Go Back   D-series.org » Motor Mayhem & Suspension Satisfaction » Forced Induction
Old 02-07-2010, 10:16 PM   #1 (permalink)
v-tecivic's Avatar
Rep Power: 5 v-tecivic smells like Boratv-tecivic smells like Boratv-tecivic smells like Boratv-tecivic smells like Boratv-tecivic smells like Boratv-tecivic smells like Borat
Default Oil Return with an fittings. will this work fine?
im sending my block out soon for machine work, so i mocked my turbo setup to see how it fits. im using a go-autoworks manifold and it sits kind of low. i have a bunch of different fittings and this is all i could come up with.
this is how the oil return line is routed. will it be ok? im sure it will be fine, just need some opinions.
i did have a fitting welded on the pan already, but it was on there from a different manifold setup.
v-tecivic is offline   Reply With Quote
Old 02-07-2010, 10:32 PM   #2 (permalink)
94 R-81 VX type R
Chrisfrom1986's Avatar
Rep Power: 14 Chrisfrom1986 is the fucking MAN!!!!Chrisfrom1986 is the fucking MAN!!!!Chrisfrom1986 is the fucking MAN!!!!
Chrisfrom1986 is the fucking MAN!!!!Chrisfrom1986 is the fucking MAN!!!!Chrisfrom1986 is the fucking MAN!!!!Chrisfrom1986 is the fucking MAN!!!!Chrisfrom1986 is the fucking MAN!!!!Chrisfrom1986 is the fucking MAN!!!!Chrisfrom1986 is the fucking MAN!!!!Chrisfrom1986 is the fucking MAN!!!!
That maybe ok, but ideally you want something that goes straight and only down. Right at the pan it angles up, thats not going to be good for a gravity drain.
94 R-81 VX D15B
Chrisfrom1986 is offline   Reply With Quote
Old 02-07-2010, 10:36 PM   #3 (permalink)
cervan's Avatar
Rep Power: 11 cervan is hot as a volcanocervan is hot as a volcano
cervan is hot as a volcanocervan is hot as a volcanocervan is hot as a volcanocervan is hot as a volcanocervan is hot as a volcanocervan is hot as a volcanocervan is hot as a volcanocervan is hot as a volcanocervan is hot as a volcanocervan is hot as a volcanocervan is hot as a volcano
weld a 45 degree angle going in and then cut a section of hose for it.
Have a question about lightweight front pulley? read this shit before posting:Lightweight pulley thread.
Originally Posted by Zombieland
You're like a giant cockblocking robot, like developed in a secret fucking government lab.
My build in my CRX:
Y8 block with a z6 head stock z6 rods on a redneck portjob oil pump.
cervan is offline   Reply With Quote
Old 02-07-2010, 11:51 PM   #4 (permalink)
94 R-81 VX type R
94 R-81 VX D15B
Old 02-08-2010, 12:19 AM   #5 (permalink)
cervan's Avatar
actually to be honest i wouldnt even mess with AN connections at this point, your so close they would be cumbersome. i would suggest getting two barbed fittings one alluminum and one steel/brass to put into the turbo flange. then running some high heat tubing to the pan.
My build in my CRX:
Old 02-08-2010, 02:04 AM   #6 (permalink)
stiffdogg06's Avatar
Rep Power: 4 stiffdogg06 smells like Boratstiffdogg06 smells like Boratstiffdogg06 smells like Boratstiffdogg06 smells like Boratstiffdogg06 smells like Boratstiffdogg06 smells like Borat
+1
I ran AN fittings for a few weeks last season and I took them off because I barely had 1/2" of braided line showing. I'll be running barbed fittings.
330whp/250ftlbs D16Y8 GT3076R 18psi
stiffdogg06 is offline   Reply With Quote
Old 02-08-2010, 05:34 AM   #7 (permalink)
v-tecivic's Avatar
maybe when i get off work i'll run to the hardware store and pick up some barb fittings. i could probably use the AN fittings for a catch can setup instead.
