fuel injectors for d15b - Page 2 - D-series.org
Old 10-25-2010, 06:08 PM   #21 (permalink)
Rep Power: 0 chirby is nobody
Originally Posted by tumiljones View Post
If the spark plugs are towards the front of the motor its vtec same cast as z6 head I think. If vtec use z6. If non vtec b7 injectors. The only difference between obd1 and 2 is the tabs don't line up but you can break them off or get the right pluggs and you can use the injectors as far as ls injectors I think they would work but may run rich don't know much about them.
thanks for the infoo reppp.. i still need to know about the ls tho. and my head code is p2j-2 is this stage 3 vtec or wat?
chirby is offline   Reply With Quote Quick reply to this message
Old 10-25-2010, 06:13 PM   #22 (permalink)
Rusty Ratchet's Avatar
Rep Power: 8 Rusty Ratchet is learning the way of the DRusty Ratchet is learning the way of the D
so it sounds like you have a JDM d15 block with a Y8 head.. are you using the Y8 intake manifold?
good news everyone!
Rusty Ratchet is offline   Reply With Quote Quick reply to this message
Old 10-25-2010, 06:22 PM   #23 (permalink)
96 EX D16Y8 Auto------P2J-2 stamped 95 on rs of head
THE OBD-II 3 stage VTEC D15B 96^
(2) VTEC solenoids
Head Code "P2J"
year Code "95"
intake mani also stamped "P2J" on the back
this is how you tell. thanks to,
http://www.sohchonda.com/forums/index.php?showtopic=135
good news everyone!
Old 10-25-2010, 06:28 PM   #24 (permalink)
yeah its a y8 i jus check with a y8 tb
Old 10-25-2010, 06:29 PM   #25 (permalink)
(2) VTEC solenoids
Head Code "P2J"
year Code "95"
D Series Head Codes - SOHCHonda.com
so is the wires obd1 or obd2? sorry im noob
Old 10-25-2010, 06:30 PM   #26 (permalink)
thanks dude for u timess ill rep for uuu
Old 10-25-2010, 06:38 PM   #27 (permalink)
i still need to know is it obd1 or 2 please help ill rep
Old 10-25-2010, 06:45 PM   #28 (permalink)
the injectors are for a 96 civic EX
so you can have the injectors cleaned and pattern tested or you could buy new ones. i would stick with the injector type you currently have. whats the reason for changing your injectors?
good news everyone!
Old 10-25-2010, 06:51 PM   #29 (permalink)
im thinking its obd2 because the head is from a 96 honda civic ex
good news everyone!
Old 10-25-2010, 06:51 PM   #30 (permalink)
its not firing. like its bogging and dying. like not giving enough gas but fuel pump is good cuz everytime it dies it starts back up. so im guesss its the fuel injectors. but if i do buy one do u recommend me buy a obd2 from a z6 or somthing? thanks
Old 10-25-2010, 06:52 PM   #31 (permalink)
that's wen i drive it for a while and it starts to act up and with a high idle then wen i press the gas the rpm doesnt go up wen i press it, then 2 second later its goes up after i press the gas sorrry if i dont make sense
Old 10-25-2010, 06:53 PM   #32 (permalink)
i change the fuel filter also
Old 10-25-2010, 07:00 PM   #33 (permalink)
yeah thats wat i was thinking also, do u think the juffy lube can see if its a obd2 or 1 or 0?
Old 10-25-2010, 07:09 PM   #34 (permalink)
are you sure your ignition timing and mechanical timing are correct?
good news everyone!
Old 10-25-2010, 07:10 PM   #35 (permalink)
idk cuz i dont know how to check to those..sorry im trying to learn
Old 10-25-2010, 07:11 PM   #36 (permalink)
is there a sticker on your ECU? if so whats the number off it?
good news everyone!
Old 10-25-2010, 07:13 PM   #37 (permalink)
your ECU is located on the passenger side it may be under the carpet it looks like a silver or gray box with a lot of wiring running to it.
good news everyone!
Old 10-25-2010, 07:14 PM   #38 (permalink)
the ecu is p28 if this helps..but do u want me to check for wat numbers? cuz ill do it right now.
Old 10-25-2010, 07:18 PM   #39 (permalink)
jdm_trai's Avatar
Rep Power: 10 jdm_trai is learning the way of the Djdm_trai is learning the way of the D
wat car is it?
I Old SkooL
jdm_trai is offline   Reply With Quote Quick reply to this message
Old 10-25-2010, 07:19 PM   #40 (permalink)
jdm_trai's Avatar
pics may help too
I Old SkooL
iconAll times are GMT -8. The time now is 05:41 PM. | Welcome to Forum, please register to access all of our features.
