How to I get #1 piston to TDC? - D-series.org
Old 04-19-2006, 07:16 AM   #1 (permalink)
Infamous's Avatar
Rep Power: 8 Infamous is nobody
Default How to I get #1 piston to TDC?
How to I get the number 1 piston to TDC? I know how to hand crank the engine and such but how do I know when it is at TDC? Also what is the simplelest way to do so? I am going to remove my cam for replacement.
1990 Civic wagon Electron blue D15B VTEC http://www.cardomain.com/ride/2038279
2006 Subaru Legacy GT Infamous tuned 386AWHP
http://www.myspace.com/infamoustuning
Yeah its an EE!
Infamous is offline   Reply With Quote
Old 04-19-2006, 07:31 AM   #2 (permalink)
Tom Foolery
TAGs95CivicEX's Avatar
Rep Power: 9 TAGs95CivicEX is a name known to allTAGs95CivicEX is a name known to allTAGs95CivicEX is a name known to allTAGs95CivicEX is a name known to allTAGs95CivicEX is a name known to allTAGs95CivicEX is a name known to allTAGs95CivicEX is a name known to allTAGs95CivicEX is a name known to allTAGs95CivicEX is a name known to allTAGs95CivicEX is a name known to all
Default Alrighty
Well you can take your valvecover off, then your timing gear cover turn the engine till the timing marks line up. You can check to make sure both intake and exhaust are closed to make sure you are on the compression stroke. or do it the old fashion way of stick your hand over the spark plug hole till the compression pushes it off, then you know it's the compression stroke. And then you should be all set. Also could check the distributer to make sure it's pointing at number one, to be extra super sure.
-TAG
Originally Posted by eg6motion
friends shouldn't let friends bolt on stupid shit
God Made Shit, Chevrolet Just Put Wheels On It
TAGs95CivicEX is offline   Reply With Quote
Old 04-19-2006, 07:43 AM   #3 (permalink)
I wanna be just like Jimmy!!
OniFactor's Avatar
Rep Power: 11 OniFactor It's a JDM Star Bitches....
marks on the crank. you'll see a grouping of 3 marks, then 1 off by itself. that 1 is what you want. line it up with the sight
[center]
http://img.photobucket.com/albums/v2.../mng01copy.png
my one and only baby..
[br]
[br]
OniFactor is offline   Reply With Quote
Old 04-19-2006, 02:32 PM   #4 (permalink)
Rep Power: 8 clemsonvic is learning the way of the Dclemsonvic is learning the way of the D
take out the number 1 spark plug and put in a long wooden dowel, move the crank slowly, the piston will move the dowel up, then when it starts to go down back it up a bit and there you go
clemsonvic is offline   Reply With Quote
Old 04-19-2006, 03:07 PM   #5 (permalink)
Infamous's Avatar
Okay I align it with the crank pulley.
Yeah its an EE!
Old 04-20-2006, 07:48 AM   #6 (permalink)
Willie S.
I would probably download or buy a Helms manual. They're very inexpensive and will be your best friend, especially in these type of situations.
Old 04-20-2006, 09:42 AM   #7 (permalink)
The Master Fabricator
gpny's Avatar
Rep Power: 12 gpny It's a JDM Star Bitches....
gpny It's a JDM Star Bitches....gpny It's a JDM Star Bitches....gpny It's a JDM Star Bitches....gpny It's a JDM Star Bitches....gpny It's a JDM Star Bitches....
That's what I do...
gpny is offline   Reply With Quote
Old 04-20-2006, 11:52 AM   #8 (permalink)
OniFactor's Avatar
Originally Posted by pelsise
That's what I do...
how do you people know whether or not it's on the compression stroke? seriously, half-assed ways for fixing things really aren't that much easier than doing it the right way..
[center]
[br]
[br]
Old 04-20-2006, 12:06 PM   #9 (permalink)
I neither dread nor desire.
Rep Power: 60 transzex is on a level you can only DREAM about! ! !transzex is on a level you can only DREAM about! ! !transzex is on a level you can only DREAM about! ! !transzex is on a level you can only DREAM about! ! !
transzex is on a level you can only DREAM about! ! !transzex is on a level you can only DREAM about! ! !transzex is on a level you can only DREAM about! ! !transzex is on a level you can only DREAM about! ! !transzex is on a level you can only DREAM about! ! !transzex is on a level you can only DREAM about! ! !transzex is on a level you can only DREAM about! ! !transzex is on a level you can only DREAM about! ! !transzex is on a level you can only DREAM about! ! !
crank doesn't care it it is the top of the comprssino stroke or exhaust stroke, that is the heads job
transzex is offline   Reply With Quote
Old 04-20-2006, 11:44 PM   #10 (permalink)
Rep Power: 10 gaowee is nobody
make sure your dizzy is pointin to the #1 on sparkplug wire then check the crank for the marks like oni said..since its pointing to #1 on the dizzy it will fire it..so #1 is now on the compress side and is waiting to go boom..thats how you can tell where the air/fuel getting compres and waiting for spark..
hope that help..and that dowel thing is a joke..come one guys give out good info not bad one..next u guy want him to crank it too rite and see how high he can shoot the dowel up is how good is compression is??
my $.02
gao
Great Seller:
civic4ges
spdracer22
gaowee is offline   Reply With Quote
iconAll times are GMT -8. The time now is 01:53 AM. | Welcome to Forum, please register to access all of our features.
