Exhaust makin that rattle. - D-series.org
Old 02-24-2006, 11:14 PM   #1 (permalink)
decev
Default Exhaust makin that rattle.
My exhaust started to make that slight rattle under 2500 rpms yesterday. What the hell is it. I'm replacing the whole thing soon, so I'm not that worried. Just was wondering if anyone knew off the bat.
Old 02-24-2006, 11:25 PM   #2 (permalink)
eg6motion's Avatar
Rep Power: 9 eg6motion is trying to make new friends
your not running a magnaflow cat are you? lol j/k
Most exhaust rattles come from heatshields or broken cats..ie the brick becomes loose.
5280ft elevation
please donate air
http://i74.photobucket.com/albums/i2...otion/sig2.jpg
eg6motion is offline   Reply With Quote
Old 02-24-2006, 11:31 PM   #3 (permalink)
n00br0's Avatar
Rep Power: 8 n00br0 is trying to make new friends
does it come from the back?? does your exhaust have rivits?? could be alot of things
http://www.gameshop.nl/Upload/Pictur...1_luigie18.JPGneed to make a new sig but lost photoshop anyone know were to get a copy??
Originally Posted by Grounded View Post
neon lights are only acceptable when they advertise beer. other than that = Rice a Roni.
Originally Posted by transzex View Post
put the crack pipe down...step away from the computer.
http://i15.photobucket.com/albums/a3...acing/vtec.jpg:thehump:
n00br0 is offline   Reply With Quote
Old 02-24-2006, 11:32 PM   #4 (permalink)
decev
I believe it's the cat. Sounds like it's coming from directly beneath me. Have the cat go out, will that roast my exh. valves?
Old 02-24-2006, 11:37 PM   #5 (permalink)
n00br0's Avatar
if you take it out.you would A.get pulled over for being way to loud (straigh pipe) B.not be able to pass smog. and C. you car would be really smelly. lol
Old 02-25-2006, 12:08 AM   #6 (permalink)
samuraiz's Avatar
Rep Power: 9 samuraiz is starting to learn the ropessamuraiz is starting to learn the ropessamuraiz is starting to learn the ropessamuraiz is starting to learn the ropessamuraiz is starting to learn the ropessamuraiz is starting to learn the ropes
First, what would the catalytic converter have to do with your exhaust valves?
Second, if your exhaust system has a resonator or a real muffler, you can remove the cat without it being too loud, though it does kinda smell like it's from the 60's. If your state test emissions, don't even think about removing it.
eg6motion is right, it's probably the heat shield or else the honycomb of shit inside the cat is breaking loose which could eventually clog any resonator or glasspack muffler downstream. Unless you've hit the cat on something, i'd bet it's the heatshield. The heatshield would probably sound more high pitch, it is just a small piece of tin(?) vibrating.
samuraiz is offline   Reply With Quote
Old 02-25-2006, 12:47 AM   #7 (permalink)
decev
With a blocked exhaust flow I could burn valves, right? Even you, samuraiz, stated that the comb could have become dislodged. I'm not removing anything and an entirely new exhaust is going on within 2 weeks, maybe even monday. I just wanting to make sure that 200-700 miles like this will be ok.
Old 02-25-2006, 01:00 AM   #8 (permalink)
Rep Power: 434 ryan89crx is on a level you can only DREAM about! ! !ryan89crx is on a level you can only DREAM about! ! !ryan89crx is on a level you can only DREAM about! ! !ryan89crx is on a level you can only DREAM about! ! !ryan89crx is on a level you can only DREAM about! ! !ryan89crx is on a level you can only DREAM about! ! !ryan89crx is on a level you can only DREAM about! ! !ryan89crx is on a level you can only DREAM about! ! !ryan89crx is on a level you can only DREAM about! ! !ryan89crx is on a level you can only DREAM about! ! !ryan89crx is on a level you can only DREAM about! ! !ryan89crx is on a level you can only DREAM about! ! !ryan89crx is on a level you can only DREAM about! ! !ryan89crx is on a level you can only DREAM about! ! !ryan89crx is on a level you can only DREAM about! ! !
mine started doing the same thing when i had my stock exhaust on. ended up being the resonator
My CRX 12.87@109mph
Delta Cam, best bang for your buck!
http://img.photobucket.com/albums/v2.../made_Ryan.png
ryan89crx is offline   Reply With Quote
Old 02-25-2006, 07:31 AM   #9 (permalink)
eg6motion's Avatar
You will only burn valves if your exhaust becomes blocked. I just had my cat break apart and get stick in the pipe so I speak from experience. But you WILL definately notice it when that happens. No powa.
