Water on pass. floor when it rains - D-series.org
Old 05-19-2010, 04:08 PM   #1 (permalink)
hotrodj's Avatar
Rep Power: 13 hotrodj is a Top Aussie
iTrader Score: 30 reviews
Default Water on pass. floor when it rains
I have a 94 del Sol. When it rains good, i get a puddle on the floor boards under the dash on the pass. side. I can see where the water drips from under the dash, about 3-4 inches to the left of the ecu. BUt cant find where it is coming into the car. Anyone have this before on a Sol or Eg?
Its def not coolant, like from the heater core. It only happens when i rains.
94 del Sol si 144whp, 113tq
I/H/E, pnp y8 head,Bisi lvl2, Hondata S300,
Stock Z6 bottom end
PM for ECU Chipping/Socketing and Repair Prices
Old 05-19-2010, 04:16 PM   #2 (permalink)
Rep Power: 8 Mayfieldfour is starting to learn the ropesMayfieldfour is starting to learn the ropesMayfieldfour is starting to learn the ropesMayfieldfour is starting to learn the ropesMayfieldfour is starting to learn the ropesMayfieldfour is starting to learn the ropes
iTrader Score: 16 reviews
MY old DA did the same thing. The windshield wiper cowl has a bunch of plastic button thingees helping hold it down. Underneath those, there are some rubber grommet boot things that just get brittle over the years. I think a full set was about $15 from Acura. I replaced all those nad the leak was gone. Not sure if the Del Sol is the same or not, but I'd at least look into that.
Mayfieldfour is offline   Reply With Quote Quick reply to this message
Old 05-19-2010, 04:32 PM   #3 (permalink)
hotrodj's Avatar
Yes they do man lol I had 1 missing and replaced it. Majestic Honda has them. Hmmm, guess im replaceing them all with black RTV tomorrow lol
Rep sent
Stock Z6 bottom end
Old 05-19-2010, 05:36 PM   #4 (permalink)
I went that route first and still got a tiny leak. Could have been a poor job or could have not seen some holes and jsut missed, I don't know. Honestly, I'd jsut recommend spending the money on the new grommets.
Old 05-19-2010, 05:41 PM   #5 (permalink)
Ralphyeg6's Avatar
Rep Power: 10 Ralphyeg6 is trying to make new friends
Any one got a link for those grommets I have the same problem and its driving me crazy.
Ralphyeg6 is offline   Reply With Quote Quick reply to this message
Old 05-19-2010, 06:15 PM   #6 (permalink)
It's that time again
EJ1 SCRAPPIN's Avatar
Rep Power: 29 EJ1 SCRAPPIN is on a level you can only DREAM about! ! !EJ1 SCRAPPIN is on a level you can only DREAM about! ! !
EJ1 SCRAPPIN is on a level you can only DREAM about! ! !EJ1 SCRAPPIN is on a level you can only DREAM about! ! !EJ1 SCRAPPIN is on a level you can only DREAM about! ! !EJ1 SCRAPPIN is on a level you can only DREAM about! ! !EJ1 SCRAPPIN is on a level you can only DREAM about! ! !EJ1 SCRAPPIN is on a level you can only DREAM about! ! !EJ1 SCRAPPIN is on a level you can only DREAM about! ! !EJ1 SCRAPPIN is on a level you can only DREAM about! ! !EJ1 SCRAPPIN is on a level you can only DREAM about! ! !EJ1 SCRAPPIN is on a level you can only DREAM about! ! !EJ1 SCRAPPIN is on a level you can only DREAM about! ! !EJ1 SCRAPPIN is on a level you can only DREAM about! ! !EJ1 SCRAPPIN is on a level you can only DREAM about! ! !
iTrader Score: 55 reviews
Send a message via AIM to EJ1 SCRAPPIN
it could also be the rubber harness protector(idk the real name) between the door and chassis.......if its popped off from chassis side you will def get a leak
NOR*CAL
EJ1 SCRAPPIN is offline   Reply With Quote Quick reply to this message
Old 05-19-2010, 06:20 PM   #7 (permalink)
Rep Power: 0 swetty is nobody
good deal. i have this problem too, it was worse in my accord that i had previously.
swetty is offline   Reply With Quote Quick reply to this message
Old 05-19-2010, 06:20 PM   #8 (permalink)
patprimmer's Avatar
Of course the red neck fix (or ghetto fix) is to have no carpet in the firstplace then just drill a hole in the floor to let it run straight through.
