Holset Turbo Specs. HY, HX, H1C/WH1C, H1E/WH1E - D-series.org
Old 10-29-2009, 09:07 PM   #1 (permalink)
10SecRex's Avatar
Rep Power: 10 10SecRex is obviously a regular10SecRex is obviously a regular10SecRex is obviously a regular10SecRex is obviously a regular10SecRex is obviously a regular10SecRex is obviously a regular10SecRex is obviously a regular10SecRex is obviously a regular
Default Holset Turbo Specs. HY, HX, H1C/WH1C, H1E/WH1E
I figured that there really isn't much info on holset turbos on here. I came across on the dsmtuners and found some really good info on mostly all of the popular holset turbos.
HX35:
The 8blade hx35 has a 56mm compressor inducer. This is found on 1995-1998 cummins manual pickups. The compressor flows 52 lb/min according to the compressor map. The bolton BEP housing (0.55 a/r) is enough to push the limit of the compressor. There's several 500whp 8blade hx35 cars out there with the bolt on housing. It reaches 20+psi by 3500rpms in 3rd with 272 cams. Smaller cams would equal a faster spool speed in most cases.
The 7blade hx35 has a 56mm compressor inducer. This is found on the 1999-2002 cummins manual pickups. The compressor flows 60lb/min according to the compressor map and logged results from a member here. The bolton BEP housing with the hx35 turbine wheel do not SEAM to have enough flow to really reach the potential of 60lb/min. But many have logged over 50lb/min so far and seen 500whp. The stock hx35 12cm^2 twinscroll turbine housing is a t3 flange housing. This mated to a NON-divided runner manifold has produced a 132mph trap speed with a full weight 1g AWD. This is about 600whp. So the flow is there with the stock housing if you use a non-divided manifold. The spool speed of the 7blade hx35 is similar to the 8blade hx35 with 20+ psi by 3500rpms in the bolton housing and by 4000rpms with the stock housing with a non-divided manifold.
HY35:
The hy35 has a smaller turbine wheel than the hx35. And, it has a turbine housing connection that does not allow for a bolton housing to be used. It does not have a divided housing so any t3 manifold can be used effectively with this turbo. It has the same compressor as the 7blade hx35. We don't know if te hy35 turbine wheel and housing is enough to reache the 60lb/min potential of the 56mm 7blade compressor. Some one try it out already!!! It should at least be a faster spooling viable option to the full t3/t4 50-trim.
H1C/WH1C:
In 1994, there was the Wh1c which has pretty much the identical compressor as the hx35 but with a Vband compressor cover. The turbine wheel is the same. It will bolt into the BEP bolton hx35 turbine housing. It has 4 bolts at the housing instead of 6. So you will need to buy 2 more bolts and use 6 washers cut to make a flat side. Honestly, I just used bolts that were cut a little short and the bolt head was wide enough to pull the chra to the turbine housing. No sealing issues. Since the Wh1c is for all practical purposes an 8blade hx35 the spool and flow is the same too.
I have the big h1c. It comes on the INTERCOOLED 1991-1993 cummins pickups. It has the webbing for MWE but no groove cut like the hx35/wh1c has. This turbo I term the big h1c because it has a 54mm compressor inducer and same exducer than the 8blade hx35/Wh1c. The other h1c is the small h1c found on the NON-intercooled cummins pickups. This has a 50mm inducer but only 7blades and has no webbing for MWE. Less blades helps flow, but so does a larger inducer diameter. The most whp ever recorded on a gas 4cylinder with the small h1c was done on a KA24 nissan: 411whp. Since the big h1c has a 4mm larger inducer and the same turbine wheel as the hx35, it is safe to say that it flows enough for between 411whp and 500whp. The diesel sources state that it flows SLIGHTLY less than the early hx35. So 4lb/min less than the 8blade hx35 puts the flow of the big h1c at 48-49lb/min right where a 50-trim or 20g is. The small bep housing is all that's needed to get the most from the compressor and the spool speed is 20+psi by 3500rpms.