5280ft elevation
please donate air
Old 02-25-2006, 02:55 PM   #10 (permalink)
Rep Power: 0 jcarp613 is nobody
If it is a honeycomb cat you can smash it and make it hollow. It most likely is a loos heat shield. Crawl under it while its running and find exactly where the rattle is. Good Luck...
jcarp613 is offline   Reply With Quote
Old 02-26-2006, 12:10 AM   #11 (permalink)
samuraiz's Avatar
That's what I thought, a substantially blocked exhaust would do more than just make noise.
Old 02-26-2006, 03:33 AM   #12 (permalink)
Rep Power: 8 EG8SIR is starting to learn the ropesEG8SIR is starting to learn the ropesEG8SIR is starting to learn the ropesEG8SIR is starting to learn the ropesEG8SIR is starting to learn the ropesEG8SIR is starting to learn the ropesEG8SIR is starting to learn the ropes
my cat magically fell out when i installed my Greddy Evo Catback but lucky i had a test pipe to fill the gap till i order a new one but no rice or any werid rattles here
http://media.putfile.com/civ
If you have a nice and long resonator you can get away without having a cat (i also live in FL with no emissions and the jacked up redneck trucks are not only 10x louder but they wouldnt use a cat if someone paid them) on exhaust notes
http://www.pbase.com/minority_report/image/64672006.jpg
you know what it is...we fuck spiders in each one of their eyes
1995 Civic 5 Speed, SOHC ZC Vtec, Fake J's Intake, DC Header, Greddy Catback, Street Tuned on the HeebSpeed laptop by myself
15.23@90.66 with a 2.29 60'
http://media.putfile.com/sohcvtec1
EG8SIR is offline   Reply With Quote
Old 02-27-2006, 10:05 AM   #13 (permalink)
17secondlx's Avatar
Rep Power: 0 17secondlx is nobody
the rattle happen several times to me on my ek. They used aluminum to help keep the heat in which is good. They bolted the aluminum to the steel exhaust which is bad.
When dissimilar metals come into contact, one tends to rust... (while the other is protected) it's called galvanic corrosion... and unfortunately the heat shields rust though around the bolts and becomes loose...
It's much more common than say damage to the catalytic converter... So it's more likely to be the heat shield. Fixing the rattle the first two time for me was really easy. After I saw the heat shield that was vibrating, I grabbed the offending bit of metal and promptly burnt my hand... (wait until the car cools down) An hour later I went out and grabbed it again and yanked it out. The next time was just as easy and I pulled out another piece... The last shield though was much more difficult. It has rusted though around two bolts but the other two still had a firm grip on the bit of aluminum. I tried fatiguing the metal by working it back and forth for a good ten minutes, but it was difficult and the metal is sharp, and the bolts catch on your hands and I got cut up a bit. (So don't do this either, especially without proper gloves) I gave up, got the dremel out and cut it off in 30 seconds.
If you get your oil changed at the shop, you can just tell them to rip any of the loose heat shields off... It'll take them a few seconds, and they shouldn't even charge you for it.
17secondlx is offline   Reply With Quote
Old 02-28-2006, 11:59 AM   #14 (permalink)
samuraiz's Avatar
I used Tin snips to remove the bit of heat shield that was vibrating under my car, the sound is back now so I think it's time to break out the snips again. The hardest part for me was Identifying exactly where the noise was comming from. I can only reproduce it around 3.2k rpm when in gear.
iconAll times are GMT -8. The time now is 02:17 AM. | Welcome to Forum, please register to access all of our features.
