Manual crank windows hard to roll up. - D-series.org
Old 01-28-2010, 01:53 AM   #1 (permalink)
SOHCitTOem's Avatar
Rep Power: 14 SOHCitTOem is hot as a volcanoSOHCitTOem is hot as a volcano
iTrader Score: 20 reviews
Default Manual crank windows hard to roll up.
I tried greasing the whole regulator assembly and sprayed wd40 into the guides that are in the door but it still is extremely hard to roll up and down. Any suggestions?
built single cam.
track tool.
SOHCitTOem is offline   Reply With Quote Quick reply to this message
Old 01-28-2010, 02:10 AM   #2 (permalink)
immajackuup's Avatar
Rep Power: 12 immajackuup is fly like an eagleimmajackuup is fly like an eagleimmajackuup is fly like an eagleimmajackuup is fly like an eagleimmajackuup is fly like an eagleimmajackuup is fly like an eagleimmajackuup is fly like an eagleimmajackuup is fly like an eagleimmajackuup is fly like an eagleimmajackuup is fly like an eagleimmajackuup is fly like an eagle
lol im having the same problem but if i roll it down while is really hard it will pop out of track.
Best lubrication for window seal?
immajackuup is offline   Reply With Quote Quick reply to this message
Old 01-28-2010, 02:46 AM   #3 (permalink)
bumpstick's Avatar
Rep Power: 12 bumpstick is about to kiss the sky
bumpstick is about to kiss the skybumpstick is about to kiss the skybumpstick is about to kiss the skybumpstick is about to kiss the skybumpstick is about to kiss the skybumpstick is about to kiss the skybumpstick is about to kiss the sky
iTrader Score: 31 reviews
ugh. i hate 96-00 window regulators. try replacing with OEM new or OEM from junkyard, cuz they will only get worse
CAST MANI MILLIONAIRES
bumpstick is offline   Reply With Quote Quick reply to this message
Old 01-28-2010, 02:53 AM   #4 (permalink)
Friend of the D
Aragorn's Avatar
Rep Power: 24 Aragorn Still a JDM Star....Aragorn Still a JDM Star....
Aragorn Still a JDM Star....Aragorn Still a JDM Star....Aragorn Still a JDM Star....
Yup! Also, be sure your window is on the track in the first place. My driver's side goes up and down real easy until it comes off the track. My front track appears to have been bent at some point. No much, but enough to be a pain in the ass.
Aragorn is offline   Reply With Quote Quick reply to this message
Old 01-28-2010, 03:09 AM   #5 (permalink)
uptownsamcv's Avatar
Rep Power: 9 uptownsamcv is a name known to alluptownsamcv is a name known to alluptownsamcv is a name known to alluptownsamcv is a name known to alluptownsamcv is a name known to alluptownsamcv is a name known to alluptownsamcv is a name known to alluptownsamcv is a name known to all
i had the same problem. what i did was when i set the glue i wouldnt fully close the window untill it seated into the seal. use a silicone lubricant spray.
uptownsamcv is offline   Reply With Quote Quick reply to this message
Old 01-28-2010, 10:04 AM   #6 (permalink)
cmgreen50's Avatar
Rep Power: 20 cmgreen50 is the fucking MAN!!!!cmgreen50 is the fucking MAN!!!!cmgreen50 is the fucking MAN!!!!cmgreen50 is the fucking MAN!!!!
cmgreen50 is the fucking MAN!!!!cmgreen50 is the fucking MAN!!!!cmgreen50 is the fucking MAN!!!!cmgreen50 is the fucking MAN!!!!cmgreen50 is the fucking MAN!!!!cmgreen50 is the fucking MAN!!!!
hit the gym
i seriously have a donkey if you're serious..
The problem is, my need for speed exceeds the need to save the earth.
WELL FINE! I'LL JUST GO EAT THE SHIT OUTTA MY OREO'S THEN!
cmgreen50 is offline   Reply With Quote Quick reply to this message
Old 01-28-2010, 11:10 AM   #7 (permalink)
SOHCitTOem's Avatar
^ lol. Yeah the knob is broken too so it is a PITFA to roll down my window.
There's no way to fix this without spending money? I'm not to sure whats causing this to happen. I mean with the regulator out, it moves smooth but put it back in and it just doesnt cooperate. If the guides were the problem how would I replace those? I know there are. 10mm bolt at the bottom but how about the top part?
built single cam.
track tool.
Old 01-28-2010, 11:18 AM   #8 (permalink)
amperu's Avatar
Rep Power: 24 amperu is on a level you can only DREAM about! ! !amperu is on a level you can only DREAM about! ! !
amperu is on a level you can only DREAM about! ! !amperu is on a level you can only DREAM about! ! !amperu is on a level you can only DREAM about! ! !amperu is on a level you can only DREAM about! ! !amperu is on a level you can only DREAM about! ! !amperu is on a level you can only DREAM about! ! !amperu is on a level you can only DREAM about! ! !amperu is on a level you can only DREAM about! ! !amperu is on a level you can only DREAM about! ! !amperu is on a level you can only DREAM about! ! !amperu is on a level you can only DREAM about! ! !amperu is on a level you can only DREAM about! ! !amperu is on a level you can only DREAM about! ! !amperu is on a level you can only DREAM about! ! !
Ive got the same problem, I thought it was because my ride was previously in an accident. My locks barely work as well. I was gonna try a power window system from AutoLoc.
I've got Super Street taste and an eBay budget!
Amperu is fucking winning. Hard.
Is there anything you aren't badass at? Lol
RIP - patprimmer
amperu is offline   Reply With Quote Quick reply to this message
Old 02-20-2011, 07:29 PM   #9 (permalink)
Rep Power: 0 jgw1986 is nobody
from wrestling with mine tonight, I found the culprit to be the front track, top bolt(which is behind the trim panel where the side view mirror bolts to) wasnt tightened down, which led to the rubber squeezing on the front of the window.
jgw1986 is offline   Reply With Quote Quick reply to this message
Old 02-20-2011, 10:04 PM   #10 (permalink)
Rep Power: 0 sxysweed It's a JDM Star Bitches....
sxysweed It's a JDM Star Bitches....sxysweed It's a JDM Star Bitches....
Take the whole assembly out, grease the assembly good and make sure it moves smoothly (mine had dirt build up that kept the slider from moving). Then put it back, mount the window, and roll it all the way up (but make sure adjustment screws are loose), then tighten everything down.
The guides and weather stripping can also be old/bent out of shape, and may need replacing.
sxysweed is offline   Reply With Quote Quick reply to this message
iconAll times are GMT -8. The time now is 03:20 PM. | Welcome to Forum, please register to access all of our features.
