How do i convert p06 to p28 (nonvtec to vtec) - D-series.org
Old 09-18-2006, 01:53 PM   #1 (permalink)
thsmrtone1's Avatar
Rep Power: 12 thsmrtone1 smells like Boratthsmrtone1 smells like Boratthsmrtone1 smells like Boratthsmrtone1 smells like Boratthsmrtone1 smells like Boratthsmrtone1 smells like Borat
Send a message via AIM to thsmrtone1 Send a message via MSN to thsmrtone1
Default How do i convert p06 to p28 (nonvtec to vtec)
how do i convert p06 to p28 (nonvtec to vtec)... ive heard its possible, but has anyone done this and know of a good write-up... pics? anything?
I REP BACK! (if it lets me
ehh, with a traction bar and inserts in all the mounts, the motherfucker vibrated like a v-12 powered dildo.
thsmrtone1 is offline   Reply With Quote Quick reply to this message
Old 09-18-2006, 02:08 PM   #2 (permalink)
99EJ6T's Avatar
Rep Power: 42 99EJ6T is on a level you can only DREAM about! ! !99EJ6T is on a level you can only DREAM about! ! !99EJ6T is on a level you can only DREAM about! ! !
iTrader Score: 32 reviews
start here for the kit (parts): http://www.xenocron.com/products.php?page=chippingkits
then go here: http://xenocron.com/install/index.htm
and select the kit you got.
Old 09-18-2006, 02:18 PM   #3 (permalink)
AllMotorDPower's Avatar
Rep Power: 14 AllMotorDPower is a Top Aussie
AllMotorDPower is a Top AussieAllMotorDPower is a Top AussieAllMotorDPower is a Top AussieAllMotorDPower is a Top AussieAllMotorDPower is a Top AussieAllMotorDPower is a Top AussieAllMotorDPower is a Top AussieAllMotorDPower is a Top AussieAllMotorDPower is a Top AussieAllMotorDPower is a Top AussieAllMotorDPower is a Top Aussie
Send a message via AIM to AllMotorDPower
or u can buy a obd0 to obd1 conversion harness and save alot of time
check on rywire thats were i got mine its a real simple install
AllMotorDPower is offline   Reply With Quote Quick reply to this message
Old 09-18-2006, 02:22 PM   #4 (permalink)
CrazyConscious's Avatar
Rep Power: 16 CrazyConscious is about to kiss the sky
CrazyConscious is about to kiss the skyCrazyConscious is about to kiss the skyCrazyConscious is about to kiss the skyCrazyConscious is about to kiss the skyCrazyConscious is about to kiss the skyCrazyConscious is about to kiss the skyCrazyConscious is about to kiss the sky
OR you could buy one of these...lol...http://www.d-series.org/forums/showthread.php?t=51431
boosted D16Z6 :shocked:
Honestly, I would piss on his door handles. Regularly, like his door was my personal bathroom.
CrazyConscious is offline   Reply With Quote Quick reply to this message
Old 09-18-2006, 02:32 PM   #5 (permalink)
thsmrtone1's Avatar
thing is, ive already got the chipped p06... all i need is vtec cuz im doing a d15b swap... and instead of buying a p28 to add to my collection of ecus, id like to just make this one so i can use it...
Old 09-18-2006, 02:34 PM   #6 (permalink)
thsmrtone1's Avatar
Originally Posted by 99EJ6T
start her for the kit (parts): http://www.xenocron.com/products.php?page=chippingkits
thanks... that helps a TON
Old 09-19-2006, 09:35 AM   #7 (permalink)
slowcivic2k's Avatar
Rep Power: 12 slowcivic2k is nobody
got a P08 vtec ecu, if you need one.
slowcivic2k is offline   Reply With Quote Quick reply to this message
Old 09-19-2006, 03:15 PM   #8 (permalink)
Rep Power: 0 92civy is nobody
wat do u want for the p08 ecu?
thanks
92civy is offline   Reply With Quote Quick reply to this message
Old 09-21-2006, 01:00 AM   #9 (permalink)
Sonictronic's Avatar
Rep Power: 14 Sonictronic is learning the way of the DSonictronic is learning the way of the D
done it plenty of times. Running a P06 in my coupe with d16z6/turbo.
you need to find out if it has an 11F0 or 1720 board. 11F0 is easy, 1720 is a bit more involved. It would probably be best to send it out for the conversion if you are not solder inclined. De-soldering is the hard part.
pgmfi.org has a great wealth of info as well. Read the wiki!
Im JDM Short Yo!!!!!1!11!!
