avatar
Rep Power: 14 DirtyDC4 is approaching greatnessDirtyDC4 is approaching greatnessDirtyDC4 is approaching greatnessDirtyDC4 is approaching greatnessDirtyDC4 is approaching greatnessDirtyDC4 is approaching greatnessDirtyDC4 is approaching greatnessDirtyDC4 is approaching greatnessDirtyDC4 is approaching greatnessDirtyDC4 is approaching greatnessDirtyDC4 is approaching greatnessDirtyDC4 is approaching greatnessDirtyDC4 is approaching greatness
You do more than just re-use your dizzy when you swap an OBD-1 engine into an OBD-0 car. Re-use injectors, harness, alternator, starter, etc. Same goes for OBD-2 engines in OBD-0 cars. Just re-use anything and everything you can.
DirtyDC4 is offline   Reply With Quote Quick reply to this message
Old 06-09-2006, 04:14 PM   #5 (permalink)
Rep Power: 0 grey89si is nobody
Why not just convert to OBD1? Ive had a Y8 in a CRX on OBD0 and was never happy w/the way it performed. It runs much better on OBD1 even with a virgin P28,(which youll want to rechip so you dont have to buy premium all the time, IMO the stock P28 runs a little lean past 4 grand on a Y.
grey89si is offline   Reply With Quote Quick reply to this message
Old 10-07-2006, 10:24 PM   #6 (permalink)
4thg4d
i'm in the same situation. i'm in the middle of putting a obd2b d16y7 into an obd0 90 civic sedan. what i've found so far is that i can convert to mpfi, get a obd0 to obd1 ecu jumper, use a p06 ecu, use an obd2 dis thats on the y7 (with converted plugs of course), convert alternator wiring to obd1, use my cable tranny from my d15b2 which bolts right up to the y7 and i should be set. if anyone disagrees with the compatibility of this setup i would like to hear about it
Old 10-08-2006, 11:09 AM   #7 (permalink)
jdmd16's Avatar
Rep Power: 12 jdmd16 is trying to make new friends
yeah me to i have a y8 in a 90 dx it acually performs pretty well but, what do i have to get to run obd1. i heard i just need an obd1 dizzy,4 wire o2 sensor,ecu and the conversion harness. does know of a reasonable place to get these items
Back On The Scene!!!!!!
jdmd16 is offline   Reply With Quote Quick reply to this message
Old 10-08-2006, 11:13 AM   #8 (permalink)
mmmmm sexy bay
jimmyb34's Avatar
Rep Power: 50 jimmyb34 is on a level you can only DREAM about! ! !jimmyb34 is on a level you can only DREAM about! ! !jimmyb34 is on a level you can only DREAM about! ! !jimmyb34 is on a level you can only DREAM about! ! !
jimmyb34 is on a level you can only DREAM about! ! !jimmyb34 is on a level you can only DREAM about! ! !jimmyb34 is on a level you can only DREAM about! ! !jimmyb34 is on a level you can only DREAM about! ! !jimmyb34 is on a level you can only DREAM about! ! !jimmyb34 is on a level you can only DREAM about! ! !jimmyb34 is on a level you can only DREAM about! ! !jimmyb34 is on a level you can only DREAM about! ! !jimmyb34 is on a level you can only DREAM about! ! !jimmyb34 is on a level you can only DREAM about! ! !jimmyb34 is on a level you can only DREAM about! ! !jimmyb34 is on a level you can only DREAM about! ! !
iTrader Score: 29 reviews
Send a message via AIM to jimmyb34
i was gonan say.. numbers guy chose to leave here wtf is he doing back... make your own thread, youll get more responses
jimmyb34 is offline   Reply With Quote Quick reply to this message
iconAll times are GMT -8. The time now is 12:53 PM. | Welcome to Forum, please register to access all of our features.
