Retuned D16z6 Turbo **Goodies inside** - D-series.org
Old 07-24-2015, 07:01 PM   #1 (permalink)
jrock162000's Avatar
Rep Power: 10 jrock162000 smells like Boratjrock162000 smells like Boratjrock162000 smells like Boratjrock162000 smells like Boratjrock162000 smells like Borat
Default Retuned D16z6 Turbo **Goodies inside**
What's up DSO crew! I decided to get my car retuned after rebuilding the engine (oem) and wanted to share results.
Car drives extremely well and is a blast to drive! Specs, pics and final numbers are below.
Stock rebuilt D16z6 (by me)
75.5mm nippon replacement pistons
Stock rods
kings standard bearings
stock head shaved (.015) yielding 9.5.1 comp
Arp head studs
Skunk 2 intake manifold , ls throttle body
Turbonetics super 60 .63> 3 inch intake, k&n filter
Go-auto cast log
Go-auto Dp & Dump
2.5 inch exhaust dyno max muffler (extremely quiet)
Final numbers where 233whp & 192 trq at 9psi
"2015 Garage"
1997 Honda Crv FWD
2010 Honda Fit Sport
93 Civic Lx Sdn D16Z6-T 233whp & 193 trq
jrock162000 is offline   Reply With Quote Quick reply to this message
Old 07-24-2015, 07:04 PM   #2 (permalink)
Rep Power: 50 slo_eg8 is on a level you can only DREAM about! ! !slo_eg8 is on a level you can only DREAM about! ! !
slo_eg8 is on a level you can only DREAM about! ! !slo_eg8 is on a level you can only DREAM about! ! !slo_eg8 is on a level you can only DREAM about! ! !slo_eg8 is on a level you can only DREAM about! ! !slo_eg8 is on a level you can only DREAM about! ! !slo_eg8 is on a level you can only DREAM about! ! !slo_eg8 is on a level you can only DREAM about! ! !slo_eg8 is on a level you can only DREAM about! ! !slo_eg8 is on a level you can only DREAM about! ! !slo_eg8 is on a level you can only DREAM about! ! !slo_eg8 is on a level you can only DREAM about! ! !slo_eg8 is on a level you can only DREAM about! ! !slo_eg8 is on a level you can only DREAM about! ! !slo_eg8 is on a level you can only DREAM about! ! !
stock rods at 233? props.
totaled. 93 EJ2
NEW 95 ej1
d16y7 block with z6 head
y7 transmission
ls meshies, oem wing, blacked out tails with h.i.d head lights
Old 07-24-2015, 07:14 PM   #3 (permalink)
Thanks. Every single cam I've had in the past I ran between 225-230whp for years with no issues. I actually drive like a granny which is probably why. I ain't scuurred
"2015 Garage"
1997 Honda Crv FWD
Old 07-25-2015, 03:37 AM   #4 (permalink)
robgoof's Avatar
Rep Power: 13 robgoof is the fucking MAN!!!!robgoof is the fucking MAN!!!!robgoof is the fucking MAN!!!!robgoof is the fucking MAN!!!!
robgoof is the fucking MAN!!!!robgoof is the fucking MAN!!!!robgoof is the fucking MAN!!!!robgoof is the fucking MAN!!!!robgoof is the fucking MAN!!!!robgoof is the fucking MAN!!!!robgoof is the fucking MAN!!!!robgoof is the fucking MAN!!!!robgoof is the fucking MAN!!!!robgoof is the fucking MAN!!!!robgoof is the fucking MAN!!!!
nice whip
Old 07-25-2015, 03:37 AM   #5 (permalink)
evo_lucian's Avatar
Rep Power: 5 evo_lucian is about to blow upevo_lucian is about to blow upevo_lucian is about to blow upevo_lucian is about to blow upevo_lucian is about to blow upevo_lucian is about to blow upevo_lucian is about to blow upevo_lucian is about to blow upevo_lucian is about to blow upevo_lucian is about to blow upevo_lucian is about to blow upevo_lucian is about to blow upevo_lucian is about to blow upevo_lucian is about to blow upevo_lucian is about to blow up
Send a message via Skype™ to evo_lucian
Real good power. Must be a blast to drive on the streets
evo_lucian is offline   Reply With Quote Quick reply to this message
Old 07-25-2015, 04:42 AM   #6 (permalink)
Originally Posted by robgoof View Post
nice whip
Thanks Rob! How'd the pistons work out for ya?
"2015 Garage"
1997 Honda Crv FWD
Old 07-25-2015, 05:52 AM   #7 (permalink)
Full_Tilt's Avatar
Rep Power: 27 Full_Tilt is on a level you can only DREAM about! ! !Full_Tilt is on a level you can only DREAM about! ! !Full_Tilt is on a level you can only DREAM about! ! !
Full_Tilt is on a level you can only DREAM about! ! !Full_Tilt is on a level you can only DREAM about! ! !Full_Tilt is on a level you can only DREAM about! ! !Full_Tilt is on a level you can only DREAM about! ! !Full_Tilt is on a level you can only DREAM about! ! !Full_Tilt is on a level you can only DREAM about! ! !Full_Tilt is on a level you can only DREAM about! ! !Full_Tilt is on a level you can only DREAM about! ! !Full_Tilt is on a level you can only DREAM about! ! !Full_Tilt is on a level you can only DREAM about! ! !Full_Tilt is on a level you can only DREAM about! ! !Full_Tilt is on a level you can only DREAM about! ! !Full_Tilt is on a level you can only DREAM about! ! !
I hate shops that start the dyno pulls so high. Its impossible to see what spool is like when the run starts at 4k.
