Another smog question - D-series.org
Old 08-29-2012, 04:07 PM   #1 (permalink)
undeadcivicrace's Avatar
Rep Power: 8 undeadcivicrace is nobody
Default Another smog question
i did my smog today and of course it failed with high hc and very high co i was reading the high hc is unburned fuel and high co is when the air/fuel mixture is too rich. no i have a 94 civic lx with a d15b7 in it with cai and exhaust. if i run a new o2 sensor would that fix my high co readings. high hc reading is a basic tune up. thanks any comments would be great full
undeadcivicrace is offline   Reply With Quote Quick reply to this message
Old 08-29-2012, 04:11 PM   #2 (permalink)
\/ apply baby lotion here \/
Pata's Avatar
Rep Power: 43 Pata is on a level you can only DREAM about! ! !Pata is on a level you can only DREAM about! ! !Pata is on a level you can only DREAM about! ! !Pata is on a level you can only DREAM about! ! !Pata is on a level you can only DREAM about! ! !
iTrader Score: 136 reviews
do you have a OEM cat? is it good or old?
Old 08-29-2012, 08:28 PM   #3 (permalink)
its a oem still good last i knew
Old 08-30-2012, 05:44 PM   #4 (permalink)
anyone else have any ideas?
Old 08-30-2012, 06:23 PM   #5 (permalink)
CaliLegal's Avatar
Rep Power: 12 CaliLegal is hot as a volcanoCaliLegal is hot as a volcano
CaliLegal is hot as a volcanoCaliLegal is hot as a volcanoCaliLegal is hot as a volcanoCaliLegal is hot as a volcanoCaliLegal is hot as a volcanoCaliLegal is hot as a volcanoCaliLegal is hot as a volcanoCaliLegal is hot as a volcanoCaliLegal is hot as a volcanoCaliLegal is hot as a volcano
HC is RAW fuel.... completely unburnt. As where CO is partially burnt.
Old
D16z6
11.5psi 204whp/180ftlbs. old setup
New - 5/25/12
.002 P2W
75.5mm Z6
TD04H 15G @ 22.6psi ??WHP
Put a new motor in?
Dont race your car?
If you see smoke don't insert face?
If any of this confuses you die!
R.I.P - Pat Primmer
CaliLegal is offline   Reply With Quote Quick reply to this message
Old 08-30-2012, 07:00 PM   #6 (permalink)
NeonPinHead's Avatar
Rep Power: 23 NeonPinHead is the fucking MAN!!!!NeonPinHead is the fucking MAN!!!!NeonPinHead is the fucking MAN!!!!NeonPinHead is the fucking MAN!!!!
NeonPinHead is the fucking MAN!!!!NeonPinHead is the fucking MAN!!!!NeonPinHead is the fucking MAN!!!!NeonPinHead is the fucking MAN!!!!NeonPinHead is the fucking MAN!!!!NeonPinHead is the fucking MAN!!!!NeonPinHead is the fucking MAN!!!!NeonPinHead is the fucking MAN!!!!NeonPinHead is the fucking MAN!!!!
iTrader Score: 51 reviews
always get a tune up before a smog test. you seem to have an ignition system problem (spark plugs, wireset, dizzy cap and rotor). You should also get a new air filter, change the oil and filter, fuel filter, check timing, valve lash adjustment, and if it comes down to it run some sea foam in the gas tank and through the intake. if you still don't pass catalytic converter. following these steps I have always passed. Also you're not in cali so it shouldn't be as hard to pass.
NeonPinHead is offline   Reply With Quote Quick reply to this message
Old 08-30-2012, 07:15 PM   #7 (permalink)
I no longer haz teh pink eye! Iz got STINK EYE
Bumpysbro's Avatar
Rep Power: 18 Bumpysbro is the fucking MAN!!!!Bumpysbro is the fucking MAN!!!!Bumpysbro is the fucking MAN!!!!