HX35-40 hybrid:
Keeping the long tradition of the marriage of sportcompact and hybrid turbos, there is the hx35 turbine and the hx40 compressor. It is strongly recommended to use the large bep turbine housing or the stock hx35 turbine housing with an non-divided t3 manifold for this turbo. The small bep housing around a t31 size hx35 turbine wheel is probably not enough to merit any of the hx40 compressor wheel upgrades. 20+ psi by 4000rpms can be seen in the hx35/40 with the hx35 12cm^2 turbine housing with a non-divided t3 manifold. With the large bep housing, spool times are to be determined. But likely similar.
HX40:
The 8blade hx40 has a 58mm inducer and flows about the same as a 60-1 (around 60lb/min) with ALOT better high boost efficiency and spool speed. It is the most common hx40 out there. The small bep housing with the hx40 turbine wheel is plenty to reach the full potential of the 60lb/min 8blade hx40 compressor. 20+ psi by 4100rpms with 272s.
The 7 and 6 blade hx40 is called the super40 and has the 60mm compressor inducer. This compressor flows around 69lb/min. You can get this wheel in billet style (think HTA). The non-billet wheel spools as fast as the 8blade hx40 in the bolton bep housing and has done 653whp at 40psi per the holset results only thread. Billet should spool even faster. The t3 .70 a/r BEP housing slows spool about 400rpms. But reports show a significant gain in flow per psi. So expect more power at lower boost with that turbine housing.
H1E/WH1E:
The Wh1e is like it's little brother the Wh1c. It mirrors the hx40 8blade in every way except that it has a v-band compressor cover and a 4bolt chra-turbinehousing pattern. It will consequently bolt into the hx40 bep bolton turbine housing and this is plenty of flow to max out its 60lb/min compressor.
The h1e is like it's little brother the h1c. There are different size compressors. . . BUT there are also different size turbine wheels too. Check measurements before buying this turbo if you plan on running a BEP turbine housing. There are lower flowing compressors than the 58mm 8blade that are out there. So this turbo may not flow any more than an hx35 if get the wrong one. You need at least a 58mm compressor inducer for this to be a worthwhile turbo vs the proven hx35 or 8blade hx40.
HX52:
This is a big sucker. It is commonly found on the Volvo Semis and usually has a billet compressor wheel. It flows 88lb/min. There is no bolt on housing for it. If you want a bolton housing for this turbo, then you don't want this turbo. In fact if you want a t3 flange turbine housing for this turbo, then you don't want this turbo. You DO want this turbo if you're looking at a gt4294r or gt4202r. The turbine inlet is slightly different than a t4 bolt pattern. You can still get the t4 manifold to work just fine by enlarging the bolt holes.
Misc.:
* Holset's don't spool slow. They spool faster than their garrett or mitsubishi counterparts. Diesel exhaust is cold and slow moving.
* The holset turbine wheel is a work of art. It has been shown to flow very well in a very small turbine housing. For example the hx40 turbine wheel in the small .55 ar bep bolton housing flows as much as a garrett gt35r turbine wheel in a larger .63 ar garrett t3 turbine housing. The hx40 with this configuration spools about 500rpms faster! You can upgrade to the .70 a/r BEP t3 turbine housing and have the same or slightly faster spool speed as the above gt35r with ALOT more flow per psi and consequently more horsepower per psi. This makes for VERY good pumpgas numbers.
* Holset patented map width enhancement. They do not have extended tip technology, but there compressors show more efficiency than their garrett or mitsubishi counterpart.
* They have superback technology witch leads to VERY, VERY durable compressors. The are designed to be overworked and underpaid.
* There are discrepancies all over the web concerning the compressor maps. Take what you hear/read with a grain of salt and a shot of tequila, and the worm.
* The holset is fine with stock 4g63 oil pressure from the oil filter housing. If you have no b shafts, you'll need a restrictor. The drain line is a garret bolt pattern. The feed line is different for different turbos.
