Need help again!!! - D-series.org
Old 08-05-2010, 04:21 PM   #1 (permalink)
Rep Power: 0 kingsnake692005 is nobody
Default Need help again!!!
I have a rebuilt d16a6 head that I wanna put on my d15b2 block... I also have a d16z6 intake mani to put on the head & to do my mpfi swap when I swap the heads...
My question is that can I use my b2 dizzy on the a6 head. I have been reading & alot of people say that you cant because the d16a6 dizzy has a crank angle sensor & the d15b2 dont...
If i can use my d15b2 dizzy is there a way to put a crank angle sensor in or on a d15b2 dizzy to make it work for the d16a6 head???
kingsnake692005 is offline   Reply With Quote
Old 08-07-2010, 05:14 PM   #2 (permalink)
RandysSOHC's Avatar
Rep Power: 8 RandysSOHC is a name known to allRandysSOHC is a name known to allRandysSOHC is a name known to allRandysSOHC is a name known to allRandysSOHC is a name known to allRandysSOHC is a name known to allRandysSOHC is a name known to allRandysSOHC is a name known to all
you can't put the sensor in the b2 dizzy.
the si dizzy is required if you change the ecu, changing the ecu is reuired for running 4 injectors,
so yes, the b2/b1 original d15 dizzys won't work on a multiport setup (a6, b2/a6 setup)
should be able to hit the si dizzy up on ebay for around 60$ or somthin...
I done the swap a while back it wasn't hard if you have everything to do it at once & good luck
R.I.P boosted b8 ed
RandysSOHC is offline   Reply With Quote
Old 08-07-2010, 05:19 PM   #3 (permalink)
crxdonwon's Avatar
Rep Power: 4 crxdonwon is a name known to allcrxdonwon is a name known to allcrxdonwon is a name known to allcrxdonwon is a name known to allcrxdonwon is a name known to allcrxdonwon is a name known to allcrxdonwon is a name known to allcrxdonwon is a name known to allcrxdonwon is a name known to allcrxdonwon is a name known to all
To do the MPFI swap you have to wire in the injectors, resistor box, and a few more for the Distributor. You have to have a SI distributor, resistor box, IM, and ECU.
crxdonwon is online now   Reply With Quote
Old 08-08-2010, 02:48 PM   #4 (permalink)
well about the mpfi swap Imma be running obd1 injectors so I dont have to run a resistor box & I can get a dizzy for about 30 bucks but ive just been hard on cash so im trying to make the money to get the dizzy
iconAll times are GMT -8. The time now is 03:30 AM. | Welcome to Forum, please register to access all of our features.
