Brown stuff in coolant - D-series.org
Old 05-08-2011, 07:15 PM   #1 (permalink)
Iwantvtec's Avatar
Rep Power: 0 Iwantvtec is nobody
Default Brown stuff in coolant
hey guys I'm new hear but I have a problem. I saw brown residue in my radiator after I purchased my EJ1. I thought ok maybe its rust from the radiator so I swapped out the radiator. A couple of days later I see the brown residue again. I've been reading that it's signs of a failing head gasket but could it also be anything else besides that? And if it's a failing head gasket wouldn't there be water in the oil?
Iwantvtec is offline   Reply With Quote Quick reply to this message
Old 05-08-2011, 07:18 PM   #2 (permalink)
sloK's Avatar
Rep Power: 11 sloK is da #1 stunnasloK is da #1 stunnasloK is da #1 stunnasloK is da #1 stunnasloK is da #1 stunnasloK is da #1 stunnasloK is da #1 stunna
first of all, where do you live?
2nd of all, if it was rust inside your cooling system, just replacing the radiator wont take the rusty coolant and residue out of your engine and other coolant hoses.
no restrictor!
how is oil going to damage a steel ring? it wont.
am i the only one who is on the same page as danz!?!?!?!
s300 is worth the money over crome. crome is terrible and i have a feeling people over the pond have more brains than to cheap out on management like most over on this side.
especially since most other platforms require complete stand alones!
sloK is offline   Reply With Quote Quick reply to this message
Old 05-08-2011, 07:22 PM   #3 (permalink)
devilsnight's Avatar
Rep Power: 14 devilsnight  is accepted as part of the communitydevilsnight  is accepted as part of the communitydevilsnight  is accepted as part of the communitydevilsnight  is accepted as part of the community
did you flush the system? or just drain, change radiator and refill
devilsnight is offline   Reply With Quote Quick reply to this message
Old 05-08-2011, 07:24 PM   #4 (permalink)
EF9
EF9's Avatar
Rep Power: 15 EF9 is the fucking MAN!!!!EF9 is the fucking MAN!!!!
EF9 is the fucking MAN!!!!EF9 is the fucking MAN!!!!EF9 is the fucking MAN!!!!EF9 is the fucking MAN!!!!EF9 is the fucking MAN!!!!EF9 is the fucking MAN!!!!EF9 is the fucking MAN!!!!EF9 is the fucking MAN!!!!EF9 is the fucking MAN!!!!EF9 is the fucking MAN!!!!EF9 is the fucking MAN!!!!EF9 is the fucking MAN!!!!EF9 is the fucking MAN!!!!
Having kaka colored coolant is usually a sign that the headgasket is on its way out or your cooling system has cancer in it. To confirm the headgasket, one way is to have someone rev up the engine hard n quick and check what comes out of the tail end, usually whitish smoke is a sign and it should have a hint of a sweet smell. As for the cancer, do a string of flushes over the course of a couple months (ie one flush every 3-5 weeks for 10-12 weeks). To comfirm cancer, you can also pop the thermostat out and see how it and the surround area looks.
<- Deuce MKIa
<- Deuce MKIb
Will you make a contract with me? /人◕ ‿‿ ◕人\
Magical spinning Doritos do not belong in cars...
EF9 is offline   Reply With Quote Quick reply to this message
Old 05-08-2011, 07:25 PM   #5 (permalink)
Im Bringing TSEXY Back!
T-MacK's Avatar
Rep Power: 30 T-MacK is on a level you can only DREAM about! ! !T-MacK is on a level you can only DREAM about! ! !T-MacK is on a level you can only DREAM about! ! !
T-MacK is on a level you can only DREAM about! ! !T-MacK is on a level you can only DREAM about! ! !T-MacK is on a level you can only DREAM about! ! !T-MacK is on a level you can only DREAM about! ! !T-MacK is on a level you can only DREAM about! ! !T-MacK is on a level you can only DREAM about! ! !T-MacK is on a level you can only DREAM about! ! !
Headgasket is on its way out!
Hella Flush.....Were waiting!
Xbox gamer tag: THErealTMACK
T-MacK is offline   Reply With Quote Quick reply to this message
Old 05-08-2011, 07:29 PM   #6 (permalink)
dnice78's Avatar
Rep Power: 11 dnice78 is a Top Aussie
dnice78 is a Top Aussiednice78 is a Top Aussiednice78 is a Top Aussiednice78 is a Top Aussiednice78 is a Top Aussiednice78 is a Top Aussiednice78 is a Top Aussiednice78 is a Top Aussiednice78 is a Top Aussiednice78 is a Top Aussiednice78 is a Top Aussie
I remember my sisters car had some brown goop-like stuff in her radiator three years ago and she has yet to blow her headgasket.