HX40 Compressor Map:
HX35 Compressor Map:
Here are some external comparison pictures between the HX and HY35.
May 31, 2009
12.336@113.57, 1.816 60ft. 21psi
10SecRex is offline   Reply With Quote Quick reply to this message
Old 10-29-2009, 09:15 PM   #2 (permalink)
formerly allnaturalrex
greasemonkey89's Avatar
Rep Power: 20 greasemonkey89 is the fucking MAN!!!!greasemonkey89 is the fucking MAN!!!!greasemonkey89 is the fucking MAN!!!!
Send a message via AIM to greasemonkey89
nice did you get it from that holset forum.
greasemonkey89 is offline   Reply With Quote Quick reply to this message
Old 10-29-2009, 09:18 PM   #3 (permalink)
10SecRex's Avatar
found it on dsmtuners.com
I recently sold my 8 blade WH1C and now regretting it! So I went out and bought 2 turbos' and still deciding wich one to use. I got a 7 blade HY35 with the 9^cm2 and a 7 blade HX35W with the 12^cm2.
But I think I am going to rock the HX35W and build a twin scroll manifold for it unless anyone know where I can find a undivided housing for it.
May 31, 2009
Old 10-30-2009, 11:51 AM   #4 (permalink)
Rep Power: 0 dpine is nobody
where are you getting the data for the spool times? If you got the info from dsmtuners then are they being compared on a 4g63.
dpine is offline   Reply With Quote Quick reply to this message
Old 10-30-2009, 11:52 AM   #5 (permalink)
racist-bigot-sexist-homophob
mindless's Avatar
Rep Power: 41 mindless is on a level you can only DREAM about! ! !mindless is on a level you can only DREAM about! ! !
iTrader Score: 43 reviews
Sticky.
Old 10-30-2009, 01:07 PM   #6 (permalink)
10SecRex's Avatar
Like I've said over again, info was from dsmtuners.com. even though the spool time is on a 4g63 its the only real hard info that people has logged. It should atleast give us an idea of what spool times should be, given our 1.6/1.5.
Until we, ourselves, has logged any hard info this will have to do.
May 31, 2009
Old 11-02-2009, 07:43 PM   #7 (permalink)
10SecRex's Avatar
Originally Posted by mindless View Post
Sticky.
bump...
I added some more pictures on post 1. Courtesy of dieseltruckresouce.com
May 31, 2009
Old 11-02-2009, 08:26 PM   #8 (permalink)
Rep Power: 12 vtec_bomber is a name known to allvtec_bomber is a name known to allvtec_bomber is a name known to allvtec_bomber is a name known to allvtec_bomber is a name known to allvtec_bomber is a name known to allvtec_bomber is a name known to allvtec_bomber is a name known to allvtec_bomber is a name known to allvtec_bomber is a name known to all
Hum, the hy35 look more sexier. Haha.
vtec_bomber is offline   Reply With Quote Quick reply to this message
Old 11-02-2009, 08:32 PM   #9 (permalink)
10SecRex's Avatar
haha, we'll see whose sexier when the hx sucks in the hy... hyhx
May 31, 2009
Old 11-03-2009, 04:18 AM   #10 (permalink)
Rep Power: 0 N54E90XI is nobody
That comparison picture is still the 7blade vs 7blade bro - probably the "hx35w".
N54E90XI is offline   Reply With Quote Quick reply to this message
Old 11-03-2009, 05:41 AM   #11 (permalink)
10SecRex's Avatar
yes, both are the later versions 7blade (99-02 cummins manual hx35w, automatics hy35) , the ones that i have are both 7 blade.
May 31, 2009
Old 11-03-2009, 10:25 AM   #12 (permalink)
sohc-gT's Avatar
Rep Power: 12 sohc-gT  is slowly gaining respectsohc-gT  is slowly gaining respectsohc-gT  is slowly gaining respectsohc-gT  is slowly gaining respectsohc-gT  is slowly gaining respect
nice info! now were can one buy a holset turbo besides ebay?
