Timing Problem...I Think? - D-series.org
Old 03-05-2006, 07:10 PM   #1 (permalink)
Formally known as SPONSOREDCRX
ESD_DA9's Avatar
Rep Power: 14 ESD_DA9 is hot as a volcanoESD_DA9 is hot as a volcano
ESD_DA9 is hot as a volcanoESD_DA9 is hot as a volcanoESD_DA9 is hot as a volcanoESD_DA9 is hot as a volcanoESD_DA9 is hot as a volcanoESD_DA9 is hot as a volcanoESD_DA9 is hot as a volcano
Default Timing Problem...I Think?
i have a little problem ever since i changed my timing belt.i think i may have moved the crank off of tdc when i was putting the belt on the cam gear.it idles a little low(500rpm)and it kinda bogs a little ever couple seconds. it also has a very slight knock too. any help?
1991 CRX Si (Traded) It will def be missed
1990 Integra 2D (Current DD)
Originally Posted by cmgreen50 View Post
most of mans motivation is motivated by...vag or money and the only reason we care about money is cause we can use it to get...vag
Originally Posted by jEromy View Post
My mom came into my room and thought i was watching porn because i was stroking myself to your car!
ESD_DA9 is offline   Reply With Quote
Old 03-05-2006, 07:42 PM   #2 (permalink)
I wanna be just like Jimmy!!
OniFactor's Avatar
Rep Power: 11 OniFactor It's a JDM Star Bitches....
set cyl 1 at TDC, and see if the cam matches up along with the crank..
[center]
http://img.photobucket.com/albums/v2.../mng01copy.png
my one and only baby..
[br]
[br]
OniFactor is offline   Reply With Quote
Old 03-05-2006, 08:17 PM   #3 (permalink)
ESD_DA9's Avatar
i was going 2 do that but i want 2 make sure thats what the problem is.
Old 03-05-2006, 08:19 PM   #4 (permalink)
OniFactor's Avatar
that's really the only way to check..
[center]
[br]
[br]
Old 03-05-2006, 08:23 PM   #5 (permalink)
ESD_DA9's Avatar
i wanna see if any 1 else had this problem
Old 03-05-2006, 11:46 PM   #6 (permalink)
d16a6 power's Avatar
Rep Power: 10 d16a6 power is learning the way of the Dd16a6 power is learning the way of the D
The only way to check is to go to cylinder one on compression stroke and see if the crank pulley mark is on correct mark as well as the cam sprocket is pointed to the correct mark. Doesn't take long and sounds exactly what your problem is.
d16a6 power is offline   Reply With Quote
Old 03-06-2006, 12:36 PM   #7 (permalink)
ESD_DA9's Avatar
alright thanks
iconAll times are GMT -8. The time now is 12:02 AM. | Welcome to Forum, please register to access all of our features.
