Turn Signals/Hazards Stopped Working - D-series.org
Old 11-28-2012, 04:09 PM   #1 (permalink)
Rep Power: 0 Animag771 is learning the way of the DAnimag771 is learning the way of the D
Question Turn Signals/Hazards Stopped Working
As the title says, my turn signals and hazards stopped working. None of the lights blink when i put on my signals or hazards. The gauge arrows don't flash and I cannot hear the relay. I was rewiring my tail lights because they were all messed up and when I went to test the blinkers they worked fine and then they just stopped... I have checked all of my fuses, looked at the wiring that I did and nothing is shorting or grounded out and I have checked to verify that my hazard button is completely plugged in, which it is.
I figured out where my turn signal relay should be, on my fuse box to check the relay and this is what I found...
All of my signals have been working fine for years... WTF??
Animag771 is offline   Reply With Quote Quick reply to this message
Old 11-28-2012, 04:12 PM   #2 (permalink)
AJAY's Avatar
Rep Power: 13 AJAY is the fucking MAN!!!!AJAY is the fucking MAN!!!!AJAY is the fucking MAN!!!!
AJAY is the fucking MAN!!!!AJAY is the fucking MAN!!!!AJAY is the fucking MAN!!!!AJAY is the fucking MAN!!!!AJAY is the fucking MAN!!!!AJAY is the fucking MAN!!!!AJAY is the fucking MAN!!!!
Check out other thread
1993 civic dx hatch
jdm d15b vtec obd1
web level 1 cam
15g turbo 13 psi
AJAY is offline   Reply With Quote Quick reply to this message
Old 11-28-2012, 04:16 PM   #3 (permalink)
\/ apply baby lotion here \/
Pata's Avatar
Rep Power: 43 Pata is on a level you can only DREAM about! ! !Pata is on a level you can only DREAM about! ! !Pata is on a level you can only DREAM about! ! !Pata is on a level you can only DREAM about! ! !Pata is on a level you can only DREAM about! ! !
iTrader Score: 136 reviews
Ok..
Old 11-28-2012, 04:19 PM   #4 (permalink)
crxdonwon's Avatar
Rep Power: 8 crxdonwon is a name known to allcrxdonwon is a name known to allcrxdonwon is a name known to allcrxdonwon is a name known to allcrxdonwon is a name known to allcrxdonwon is a name known to allcrxdonwon is a name known to allcrxdonwon is a name known to allcrxdonwon is a name known to allcrxdonwon is a name known to all
If the hazard switch is not plugged in or bad, your lights will not blink. May not fix your problem, but a possibility if you haven't checked.
You asked.
"Son... We don't cry unless we're bleedin' or broken!"
-DonWon
"Don't get too close to me, you'll get Horsepower on you!"
-DonWon
crxdonwon is offline   Reply With Quote Quick reply to this message
Old 11-28-2012, 04:20 PM   #5 (permalink)
hotrodj's Avatar
Rep Power: 13 hotrodj is a Top Aussie
iTrader Score: 30 reviews
Yes, try another hazard switch
94 del Sol si 144whp, 113tq
I/H/E, pnp y8 head,Bisi lvl2, Hondata S300,
Stock Z6 bottom end
PM for ECU Chipping/Socketing and Repair Prices
Old 11-28-2012, 04:29 PM   #6 (permalink)
The hazard switch is completely plugged in, as I stated in my original post. I am currently looking online to find a new hazard switch to see how long that will take to get to me and how much that is going to cost me... If it isn't the hazard switch does anybody have any other suggestions? Also, is it that I have no relay for my signals (in pic) or that I was simply looking at the wrong spot?
Old 11-28-2012, 04:32 PM   #7 (permalink)
HondaDNA's Avatar
Rep Power: 20 HondaDNA is the fucking MAN!!!!HondaDNA is the fucking MAN!!!!HondaDNA is the fucking MAN!!!!
You need a relay...
Next time only make ONE thread..
Old 11-28-2012, 04:32 PM   #8 (permalink)
sir_bobos's Avatar
Rep Power: 33 sir_bobos is on a level you can only DREAM about! ! !sir_bobos is on a level you can only DREAM about! ! !
I may be wrong on this but could you jumper the hazard connector at least till you fix it right. At least you could drive it.
EDIT*If the switch is bad of course.
I play Black Metal, I don't need to know chords.
A09/TQ2.0.02155F1 CIV
sir_bobos is offline   Reply With Quote Quick reply to this message
Old 11-28-2012, 04:36 PM   #9 (permalink)
Originally Posted by HondaDNA View Post
You need a relay...
I must have been looking at the wrong relay or something, I guess... Turn signals have worked fine for years, but I looked under there today and saw a big relay spot that says "TURN" and it's empty...
Yea I couldn't figure out which section to post in and then I couldn't figure out how to delete the other. Sorry
Old 11-28-2012, 04:38 PM   #10 (permalink)
When you say "the switch" you are talking about the button I am pressing to turn the hazards on, correct? Not something hidden somewhere...?