Nissan Titan
S13 Coupe Sr20det-Missile
S13 Coupe Ka24de-Mistress
2014 Honda Grom
dnice78 is offline   Reply With Quote Quick reply to this message
Old 05-08-2011, 08:14 PM   #7 (permalink)
Nasty_Canasta's Avatar
Rep Power: 15 Nasty_Canasta is the fucking MAN!!!!Nasty_Canasta is the fucking MAN!!!!Nasty_Canasta is the fucking MAN!!!!
You can try taking your radiator cap off, leaving the hood open and starting it.
If your head gasket is going and pressure is getting into the cooling system,
your coolant will shoot out the radiator. Sometimes as high as 5-6 feet.
If it doesn't happen, it doesn't mean your head gasket isn't going. There
are a bunch of different symptoms depending on where the gasket is failing
at.
Also check the top of your oil cap for milkshake, your coolant reservoir for
oil / gunk, air continuously bubbling from the radiator, etc.
I home school my kid. I am now Professor Canasta.
Nasty_Canasta is offline   Reply With Quote Quick reply to this message
Old 05-08-2011, 08:21 PM   #8 (permalink)
patprimmer's Avatar
A Honda radiator is normally aluminium as is the head and block. The only materials that can make brown rust are the steel fittings or tubes like across the back of the block from the thermostat to the water pump.
Brown sludge is almost certainly oil and almost certainly due to a current or previously blown or leaky gasket. A lot depends o where and why the gasket is leaking.
Regards
Pat. RIP Feb 22, 2013.
my CRX thread
my intro
Old 05-08-2011, 09:14 PM   #9 (permalink)
Iwantvtec's Avatar
No bubbling in the system or sludge on the oil cap. Also I've tried the revving and no white smoke comes out. Also I drained, changed rad, and refilled.
Old 05-08-2011, 09:22 PM   #10 (permalink)
baajaa's Avatar
Rep Power: 7 baajaa is fly like an eaglebaajaa is fly like an eaglebaajaa is fly like an eaglebaajaa is fly like an eaglebaajaa is fly like an eaglebaajaa is fly like an eaglebaajaa is fly like an eaglebaajaa is fly like an eaglebaajaa is fly like an eaglebaajaa is fly like an eaglebaajaa is fly like an eagle
You need to flush it out. Pour some draino in it, and let it idle for 15 minutes or so. Then drain it. Fill it. Run it around town a lil. Drain it again. Fill it again. Good to go!!
easy answer, pump and dump, just wrap your PTO shaft!
baajaa is offline   Reply With Quote Quick reply to this message
Old 05-08-2011, 10:28 PM   #11 (permalink)
patprimmer's Avatar
DO NOT. I REPEAT DO NOT PUT DRAINO IN IT.
Draino is caustic soda. Caustic soda dissolves aluminium rapidly. You radiator, block, water pump and cylinder head are all aluminium. Draino could turn it all to shit.
Use Draino would have to be the worst single piece of advice I ever saw on here.
Regards
my CRX thread
my intro
Old 05-08-2011, 11:26 PM   #12 (permalink)
cmgogo's Avatar
Rep Power: 13 cmgogo is approaching greatnesscmgogo is approaching greatnesscmgogo is approaching greatnesscmgogo is approaching greatnesscmgogo is approaching greatnesscmgogo is approaching greatnesscmgogo is approaching greatnesscmgogo is approaching greatnesscmgogo is approaching greatnesscmgogo is approaching greatnesscmgogo is approaching greatnesscmgogo is approaching greatnesscmgogo is approaching greatness
Seriously... who gave you posting rights?
How have you been flushing? Inline water tap into the heater hose, or just drain and refil?
cmgogo for gov. of California
Yeah... i'm THAT awesome
cmgogo is offline   Reply With Quote Quick reply to this message
Old 05-08-2011, 11:33 PM   #13 (permalink)
\/ apply baby lotion here \/
Pata's Avatar
Rep Power: 43 Pata is on a level you can only DREAM about! ! !Pata is on a level you can only DREAM about! ! !Pata is on a level you can only DREAM about! ! !Pata is on a level you can only DREAM about! ! !Pata is on a level you can only DREAM about! ! !
iTrader Score: 136 reviews
Flush it all out, put new 50/50 in there and report back in a month..
iconAll times are GMT -8. The time now is 08:03 PM. | Welcome to Forum, please register to access all of our features.