91 Integra LS-S
190whp 130wtq
13.5@104mph street tires 9/6
12.8@104mph slicks 10/6
92 civic hatch
stock d16y8 18psi 15g
R.I.P. 3/12/8
250whp 221wtq 12.5@110mph
Vitara build 44trim ebay setup
R.I.P. 8/9
325whp 210wtq 20psi 11.7@121
sohc-gT is offline   Reply With Quote Quick reply to this message
Old 11-03-2009, 12:02 PM   #13 (permalink)
10SecRex's Avatar
ebay, craigslist, deiseltruckresource.com, cumminsforum.com...h-t and even dsmtuners.com....
May 31, 2009
Old 11-07-2009, 04:22 PM   #14 (permalink)
Rep Power: 0 turbod16y8 is nobody
what do you guys think about this turbo. I want to go pick it up but want your guys opinion. Its gonna be for my d16z6 vitara/fjt build
94 Dodge Diesel factory Holset "Turbo" cummins 12V or
dodge diesel turbo -
turbod16y8 is offline   Reply With Quote Quick reply to this message
Old 11-18-2009, 04:31 PM   #15 (permalink)
hotrodj's Avatar
Rep Power: 13 hotrodj is a Top Aussie
iTrader Score: 30 reviews
any more info on the BEP housing? where to find them? I seen they come in 2 a/r sizes, i think .55 and .70, that ive seen.
94 del Sol si 144whp, 113tq
I/H/E, pnp y8 head,Bisi lvl2, Hondata S300,
Stock Z6 bottom end
PM for ECU Chipping/Socketing and Repair Prices
Old 11-18-2009, 04:38 PM   #16 (permalink)
92CXyD's Avatar
Rep Power: 13 92CXyD is hot as a volcano92CXyD is hot as a volcano
This info and more is also on TurboByHolset.com
If you want to know about my avatar
ENMO.
An Emo car would cut its own tires and never get out of the garage.
92CXyD is offline   Reply With Quote Quick reply to this message
Old 11-18-2009, 05:15 PM   #17 (permalink)
khrys771's Avatar
Rep Power: 10 khrys771 is obviously a regularkhrys771 is obviously a regularkhrys771 is obviously a regularkhrys771 is obviously a regularkhrys771 is obviously a regularkhrys771 is obviously a regularkhrys771 is obviously a regularkhrys771 is obviously a regular
i'd like to try an he351ve. like this guy did.
Turbo Talk - View topic - 95 TSI AWD HE351VE VGT Holset Build
1996 civic dx coupe - daily
1998 civic dx hatch - d2b 5857 turbo
khrys771 is offline   Reply With Quote Quick reply to this message
Old 01-07-2010, 06:59 AM   #18 (permalink)
Is there any info on the wastegates for these turbos?
Old 01-07-2010, 09:18 AM   #19 (permalink)
FarmerD is on a level you can only DREAM about! ! !FarmerD is on a level you can only DREAM about! ! !FarmerD is on a level you can only DREAM about! ! !FarmerD is on a level you can only DREAM about! ! !FarmerD is on a level you can only DREAM about! ! !FarmerD is on a level you can only DREAM about! ! !
the trucks run 20+ psi.
go external.
Old 02-12-2010, 01:37 PM   #20 (permalink)
Rep Power: 0 kaminam is nobody
what truck came with the HY35?
kaminam is offline   Reply With Quote Quick reply to this message
LinkBacks (?)
LinkBack to this Thread: http://www.d-series.org/forums/forced-induction/120686-holset-turbo-specs-hy-hx-h1c-wh1c-h1e-wh1e.html
Posted By For Type Date
UKSaabs • View topic - Holset Turbos This thread Refback 02-05-2013 06:36 PM
Nissan Klub Turbokillers :: turbiny holset This thread Refback 01-23-2013 11:26 AM
iconAll times are GMT -8. The time now is 01:30 AM. | Welcome to Forum, please register to access all of our features.