Old 11-28-2012, 05:11 PM   #11 (permalink)
sir_bobos's Avatar
Sorry I meant try jumping the harness connector for the hazard switch.
Old 11-28-2012, 05:11 PM   #12 (permalink)
crxdonwon's Avatar
Yes
You asked.
-DonWon
-DonWon
Old 11-28-2012, 05:40 PM   #13 (permalink)
HondaDNA's Avatar
Seeing as there is only one relay marked "TURN" I have no idea why it has worked...
Old 11-28-2012, 06:02 PM   #14 (permalink)
Thank you for the helpful diagram. Now extremely confused as to how it has been working for years with no relay. It's not like the relay just fell out somehow and disappeared... I am now sure that it is the correct slot for that relay, because in my original post you can see fuse numbers 21, 22 and 23 which the relay is located above.
Well I guess I will get a relay to start and if that doesnt fix it I will buy a new switch as well. I will stay posted.
Old 12-08-2012, 06:12 PM   #15 (permalink)
Well.... I have replaced the turn signal relay and the hazard switch.
Still no working blinkers/hazards... Any other suggestions?
Thanks
Old 12-08-2012, 06:25 PM   #16 (permalink)
2jzdreamin's Avatar
Rep Power: 27 2jzdreamin is on a level you can only DREAM about! ! !2jzdreamin is on a level you can only DREAM about! ! !2jzdreamin is on a level you can only DREAM about! ! !
2jzdreamin is on a level you can only DREAM about! ! !2jzdreamin is on a level you can only DREAM about! ! !2jzdreamin is on a level you can only DREAM about! ! !2jzdreamin is on a level you can only DREAM about! ! !2jzdreamin is on a level you can only DREAM about! ! !2jzdreamin is on a level you can only DREAM about! ! !2jzdreamin is on a level you can only DREAM about! ! !2jzdreamin is on a level you can only DREAM about! ! !2jzdreamin is on a level you can only DREAM about! ! !2jzdreamin is on a level you can only DREAM about! ! !2jzdreamin is on a level you can only DREAM about! ! !
iTrader Score: 49 reviews
Can you post pics of the wiring you played with and the under dash fuse box?
What year and make is the car?
all so do vtec sub-harness
instagram @magicman9won4
2jzdreamin is online now   Reply With Quote Quick reply to this message
Old 12-09-2012, 03:58 PM   #17 (permalink)
Yes. I will upload those tomorrow.
Old 12-13-2012, 07:57 AM   #18 (permalink)
Ok, so I'm a little later on these uploads than planned. Here they are though...
So, the thing is that the lights in my tail light housing would not fit into the proper slots because I have aftermarket tail lights and the slots are in the wrong spots. So in order for everything to fit into its correct spot and lock into place I had to swap the tail light/brake light with the blinker. All I did was cut off the blinker bulb and tail light/brake bulb wires and swap their positions. Everything was working fine and then the blinker stopped working all together.
Tail Lights
Fuse Box (Nothing changed in there other than adding the flasher relay)
Wiring
Old 12-19-2012, 09:13 AM   #19 (permalink)
Bump.
Please help. Need to get this car inspected and cannot do so without blinkers.
Old 12-19-2012, 02:08 PM   #20 (permalink)
BigJnWorldWide's Avatar
Rep Power: 27 BigJnWorldWide is on a level you can only DREAM about! ! !BigJnWorldWide is on a level you can only DREAM about! ! !BigJnWorldWide is on a level you can only DREAM about! ! !
BigJnWorldWide is on a level you can only DREAM about! ! !BigJnWorldWide is on a level you can only DREAM about! ! !BigJnWorldWide is on a level you can only DREAM about! ! !BigJnWorldWide is on a level you can only DREAM about! ! !BigJnWorldWide is on a level you can only DREAM about! ! !BigJnWorldWide is on a level you can only DREAM about! ! !BigJnWorldWide is on a level you can only DREAM about! ! !BigJnWorldWide is on a level you can only DREAM about! ! !BigJnWorldWide is on a level you can only DREAM about! ! !BigJnWorldWide is on a level you can only DREAM about! ! !BigJnWorldWide is on a level you can only DREAM about! ! !BigJnWorldWide is on a level you can only DREAM about! ! !
You need a multimeter. I fixed like 4 wiring problems in 1 day after I picked one up a few years back. It will be your best friend.
But before replacing something, you really should test it to see if it's the culprit or not. It's the best way to narrow things down. Go buy a multimeter. GL, sir.
On top of that you have a special knowledge, an understanding of the complexity of the things happening. Others see you turn the wheel and push down on the gas, not you. You see a symphony of combustion and physics. You see a balance between frictional coefficients, tire roll over, spring rates, and throttle. It's a beautiful thing to see all these components working in harmony, it's literally a ballet of force and mathematics!
BigJnWorldWide is offline   Reply With Quote Quick reply to this message
iconAll times are GMT -8. The time now is 12:33 PM. | Welcome to Forum, please register to access all of our features.
