i was wondering how much boost can i get away with without having to run e85 or race fuel or running water/meth injection on pump gas? my motor consist of y7 block with z6 head
eagle rods
vitara 75.5 piston
comp cam valve springs
crower stage 2 na for now waiting on my delta 272-2 to get back and then retune wanting to run higher boost on pump gas
ported head
stock IM and TB
sls top mount manifold
bullseye s256 turbo
as of now im running 18-19 lbs on pump gas but wanting to up the boost when i switch the cam over to make more power but unsure of how much i can run and be able to get away with it just by running pump. since this is my dd car and i take it everywhere i go long trips and it will be almost impossible to run e85 i just want to be able to get gas everywhere. its making 302whp and 246 tq im hopeing to be somewhere 370 if not more if possible just running pump gas also up the boost if possible and by switching the cams
eagle rods
vitara 75.5 piston
ported head
stock IM and TB
bullseye s256 turbo