Bumpysbro is the fucking MAN!!!!Bumpysbro is the fucking MAN!!!!Bumpysbro is the fucking MAN!!!!Bumpysbro is the fucking MAN!!!!Bumpysbro is the fucking MAN!!!!
high hc and high co usually means your running rich. what are your other readings? whats your o2 and nox levels at? ya id do what neon said, probably a tune up will fix it, if all your readings are a little high can usually mean a cat on the way out but i would do the cheapest first
OG SoCal mufuckers don't fear Smog
I want your whale penis
I almost had you man....you almost had me? You never had me..You never had your car LOL
Bumpysbro is offline   Reply With Quote Quick reply to this message
Old 08-31-2012, 05:03 AM   #8 (permalink)
readings are at
hc 7.6680 limit 1.200
co 95.9571 limit 15.000
co2 145.410 limit n/a
nox 0.4444 limit 3.000
Old 08-31-2012, 05:04 AM   #9 (permalink)
i will do a tune up today since i got paid and im in colorado
Old 08-31-2012, 05:08 AM   #10 (permalink)
on another note i know iam rich also i have throwing code 43 witch if fuel supply.
Old 08-31-2012, 05:09 AM   #11 (permalink)
\/Your Mom Was Here\/
BeerDrinkin's Avatar
Rep Power: 48 BeerDrinkin is on a level you can only DREAM about! ! !BeerDrinkin is on a level you can only DREAM about! ! !BeerDrinkin is on a level you can only DREAM about! ! !BeerDrinkin is on a level you can only DREAM about! ! !
BeerDrinkin is on a level you can only DREAM about! ! !BeerDrinkin is on a level you can only DREAM about! ! !BeerDrinkin is on a level you can only DREAM about! ! !BeerDrinkin is on a level you can only DREAM about! ! !BeerDrinkin is on a level you can only DREAM about! ! !BeerDrinkin is on a level you can only DREAM about! ! !BeerDrinkin is on a level you can only DREAM about! ! !BeerDrinkin is on a level you can only DREAM about! ! !BeerDrinkin is on a level you can only DREAM about! ! !BeerDrinkin is on a level you can only DREAM about! ! !
Get a tune up and run some seafoam or other top engine cleaner through the intake and also change out the pcv valve and make sure the hose isn't clogged. If all that fails you may end up needing a cat
2005 Civic EX Sedan (ES2)
Old 08-31-2012, 07:40 AM   #12 (permalink)
CaliLegal's Avatar
Originally Posted by undeadcivicrace View Post
readings are at
Can we get these with proper numbers? Ive never seen CO2, CO, or O2 not as a percentage.
Try this please,
O2 %
HC ppm count
CO %
CO2 %
NOx ppm count
If you get me these ill let you know if your within catalyst efficiency range.
Old
D16z6
New - 5/25/12
.002 P2W
75.5mm Z6
Put a new motor in?
Dont race your car?
R.I.P - Pat Primmer
Old 08-31-2012, 07:54 AM   #13 (permalink)
JBrettHowell's Avatar
Rep Power: 10 JBrettHowell is fly like an eagleJBrettHowell is fly like an eagleJBrettHowell is fly like an eagleJBrettHowell is fly like an eagleJBrettHowell is fly like an eagleJBrettHowell is fly like an eagleJBrettHowell is fly like an eagleJBrettHowell is fly like an eagleJBrettHowell is fly like an eagleJBrettHowell is fly like an eagleJBrettHowell is fly like an eagleJBrettHowell is fly like an eagle
I had a similar issue getting through emissions and did what BeerDrinkin is suggesting. It worked.
JBrettHowell is offline   Reply With Quote Quick reply to this message
Old 08-31-2012, 11:01 AM   #14 (permalink)
97-Civic-Ex's Avatar
Rep Power: 9 97-Civic-Ex is a name known to all97-Civic-Ex is a name known to all97-Civic-Ex is a name known to all97-Civic-Ex is a name known to all97-Civic-Ex is a name known to all97-Civic-Ex is a name known to all97-Civic-Ex is a name known to all97-Civic-Ex is a name known to all
iTrader Score: 23 reviews
You have to clear this first. The ECU is trying to compensate for O2 sensor reading and has reached it's limit.
Speculation is your O2 sensor is not reading right anymore(possibly too lean) and the ECU keeps adding more and more fuel making your mixture too rich.
1st step for clearing a code 43, change O2 sensor reset ECU warm it up and drive it a few hundred miles. If it doesn't come back, that was your main problem.
If that doesn't do it, fuel filter or regulator(if you have an aftermarket adjustable one, is it set too high?)
All other suggestions will help, but all CEL has to be cleared first
97-Civic-Ex is offline   Reply With Quote Quick reply to this message
Old 08-31-2012, 07:34 PM   #15 (permalink)
i swaped the o2 sensor already , did fuel filter it has an oem fpr. i will change out the pvc valve as well.
iconAll times are GMT -8. The time now is 09:49 PM. | Welcome to Forum, please register to access all of our features.