Old 02-08-2010, 11:05 AM   #8 (permalink)
danz's Avatar
Rep Power: 16 danz is the fucking MAN!!!!danz is the fucking MAN!!!!danz is the fucking MAN!!!!
danz is the fucking MAN!!!!danz is the fucking MAN!!!!danz is the fucking MAN!!!!danz is the fucking MAN!!!!danz is the fucking MAN!!!!danz is the fucking MAN!!!!danz is the fucking MAN!!!!danz is the fucking MAN!!!!danz is the fucking MAN!!!!danz is the fucking MAN!!!!danz is the fucking MAN!!!!danz is the fucking MAN!!!!danz is the fucking MAN!!!!danz is the fucking MAN!!!!danz is the fucking MAN!!!!
id use heater hose for that.
preferably a formed 90 degree 5/8ths heater hose.
my ED6 build thread here!
10.912@127.33mph
Colt Cams
danz is offline   Reply With Quote
Old 02-08-2010, 11:52 AM   #9 (permalink)
99ctrhatch's Avatar
Rep Power: 5 99ctrhatch is starting to learn the ropes99ctrhatch is starting to learn the ropes99ctrhatch is starting to learn the ropes99ctrhatch is starting to learn the ropes99ctrhatch is starting to learn the ropes99ctrhatch is starting to learn the ropes
just get braided stainless line
99ctrhatch is offline   Reply With Quote
Old 02-08-2010, 12:33 PM   #10 (permalink)
speedfoos's Avatar
Rep Power: 10 speedfoos is hot as a volcano
speedfoos is hot as a volcanospeedfoos is hot as a volcanospeedfoos is hot as a volcanospeedfoos is hot as a volcanospeedfoos is hot as a volcanospeedfoos is hot as a volcanospeedfoos is hot as a volcanospeedfoos is hot as a volcanospeedfoos is hot as a volcanospeedfoos is hot as a volcanospeedfoos is hot as a volcanospeedfoos is hot as a volcanospeedfoos is hot as a volcano
^^^ I hate braided stainless line. Shit always messes up your fingers and is a pain to work with. Barbed hose ends and rubber line FTW. You can always wrap it with lock wire to help keep it from collapsing.
I hate Cash for Clunkers.
2008 Lexus IS250
2004 Nissan Frontier "Super Bunny"
1966 Volvo Amazon "Lucille" - 383 Stroker Build!!!
speedfoos is offline   Reply With Quote
Old 02-08-2010, 01:58 PM   #11 (permalink)
Anonymoussquid's Avatar
Rep Power: 3 Anonymoussquid is a name known to allAnonymoussquid is a name known to allAnonymoussquid is a name known to allAnonymoussquid is a name known to allAnonymoussquid is a name known to allAnonymoussquid is a name known to allAnonymoussquid is a name known to allAnonymoussquid is a name known to allAnonymoussquid is a name known to allAnonymoussquid is a name known to all
clock the turbo so the drain is more up and down that would help with this a lot imo.
Anonymoussquid is offline   Reply With Quote
Old 02-08-2010, 01:59 PM   #12 (permalink)
Call the amberlamps!!
Rep Power: 50 ryan89crx is on a level you can only DREAM about! ! !ryan89crx is on a level you can only DREAM about! ! !ryan89crx is on a level you can only DREAM about! ! !ryan89crx is on a level you can only DREAM about! ! !ryan89crx is on a level you can only DREAM about! ! !ryan89crx is on a level you can only DREAM about! ! !ryan89crx is on a level you can only DREAM about! ! !ryan89crx is on a level you can only DREAM about! ! !ryan89crx is on a level you can only DREAM about! ! !ryan89crx is on a level you can only DREAM about! ! !ryan89crx is on a level you can only DREAM about! ! !ryan89crx is on a level you can only DREAM about! ! !ryan89crx is on a level you can only DREAM about! ! !ryan89crx is on a level you can only DREAM about! ! !ryan89crx is on a level you can only DREAM about! ! !
Heater hose isn't too keen on oil. Tends to swell up and eventually split
REAL HMT
My CRX
12.87@109mph
ryan89crx
Delta Cams, best bang for your buck!
ryan89crx is offline   Reply With Quote
Old 02-08-2010, 02:26 PM   #13 (permalink)
Speedjunky01's Avatar
Rep Power: 8 Speedjunky01 is approaching greatnessSpeedjunky01 is approaching greatnessSpeedjunky01 is approaching greatnessSpeedjunky01 is approaching greatnessSpeedjunky01 is approaching greatnessSpeedjunky01 is approaching greatnessSpeedjunky01 is approaching greatnessSpeedjunky01 is approaching greatnessSpeedjunky01 is approaching greatnessSpeedjunky01 is approaching greatnessSpeedjunky01 is approaching greatnessSpeedjunky01 is approaching greatnessSpeedjunky01 is approaching greatness
first setup will work just fine, think about it the turbo is above the top of the oil level, as long as the end of the drain is above the center section of the turbo it will drain fine
resident verbal assault tech Jr.
