Originally Posted by juice91si
duh, sorry, its a 91 civic si, d16a6
using the the z6 wiring harness would be a pain... mainly because the obd1 plugs on the z6 harness wont conect to th e obd0 plugs to your car...in order to make the z6 harness work you would have to change the main plugs to obd0 which is not a fun thing nore very simple...
i have a mini-me obd1 swap in my 91 si and i found that buying the the coversion harness and splicing in obd1 injectors to my si wiring harness was much easier... you can get the harness at jdmshit.com for a great price and snip the injector clips of a obd1 harness (i cut mine off a chepo cx harness) next all you have to do is wire in obd1 plugs for the dizzy (if you get the convo harness from jdmshit.com it has instuctions on how to do the dizzy wiring here are some pics
complete dizzy wiring
here is the dizzy wiring paper
