LinkBack (10) | Thread Tools | Display Modes |
#82 (permalink) |
formerly Kit88
amazing job on that vc, also I´ll hit you up about that catch can setup.
this build looks clean and very orginal, props for you .
95 hatch w/ a6 block and d16z6 head precision sc60 turbo at 23 psi 24.5x9x13 M&H w/bogart flystars Tuned, by Alexracing 11.80 at 127 mph
#83 (permalink) |
D-series.org Sponsor
Very nice!!! I love how everything looks.. Clean and well organized..
#84 (permalink) |
looks nice as shit man!! only thing i see is the vent tube coming from the valve cover goes to the bottom of the catch can... shouldnt it go to the top....
great job on the clean looking and high horsepower parts!
my new and improved build... check it out http://d-series.org/forums/forced-in...-build-14.html best time so far 11.201 at 128mph with a 1.79 60 foot.. damn i need traction, best trap speed is 129mph. 26psi h1c NEW best 60' 1.56!!! |
#85 (permalink) | |
Tuna brought up the same thing on another forum, so I'll just copy it here: Originally Posted by Big Tuna: "I have to ask, why you did the catch can that way? If the motor pushes out enough oil to start filling the can in the event of a serious motor issue the can cant vent once the oil level rises to the level of the AN fitting, after that it just turns into a bubbler and pushes the oil out with the air. Wouldn't it of been better to put the fitting as high as possible in the can so in the event the motor pushes out a ton of oil, the oil can fall out of suspension and fill the can while the gas escapes? The only reason I am saying something is I have seen a similar style can setup be very ineffective during a motor issue." Tuna: There are several reasons, and you bring up a good point for discussion. Your concern with the design was discussed before we did it. My thoughts on the matter: A) Our vent channel on top of the VC draws air from above the factory baffling (which is very well designed) that is already in place. Since it's located on the top of the VC behind the factory baffling, there will be zero oil pushed into it due to puddling/splashing/acceleration/etc as seen with VC vents that are located on the front or rear of the VC. So.....that eliminates one of the normal "issues" with typical venting schemes. This design will carry less oil into the can than usual IMO. B) We tried several different routing options for the A.N. fittings and line, and this routing provided enough flex in the line to be able to remove the line easily, and looked the best as well. C) "If the motor pushes out enough oil to start filling the can in the event of a serious motor issue the can cant vent once the oil level rises to the level of the AN fitting, after that it just turns into a bubbler and pushes the oil out with the air." - Big Tuna In that event, the whole VC would have to fill with oil to the top to start pushing into the can. That'll never happen. And if there was that serious of a motor issue, you've got 2 quarts catch can capacity for a reason. Besides, you'd notice something wrong at that point and shut it down. If the catch can did fill up enough with oil to start filling up the A.N. line in normal use, it'd still push or "bubble" the pressurized blowby into the can. At high speeds/loads where there is a lot of blowby, this would be much like a steady stream of air and I feel the can would still be every bit as functional. There is a fitting under the can that can be accessed in the wheel well to drain it easily, and an internal baffle in the can to knock oil in the airstream out of suspension as well. So...we will see how it works out. If it does need some reworking we will do so, but I think it'll be fine as is. We will see!
VITARA RECORD HOLDER!!! 609whp/404tq @ 30psi 10.4 - 138mph - Vitara D16 (on old 471whp setup) 9.20 - 170mph - S/C '92 CX 84mm B18C, 24.5" tire SPEEDFACTORY Tuning & Race Fabrication http://www.speedfactoryracing.net |
#87 (permalink) |
i didnt want to quote your whole responce, but thanks for clearing up why you did it that way.. i was thinking the same thing tuna brought up, but in shorter terms haha.. im sure it will work out well... especially with the baffling still in place under the VC..
#91 (permalink) |
Update:
I really wanted to get it all tuned out today but didn't have time, we are just too swamped this week. So, we just threw it on the dyno and got a few pulls in off the WG before we left today just to see how she's gonna do. 428whp/287tq @ 19psi (gate). ![]() We didn't have time to do any in-depth tuning. The cam gear is still at 2* advanced from the N/A tune, it needs to be retarded to carry high rpm power better, so I feel there's still some more in it yet. But I'm very happy with the numbers at such low boost, and the turbo spooled better than I expected. It made 17psi by 6100rpm, so the powerband is plenty wide, and it'll go 10's at this power level already! ![]() Just got a vid of the pull up:
VITARA RECORD HOLDER!!! 609whp/404tq @ 30psi 10.4 - 138mph - Vitara D16 (on old 471whp setup) 9.20 - 170mph - S/C '92 CX 84mm B18C, 24.5" tire SPEEDFACTORY Tuning & Race Fabrication http://www.speedfactoryracing.net Last edited by JFK78; 06-30-2009 at 12:14 AM. Reason: added video |
#93 (permalink) |
![]() Great #s. This thread makes it hard for me to fight the temptation of putting a big turbo back on my car...I think I'm about to lose that battle
D-Series.Org Sponsor...check our feedback ![]() ![]() Shop 24/7 @ WWW.GO-AUTOWORKS-STORE.COM Main site WWW.GO-AUTOWORKS.COM 2009'-2010' Import Face-Off Title Sponsors...Keep the Sport alive, Come Race with US!! |
#94 (permalink) |
nice numbers guys, 19psi..sweet.
What are you taking it to for revs?
My Build Thread and Timeline http://d-series.org/forums/showcase/...r-gt3076r.html 1998 civic lx-T 215whp 187 tq, daily driven on a stock d16y7 13.2 @ 103MPH 1.96 60ft, clutch burnt out |
#96 (permalink) | |
lets see how much i care today
thats a hole butt load of horsepower.. would like to see a higher tq number myself. i am sure things will be looking much better once you have a full tune session. can't wait for the final results
99 Lightning = the DDwtf? |
#98 (permalink) |
Awesome job for just a "lets see what it do" tune. Cant wait to see what it does on a full session. So what cam did you decide to go with? I know you said Bisi was going to hook you up, but with which one. Its crazy you say you can do 10s with these #s which I do believe, a buddy of mine is scramblin to run 10s on a 500hp b16 setup.
12.40@113mph ol set up 292 255ftlbs New times coming in 2010 ![]() 400hp 313ftlbs Shue tuned ftw!!! |
#99 (permalink) | |||||
If it were 19psi steady, torque would've been 300tq range. So it's actually alot of torque for boost level, about 30 ft/lbs more than last years setup at the same boost level. I overlaid it with my 471whp chart from last year, and torque is already within 25 ft/lbs at high rpm, at only 19psi vs 29psi last year! Thanks, and yeah, you'll have to do that! It's always nice to meet some of the guys from the forums.
#100 (permalink) |
formerly Kit88
I can´t wait to see the numbers on a full dyno session with the Bisi cam on it.
very good results for 19psi.