240,000 miles and counting turbo EH9
nothing like 4drs, ac,moon roof, and 4 whores and running 13psi out or a ching chong t3/t4 setup
the build
http://www.d-series.org/forums/force...-teh-4doh.html
if it survives the winter JdM d15b+Vitara+FJT+25psi=
professional tranny assassin, 2 stock diffs in 4 weeks on street tires and preload was used
Speedjunky01 is offline   Reply With Quote
Old 02-08-2010, 02:37 PM   #14 (permalink)
patprimmer's Avatar
Rep Power: 1 patprimmer smells like Boratpatprimmer smells like Boratpatprimmer smells like Boratpatprimmer smells like Boratpatprimmer smells like Boratpatprimmer smells like Borat
I would braze a steel barbed fitting to the pan at 45 deg and line it up directly below the turbo pretty much like cervan says.
I would use oil or fuel grade rubber line. I don't know if you have Pirtek there, but here they are a chain of industrial hose and fitting specialists and they have a grade of hose called R6 or R600 that is graet for oil lines. They also have a range of steel push on type fittings for it.
Regards
Pat
patprimmer is offline   Reply With Quote
Old 02-08-2010, 03:46 PM   #15 (permalink)
You See Me Hi Hater!!!
Boosted-EH-804's Avatar
Rep Power: 23 Boosted-EH-804 Still a JDM Star....
Boosted-EH-804 Still a JDM Star....Boosted-EH-804 Still a JDM Star....Boosted-EH-804 Still a JDM Star....Boosted-EH-804 Still a JDM Star....Boosted-EH-804 Still a JDM Star....Boosted-EH-804 Still a JDM Star....Boosted-EH-804 Still a JDM Star....Boosted-EH-804 Still a JDM Star....Boosted-EH-804 Still a JDM Star....Boosted-EH-804 Still a JDM Star....Boosted-EH-804 Still a JDM Star....Boosted-EH-804 Still a JDM Star....Boosted-EH-804 Still a JDM Star....Boosted-EH-804 Still a JDM Star....Boosted-EH-804 Still a JDM Star....
Have you thought about push loc but it is really stupid tight might be best finding some hose that can handle oil and do the barbed fitting thing.
RCautoworks
Project D2B
Boosted-EH-804 is offline   Reply With Quote
Old 02-09-2010, 03:35 AM   #16 (permalink)
scottdh20's Avatar
Rep Power: 3 scottdh20 is a name known to allscottdh20 is a name known to allscottdh20 is a name known to allscottdh20 is a name known to allscottdh20 is a name known to allscottdh20 is a name known to allscottdh20 is a name known to allscottdh20 is a name known to allscottdh20 is a name known to allscottdh20 is a name known to all
barbed fittings plus rubber line FTMFW!!! mine was close, just about the same as yours, i had a hole oil line kit...feed and return, i scraped the return in favor of rubber hose, 10000x easier to get a good angle on it and works just fine. my buddies 9 sec maxima runs a rubber return line
boosted d15b7
14.23 @ 100 mph w/ 2.22 60ft
BUILD THREAD > http://d-series.org/forums/showcase/...ect-d15b7.html
sellers: hondacory ; Birdley97EKHB08
scottdh20 is offline   Reply With Quote
Old 02-09-2010, 04:49 AM   #17 (permalink)
Sohc52's Avatar
Rep Power: 0 Sohc52 is nobody
Maybe u have to try to relocate the bung which u welded on. then let it flow just downwards. It would be much better if the oil was flowing straight instead of doing the loop to the left.
Try using these. Fit those and then see the best position then reweld the bung to accomadate it. Maybe u might need to extend with a hose too. I forsee the fitting being alittle short.
Sohc52 is offline   Reply With Quote
iconAll times are GMT -8. The time now is 06:35 AM. | Welcome to Forum, please register to access all of our features.