98 ex Ls/vtec turbo
93 dx d16 turbo
94 cx shell
94 se teg shell
88 std shell
Sonictronic is offline   Reply With Quote Quick reply to this message
Old 09-21-2006, 01:19 AM   #10 (permalink)
eg4
eg4's Avatar
Rep Power: 14 eg4 is a name known to alleg4 is a name known to alleg4 is a name known to alleg4 is a name known to alleg4 is a name known to alleg4 is a name known to alleg4 is a name known to alleg4 is a name known to alleg4 is a name known to all
Send a message via ICQ to eg4 Send a message via AIM to eg4 Send a message via MSN to eg4
current setup:
ported d16y8 head
AEM TRUTIME camgear
105300 cam
ferrea 20 Super Flo. 1 mm oversize valves
zex valve springs
Edelbrock Performer X
62mm TB
d16a6 block
76mm p29 pistons
walbro 255lph
100cel catalytic convertor
fidanza 7lbs flywheel
dc2 catback
comptech header
CROME tuned p28 ecu
12,5:1 cr
4,43FD
eg4 is offline   Reply With Quote Quick reply to this message
Old 09-21-2006, 12:12 PM   #11 (permalink)
csaddict's Avatar
Rep Power: 14 csaddict is starting to learn the ropescsaddict is starting to learn the ropescsaddict is starting to learn the ropescsaddict is starting to learn the ropescsaddict is starting to learn the ropescsaddict is starting to learn the ropes
OBD0 has nothing to do with a P06. Not even a related comment. A P06 is OBDI so is a P28. They are the same exact board, you just add the VTEC components.I convert them all the time. Actually I am converting one tonight. www.pgmfi.org
owns you.
csaddict is offline   Reply With Quote Quick reply to this message
Old 09-21-2006, 12:55 PM   #12 (permalink)
thsmrtone1's Avatar
plus the engine is obd1
Old 09-21-2006, 05:15 PM   #13 (permalink)
turboprelude95's Avatar
Rep Power: 25 turboprelude95 Still a JDM Star....
turboprelude95 Still a JDM Star....turboprelude95 Still a JDM Star....turboprelude95 Still a JDM Star....turboprelude95 Still a JDM Star....turboprelude95 Still a JDM Star....turboprelude95 Still a JDM Star....
The 11f0 is easy but how do you get the vtec pressure switch to work also. Do you add another 515 x high side switch right next to ic14? So then there would be 2 515 x high side switch, one in ic14 and the other to the right of it.
P.S I just want to know because i'm going to try bbka's bin and does anyone know if he had a 1.7 bin?
Crx
Jswap 4dr
Boost 4dr
Twin scrol
F2B
turboprelude95 is offline   Reply With Quote Quick reply to this message
Old 09-21-2006, 05:31 PM   #14 (permalink)
csaddict's Avatar
You don need anything other than what is listed to get it all work. go to www.xenocron.com and you can get the 1.7 bbka map I would suggest using Crome insted of Uberdata though.
owns you.
Old 09-23-2006, 12:16 AM   #15 (permalink)
Nope, only one 5151 required, just make sure its a 5151 and not a 5050(5050's cause CEL after vtec engage). Vtec pressure should work right if the blue wire on the switch is hooked to pin d6 and the black to ground.
98 ex Ls/vtec turbo
93 dx d16 turbo
94 cx shell
94 se teg shell
88 std shell
Old 10-26-2006, 07:17 PM   #16 (permalink)
xenocron's Avatar
Rep Power: 13 xenocron is trying to make new friends
Send a message via AIM to xenocron Send a message via MSN to xenocron
5050 work on 92-93 '1720 board' ECUs just fine
they will not work in the 94-95 11F0 board types
5151 will work in 1720, 11F0 or 1980 board types, just FYI
Fuel Management for the Do-It-Yourselfer in mind
xenocron is offline   Reply With Quote Quick reply to this message
Old 10-26-2006, 10:51 PM   #17 (permalink)
siregcivic's Avatar
Rep Power: 16 siregcivic is almost there....
siregcivic is almost there....siregcivic is almost there....siregcivic is almost there....siregcivic is almost there....siregcivic is almost there....siregcivic is almost there....siregcivic is almost there....siregcivic is almost there....siregcivic is almost there....
Send a message via AIM to siregcivic
im running a p05 ecu in my z6 turbo its the 1720 board...its not that much harder then the 11fo wich is easy but with some soldering skills AND patience and read the instructions provided by xenocron its an easy task..
i got both of my p05 to vtec 11f0 and 1720 from chris... couldnt ask for anything more instructions make everything easy... the only hard part is finding some of the locations on the board other than that its cake
MN TUNING Neptune dealer/tuner socal area
SOBER TILL ITS OVER
can you tell me how to hook up a vtech switch?
i want it on the new steering wheel i got at pep boys. have you seen it its sick!
but if i hook up the vtech i can have it at like whatever rpms i want right?
like vtech all the time? will it pop louder?
Just hook it up to a clapper and slap yourself in the face everytime you race......
siregcivic is offline   Reply With Quote Quick reply to this message
Old 10-26-2006, 11:18 PM   #18 (permalink)
thsmrtone1's Avatar
ya it took me about 15 minutes to install the kit i bought from xenocron, and its been in and working for about a month... thanks
Old 10-30-2006, 03:48 PM   #19 (permalink)
Rep Power: 13 SoCaL760D16Y8 is nobody
does the ecu have to be chiped for this to work and can i get all the parts myself or is buying the kit my best bet
SoCaL760D16Y8 is offline   Reply With Quote Quick reply to this message
Old 10-30-2006, 05:17 PM   #20 (permalink)
thsmrtone1's Avatar
1st, im sure you could probably piece together the kit but it would be way easier to just buy the kit... and yes im 99% sure you have to chip the ecu cuz to my knowledge, the non vtec board doesnt have built in maps for vtec... xenocron.com has vtec and chipping combos you can buy
iconAll times are GMT -8. The time now is 01:56 AM. | Welcome to Forum, please register to access all of our features.