Old 07-25-2015, 07:53 AM   #8 (permalink)
Yup that's all i received. I can't give exact data, but the setup is quite responsive around town.
"2015 Garage"
1997 Honda Crv FWD
Old 07-25-2015, 10:30 AM   #9 (permalink)
Rep Power: 0 Francisco.jj26 is nobody
Sorry to just ask a question in your thread but what is a good staring point , like 3000?
Jimmy turbo
Check out the Build :
Francisco.jj26 is offline   Reply With Quote Quick reply to this message
Old 07-25-2015, 10:34 AM   #10 (permalink)
Full_Tilt's Avatar
Depends on what you want. If you just need to see a peak number or see your power band from 5k+ rpm, then you can start at high rpm.
Personally I like dynos to start much, much lower...
Youre actually cheating yourself out of some torque by starting high on a dynojet. Turbos spool slower on dynojets because theyre not load-holding.
OP's setup is a perfect example. I bet on the street it can hit peak boost before 5k rpm, but on this dyno it looks like it didnt get spooled until then. I bet there is a lot of torque left out of this dyno below 5k rpm.
Old 07-25-2015, 11:05 AM   #11 (permalink)
Two men shy of a group
Blu3's Avatar
Rep Power: 16 Blu3 is the fucking MAN!!!!Blu3 is the fucking MAN!!!!Blu3 is the fucking MAN!!!!Blu3 is the fucking MAN!!!!
Nice those are similar to my numbers, I believe in crome it was showing like 6.7psi on my t3 60 trim .42/.48 and I made 222whp 179tq, I've since turned it up and adjusted the fuel tables, wonder if im in the 230 range yet (running 7.9psi now)
my turbo hx build :
turbo 99 ex sedan A/C build -
Alicia Aemisegger
Blu3 is offline   Reply With Quote Quick reply to this message
Old 07-26-2015, 10:30 AM   #12 (permalink)
Oaken81's Avatar
Rep Power: 0 Oaken81 is nobody
Nice build!
Oaken81 is offline   Reply With Quote Quick reply to this message
Old 07-28-2015, 03:25 PM   #13 (permalink)
The_Acid_Beaver's Avatar
Dynos don't show turbo spool well at all, nor do they show transients in most cases.
I think it is pretty daffy to not have rods in at that point, but, the power output looks like a lot of fun.
RTFM. No, really. Do it.
Old 12-30-2016, 03:27 PM   #14 (permalink)
I'm all late this graph looks awesome as crap!
"2015 Garage"
1997 Honda Crv FWD
Old 12-30-2016, 03:36 PM   #15 (permalink)
Sharing my latest couple of mods. Triple pod by Ortiz custom pods ( steering column). They make some really cool oem fitting pods. Great for housing my oil pressure, boost , & air/fuel (AEM). This has made my driving experience so awesome.
Running awesome and I've also upgraded to Bpi Velocity Stack/K&N filter setup. I'm all about a clean organized engine bay
Here is also my graph on 11.2 psi producing
249whp & 197 lb-ft
Not sure what the hell happened at the end of the pull there lol.
"2015 Garage"
1997 Honda Crv FWD
Old 12-30-2016, 03:41 PM   #16 (permalink)
jvtec8k's Avatar
Rep Power: 20 jvtec8k Still a JDM Star....jvtec8k Still a JDM Star....
jvtec8k Still a JDM Star....jvtec8k Still a JDM Star....jvtec8k Still a JDM Star....jvtec8k Still a JDM Star....jvtec8k Still a JDM Star....jvtec8k Still a JDM Star....jvtec8k Still a JDM Star....jvtec8k Still a JDM Star....jvtec8k Still a JDM Star....jvtec8k Still a JDM Star....jvtec8k Still a JDM Star....jvtec8k Still a JDM Star....
Send a message via ICQ to jvtec8k Send a message via AIM to jvtec8k Send a message via Yahoo to jvtec8k Send a message via Skype™ to jvtec8k
That's a nice and simple build man I bet it's a blast to drive around.
D16z6 vitara/p2p, Y8 Lsd trans, V2/M&H 23", Rocket Motorsports cam, Garrettt 57trim
15.3 89mph 2011 D16z6 CAI
13.8 102mph 2012 Stock Z6
11.7 119mph 2013 Ebay turbo 18psi
11.0 125mph 2014 23" M&h slipping clutch
10.8 132mph 2015 clutch slipped 418whp E85
Insta: jvtec8k
jvtec8k is offline   Reply With Quote Quick reply to this message
Old 12-30-2016, 03:57 PM   #17 (permalink)
Rep Power: 1 Jfab is learning the way of the DJfab is learning the way of the D
I love the simplicity of it. I am working on my 99 sedan now. Great work. Not sure if I missed it, but what are you using for software? I used to use neptune but have been out for a while.
Jfab is offline   Reply With Quote Quick reply to this message
Old 01-04-2017, 02:57 AM   #18 (permalink)
Thanks man! It's definitely an enjoyable setup. I've been following your builds / YouTube for a bit. Keep kicking ass man 😀
"2015 Garage"
1997 Honda Crv FWD
Old 01-04-2017, 03:00 AM   #19 (permalink)
Much appreciated Jfab. I'm using Neptune for my tuning software.
"2015 Garage"
1997 Honda Crv FWD
Old 01-04-2017, 04:55 AM   #20 (permalink)
I used neptune back on my hatch in 2011 and kind of got out of the honda game in 2013. Glad to see neptune is still being used. It will be going into my 99 sedan this year.
iconAll times are GMT -8. The time now is 05:28 PM. | Welcome to Forum, please register to access all of our features.
