Go Back   D-series.org » Motor Mayhem & Suspension Satisfaction » Engine Management
Old 10-16-2005, 04:27 PM   #1 (permalink)
Tuner Type 1's Avatar
Rep Power: 5 Tuner Type 1 is learning the way of the DTuner Type 1 is learning the way of the D
Question OBD1 ecu for a Y7???
Hey,
I'm looking to convert my 1998 D16Y7 OBD2 ecu to a OBD1.... What ECU should I use? My mods are a ported head, Y8 intake manifold, Delta 272 cam, Bisimoto header (hopefully I can find one)... I have the original injectors from the Y8 intake manifold. Would I be able to use them in this conversion without chipping the new ECU? Would there be any gains? What model of OBD1 ecu would be the best for my application? Would I be able to use it as is without chipping it with the stock Y7 injectors? Would there be gains? Later on where would I be able to get it chipped? (someone reputable from the board?) Any conversion harnesses that someone would reccomend? Thanks.
Ryan.
"B-Series are like tampons every pussy needs one..."
Quoted from some smart man...:TU:
Tuner Type 1 is offline   Reply With Quote
Old 10-16-2005, 04:36 PM   #2 (permalink)
Cool User Title Here
Honda4VW's Avatar
Location: 7.5 hours north of Modshxcivic, 6.5 hours north of Rexinre's house (he says only 5 hours) (MAINE)
Rep Power: 15 Honda4VW is hot as a volcanoHonda4VW is hot as a volcano
Honda4VW is hot as a volcanoHonda4VW is hot as a volcanoHonda4VW is hot as a volcanoHonda4VW is hot as a volcanoHonda4VW is hot as a volcanoHonda4VW is hot as a volcanoHonda4VW is hot as a volcanoHonda4VW is hot as a volcanoHonda4VW is hot as a volcanoHonda4VW is hot as a volcano
P06 would be one choice. Won't see huge gains, but most likely a little bit of a gain
My Old Car
Honda4VW is offline   Reply With Quote
Old 10-16-2005, 11:43 PM   #3 (permalink)
Axel's Avatar
Rep Power: 5 Axel is learning the way of the DAxel is learning the way of the D
I'm considering the option of going obd1 with my y7 too.
Setup - z6 IM, z6 rail, z6 fpr, and some bolt-ons.
Thinking of going with the z6 injectors too, and converting to obd1 and running a p28.
Any suggestions, ideas, thoughts here? will this setup work fine with my y7 engine?
I'm getting a stock z6 head (with stg 1 cam) at a later point too i think.. .that's mainly why i wanted the p28 obd in my car.
Originally Posted by jake2001z001
My z6 stock holds 10 psi like it was stroking its dick...
Originally Posted by rotory20
Na Sucks And Its Loud As Fuck!
#0980 of Club Honda Norway - club-honda.org
-97' Civic Coupè - EJ6 - Milano Red - My setup w/pics
[x]85' Opel Ascona 1,6GLS [Wintercar/wrecked]
[x]87' Saab 900 turbo 8v [sold]
Axel is offline   Reply With Quote
Old 10-17-2005, 09:12 PM   #4 (permalink)
perlmeistere8's Avatar
Rep Power: 6 perlmeistere8 is nobody
Default ecu
Originally Posted by Tuner Type 1
Hey,
Ryan.
You can use a p28 and run crome/uber/neptune and just disable vtec. Then later on if you plan on getting a y8 head, you can activate vtec easily.
97 Civic Sedan EX
Old setup: Greddy 15g kit @ 10 psi
New setup in progress...
perlmeistere8 is offline   Reply With Quote
Old 10-17-2005, 09:16 PM   #5 (permalink)
MyblkVTEC's Avatar
Rep Power: 14 MyblkVTEC is hot as a volcanoMyblkVTEC is hot as a volcano
MyblkVTEC is hot as a volcanoMyblkVTEC is hot as a volcanoMyblkVTEC is hot as a volcanoMyblkVTEC is hot as a volcanoMyblkVTEC is hot as a volcanoMyblkVTEC is hot as a volcanoMyblkVTEC is hot as a volcanoMyblkVTEC is hot as a volcanoMyblkVTEC is hot as a volcano
Thats what I was gonna say!!
MyblkVTEC is online now   Reply With Quote
Old 10-17-2005, 09:19 PM   #6 (permalink)
Default yes
:thumbup:
97 Civic Sedan EX
Old 10-17-2005, 10:13 PM   #7 (permalink)
Axel's Avatar
Is it possible to run a VAFC and run vtec off the VAFC unit and just not engage it... or make it engage @ 15k or something? and just run the p28 with no special tuning?
iconAll times are GMT -8. The time now is 08:56 PM. | Welcome to Forum, please register to access all of our features.