Seriously, buy the grommets, They don't need to be Honda OEM. They just need to be the correct size to fill the hole with a good fit so they seal.
Regards
Pat. RIP Feb 22, 2013.
my CRX thread
my intro
Old 05-19-2010, 06:27 PM   #9 (permalink)
Rep Power: 9 94hatchSI smells like Borat94hatchSI smells like Borat94hatchSI smells like Borat94hatchSI smells like Borat94hatchSI smells like Borat94hatchSI smells like Borat
What grommets are these? I have this same issue. Water runs down the backside of my firewall and soaks my passenger side floor board.
94hatchSI is offline   Reply With Quote Quick reply to this message
Old 05-19-2010, 07:09 PM   #10 (permalink)
patprimmer's Avatar
Read the thread
Regards
my CRX thread
my intro
Old 05-19-2010, 07:35 PM   #11 (permalink)
Originally Posted by patprimmer View Post
Read the thread
Great response... I guess I should have been a little more clear. Does anyone know the part number for these?
Old 05-20-2010, 10:24 AM   #12 (permalink)
FarmerD is on a level you can only DREAM about! ! !FarmerD is on a level you can only DREAM about! ! !FarmerD is on a level you can only DREAM about! ! !FarmerD is on a level you can only DREAM about! ! !FarmerD is on a level you can only DREAM about! ! !FarmerD is on a level you can only DREAM about! ! !FarmerD is on a level you can only DREAM about! ! !FarmerD is on a level you can only DREAM about! ! !FarmerD is on a level you can only DREAM about! ! !
every time it happens to cars i own its the actual windshield not the grommets.
just sharing what ive experienced.
Old 05-20-2010, 11:23 AM   #13 (permalink)
You mean the seal on the windshield? How'd you fix it? Have the windshield pulled and re-set?
Old 05-20-2010, 01:15 PM   #14 (permalink)
yep
Old 05-23-2010, 05:58 PM   #15 (permalink)
hotrodj's Avatar
well I think I have those taken care of. Just waitin for some rain now to find out lol
Anyone do del Sol top seals before? I replaced them, was easy, but now its leaking in a diff place on the top.
Stock Z6 bottom end
Old 05-23-2010, 06:10 PM   #16 (permalink)
patprimmer's Avatar
Maybe you have a blocked drain hole.
Regards
my CRX thread
my intro
Old 05-23-2010, 06:25 PM   #17 (permalink)
hotrodj's Avatar
They are all clear man. I replaced all the top seals, but the leak used to be on the drivers side. Now is on the pass side, coming from the side of the top dripping onto the pass seat. I know and see exactly where its coming from. Just need to find out how to stop it. The seals are all seated properly and no gaps where the window touches the seals.
Stock Z6 bottom end
Old 05-23-2010, 06:35 PM   #18 (permalink)
hotrodj's Avatar
Go to MajesticHonda.com
Stock Z6 bottom end
Old 05-25-2010, 09:42 PM   #19 (permalink)
PianoMan's Avatar
Rep Power: 11 PianoMan smells like BoratPianoMan smells like BoratPianoMan smells like BoratPianoMan smells like BoratPianoMan smells like BoratPianoMan smells like Borat
Have you figured out whether the problem's been fixed? I've got the exact same problem on my Sol, LOL. Rep for OP and MFF for bringing this up!
D16z6
JRSC @6psi & RC 440cc Injectors
Hondata/JRSC Re-Programmed s300 ECU
Eibach Pro-System Plus (Springs, Dampers, and Anti-Roll Kit)
Buying, when I gets $$$ and time to put in: 8psi pulley from ASP Racing.
PianoMan is offline   Reply With Quote Quick reply to this message
Old 05-26-2010, 05:18 PM   #20 (permalink)
hotrodj's Avatar
No leaks with todays rain storm. Yesterday was a bad storm, still had water ont he pass side floor. Gotta seal the cowl thingys better. And drivers seat was wet.
Was a good heavy downpour today, not a drop inside. Going to spray a lil silicone spray on the new seals. Seemed to help a bit with the old seals. Heard its good to take the top off and leave it off while spraying/greasing the seals. Supposed to try to give them as long as possible to absorb the silicone.
I wipe off the areas of the seals that touch the window good before putting them up after also. Helps keep it off the glass for easier cleanup.
Gonna try tightening the latches next. Ive been trying to find out how on the web (google).
Stock Z6 bottom end
iconAll times are GMT -8. The time now is 12:51 PM. | Welcome to Forum, please register to access all of our features.
