weak window regulator - D-series.org
Old 08-01-2010, 04:09 PM   #1 (permalink)
lilryanadamse's Avatar
Rep Power: 9 lilryanadamse is learning the way of the Dlilryanadamse is learning the way of the D
Default weak window regulator
my driver side window regulator is getting weak. when you shut the door, the window falls a little. is there a way to tighten it or does it need replaced. my windows are manual, not electric.
thanks
ryan
96 dx civic saloon with full hx swap. 40mpg
lilryanadamse is offline   Reply With Quote
Old 08-01-2010, 05:11 PM   #2 (permalink)
bumpstick's Avatar
Rep Power: 7 bumpstick is about to blow upbumpstick is about to blow upbumpstick is about to blow upbumpstick is about to blow upbumpstick is about to blow upbumpstick is about to blow upbumpstick is about to blow upbumpstick is about to blow upbumpstick is about to blow upbumpstick is about to blow upbumpstick is about to blow upbumpstick is about to blow upbumpstick is about to blow upbumpstick is about to blow upbumpstick is about to blow up
replace it. i got both sides online for the same price as the dealer wanted, did both at the same time, and think it's probably the best $130 I ever spent. My windows are smooth as silk and I don't worry about the glass falling out of the track anymore
Need help installing a multiplexer? PM me.
bumpstick is offline   Reply With Quote
Old 08-01-2010, 05:43 PM   #3 (permalink)
EJ6Z's Avatar
Rep Power: 4 EJ6Z is almost a somebodyEJ6Z is almost a somebodyEJ6Z is almost a somebodyEJ6Z is almost a somebody
where is the best place to buy them I am having the same issue?
EJ6Z is offline   Reply With Quote
Old 08-01-2010, 06:41 PM   #4 (permalink)
thanks for the advice. was it a pain to do. i have done it on a camaro, but not a honda. are they riveted in.
Old 08-01-2010, 10:21 PM   #5 (permalink)
bumpstick's Avatar
just look around online and compare. I did Hondapartsdeals.com but some people swear by Majestic Honda. I got both pass and driver for what my local dealer wanted for just one side.
No it's pretty easy. Having a friend help hold the window up and steer it in makes it way easier, but you can just tape the glass up if you're all alone. It's literally a half dozen 10mm bolts, really easy once you see it up close. Getting the old regulator out is probably the worst part
Old 08-01-2010, 10:31 PM   #6 (permalink)
2jzdreamin's Avatar
Rep Power: 11 2jzdreamin is the fucking MAN!!!!2jzdreamin is the fucking MAN!!!!
2jzdreamin is the fucking MAN!!!!2jzdreamin is the fucking MAN!!!!2jzdreamin is the fucking MAN!!!!2jzdreamin is the fucking MAN!!!!2jzdreamin is the fucking MAN!!!!2jzdreamin is the fucking MAN!!!!2jzdreamin is the fucking MAN!!!!2jzdreamin is the fucking MAN!!!!2jzdreamin is the fucking MAN!!!!2jzdreamin is the fucking MAN!!!!2jzdreamin is the fucking MAN!!!!2jzdreamin is the fucking MAN!!!!2jzdreamin is the fucking MAN!!!!
what year car??
MY BUILD THREAD WITH WIRE AND BRAKE LINE TUCK http://www.d-series.org/forums/showc...line-tuck.html
PM me for obd1 & obd2 tucked mil spec harnesses
http://www.d-series.org/forums/sale/...e-harness.html
all so do vtec sub-harness
tucked headlight harness
http://www.d-series.org/forums/showc...-hottness.html
2jzdreamin is online now   Reply With Quote
Old 08-02-2010, 08:14 AM   #7 (permalink)
EJ6Z's Avatar
Thanks bumpstick, I didn't know if there was any other place. I usually go to either of the ones you mentioned.
Old 08-02-2010, 09:25 AM   #8 (permalink)
one grumpy old man
Darin T's Avatar
Rep Power: 11 Darin T is the fucking MAN!!!!Darin T is the fucking MAN!!!!Darin T is the fucking MAN!!!!
its prob for the 96-98 chassis.i did mine and i got the part from honda.was about 120.00.CAD
FARMYARD
10.967 @ 129.57 vitara z6/y8 2012
10.437 @ 133.72 vitara a6/y8 2011
10.583 @ 137.00 vitara a6/y8 2010
Darin T is offline   Reply With Quote
Old 08-02-2010, 11:24 AM   #9 (permalink)
EJ6Z's Avatar
there anywhere from 85 to 95 and they aren't hard to replace.
Old 08-02-2010, 04:40 PM   #10 (permalink)
Originally Posted by 2jzdreamin View Post
what year car??
96 4door
iconAll times are GMT -8. The time now is 10:45 PM. | Welcome to Forum, please register to access all of our features.
